passenger power window stopped working
My guess, is either bad switch or bad motor... or both... maybe bad switch and it burnt out the motor... gotta take it apart this weekend and put a voltmeter to it.
Forgot to mention the other 3 are working fine.
timecop369
Are the other three working fine?
timecop369
The motor,
The window regulator,
or the switch.
It is possible that the switch is faulty, I have seen it before.. all other windows work except one because of the faulty switch,
It can be a broken window regulator, but for this you would still hear the motor working inside the door,
and last but not least.. it can be the motor itself.
does the window work from the rear window switch?? if not its gonna be either the regulator or the motor.
ya gotta do some testing,
get the volt meter out!!
