Anyone have alignment issues after lowering?
TIA
I installed the Eibach Pro Kit with the stock Sport Springs on my 99 C280 Sport and lowered the car to about 1 finger gap with a set of AMG 18's and have had no alignment issues.
Install was done by a buddy of mine who is a MB tech and he even did the alignment at the shop.
Make sure you put the right spring pads on to get the right effect.
Would you not use the same size pads/shims that came on the car? If not how would you know without installing the springs, testing and then reinstalling if they are not correct?? Could get expensive.
The tech who did my car drives a C36 so I just asked him what he used and went with his suggestion.
I will try and take a pic and post it.
If your camber is too negative, youc an get a rear camber kit from speedybenz on club202.com and a front camber kit from many manufacturers... on myc ar the camber was still less than -2 everywhere.
Etienne
Thanks to all for advise and help. Now to get an alignment and I am set.
