W203/CL203 Suspension (Shocks/Springs/Sway Bars) Discussion/Upgrade Thread
Rating: Thread Rating: 6 votes, 5.00 average.
Old 10-05-2006, 12:42 PM
  #251
Super Moderator Alumni
drexappeal's Avatar
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Originally Posted by C320PO
I'm hoping to keep it under 1K. Of course, the lower the better.
I guess the fundamental question would be, are sway bars sufficient to take of the lean in issue? Some people say yes and some say no. Given the car is 5 years old, it may be time for new suspension but I just spend a bundle on the car. My local shops are saying coilovers are definitely the way to go but they have $$ in their minds.
The combo coilover + sways would be near 2k, that more than what I want to spend for now.
1. Lowering the car isn't just for "looks". When you get performance springs that shorten the amount of compression and lower the center of gravity, you'll increase handling
2. Swaybars will take away a lot of the lean that you're experiencing with the stock luxury setup.
3. If you want to stay under $1,000 and keep the ride comfort, you can do the following:
- Aftermarket springs (used - there's always someone upgrading to coilovers) Anywhere from $100-250 would be reasonable, depending on what kind of springs.
- Bilstein adjustable shocks (so that you can keep it on the softest setting, which would possibly be softer than the sport shocks) Buy these new. They're the most expensive of all the things you would need, but would be worth it.
- AMG swaybars $150
OR
- Buy the entire suspension setup used from someone who upgrades their 2005-present Sport Sedan model to coilovers. I believe there are a couple people who have 2005 models that recently upgraded their swaybars, so you might want to look through the Classifieds for those.
Old 10-05-2006, 12:54 PM
  #252
Blake P's Avatar
'09 A4 S Line
Originally Posted by drexappeal
OR
I think this will be his most cost effective option. Most guys are unloading their sport suspensions for little to nothing since there's no real market for OEM suspension. Used sport suspension with AMG sways should be a cheap solution to his problem, though not necessarily the best option.
Old 10-05-2006, 03:10 PM
  #253
WaveyKat's Avatar
Something Slow
am thinking about getting the tein Super Street maybe i can sell you my tein Basic coilover
Old 10-05-2006, 03:13 PM
  #254
Blake P's Avatar
'09 A4 S Line
You want SS in order to set it to the softest setting?
Old 10-05-2006, 04:48 PM
  #255
Ryanr317's Avatar
R129, XF Sportbrake, SC400
Anyone know if it would be a bad idea to replace just the front springs with lowering springs and to leave the back stock. The back gap is pretty small as it is, it's just the front gap that is too big. I know the spring rates would then not match up, that's why i'm concerned.
Old 10-05-2006, 04:50 PM
  #256
Blake P's Avatar
'09 A4 S Line
I think you answered your own question...very bad idea.
Old 10-05-2006, 08:24 PM
  #257
drexappeal's Avatar
Johnny is selling his swaybars from his 2005 C230K SS.
https://mbworld.org/forums/classifieds/165675-2005-c-class-sport-sedan-sway-bars-amg-sale.html
Old 10-05-2006, 08:47 PM
  #258
C320PO's Avatar
stock 2001 c320 sedan
Question about the ride difference
Originally Posted by Blake P
TEIN Basic coilovers with H&R sways should do the trick. What's your budget?
What kind of change did you notice about the ride difference between the stock setup and the Tein basic coilovers? Seems like with my budget, It's either the basic coilovers or the sway bars.
Old 10-05-2006, 08:53 PM
  #259
C320PO's Avatar
Old 10-05-2006, 09:10 PM
  #260
WaveyKat's Avatar
Something Slow
Yes Sir
Old 10-06-2006, 11:55 AM
  #261
Blake P's Avatar
'09 A4 S Line
Why not save up for a couple months and do both? Or, you can always do one now and one later! The ride is much more refined now. I always describe the ride on TEIN Basics as "comfortably stiff". Definitely not as cushy as the stock suspension, but much better handling and feel of the road. There is still some body roll on turns, but definite improvement over stock. Right now I'm saving up for H&R sways in order to further eliminate body roll. To be honest, my main reason for getting the TEIN c/o's was to get my drop just right. Improved handling was an added bonus.
Old 10-06-2006, 01:57 PM
  #262
C320PO's Avatar
Another question, sorry.
- AMG swaybars $150
OR
About lowering the car with the coilovers. Does lowering the car with the coilovers change the ground clearance as well? So some reason, a lot of parking lots I'm at has speed bumps.
I suppose it changes the suspension travel but the stiffer springs should reduce the likelihood of bottoming out. Correct?
Old 10-06-2006, 03:52 PM
  #263
drexappeal's Avatar
Lowering the car period changes the ground clearance. Full coilovers allow you to adjust the height and dampening, so that you can avoid this (certain partial coilovers allow height adjustment only).
Stiffer springs don't necessarily "guarantee" your car bottoming out. If you're running on stock shocks, it's still gonna allow the springs to compress/decompress everytime you hit a bump. Stiffer springs only shortens the amount of travel, but doesn't change the amount of dampening there is when the car hits a bump. That's why, when people lower the car with springs and keep the stock shocks, the shocks have a tendancy to go bad faster than what would be considered "normal".
Old 10-14-2006, 05:42 PM
  #264
bloodyhands's Avatar
2k1 c320, 2k5 wrangler, cbr 929
suspension
would the coupe w203 suspension fit a sedan??????
Old 10-14-2006, 05:54 PM
  #265
C240Style's Avatar
Mercedes is gone physically, but still in my heart.
Search the forums. It'll become your best friend.
Old 10-17-2006, 11:43 PM
  #266
c240 do u tell that to every1 that is looking 4 answers,i work 12hours per day trying to save pples lives,i be lucky if i get to post a thread and follow up on it 1s a week.... i,m not lazy; i just dont have time, it be gr8 if i get a yes/no answer,is that too much to ask.
Old 10-18-2006, 12:36 AM
  #267
C240Style's Avatar
I'm not trying to be an *******, I'm simply saying that in general it's easier to do that instead of posting a question that has been answered many MANY times. That's all.
Old 10-18-2006, 03:34 AM
  #268
SPORTCOUPE's Avatar
2003-c230K 2001-c230k sportcoupe - 1998 A190 - 2008 Smart Fortwo Brabus
I fit the H&R springs on my sportcoupe.
The ebay seller told me he purchased them for a sedan but never got around to install them...
No problems whatsoever with installation or ride...
Old 10-18-2006, 11:16 PM
  #269
thnx sportscoupe,and c240 im sorry,12hrs per day gives me a short fuse
Old 10-26-2006, 08:39 AM
  #270
WaveyKat's Avatar
Something Slow
Wow...glad you figured it out, cuz I looked all around and couldn't find anything wrong with my limited knowledge. Then again, I didn't know what to look for! Let me know what parts you end up ordering and I'll have to do the same. I figure I might as well change the arms on both sides while I'm at it.
Well i though i had it all figure out i had my Control arm replace for free at the Dealer the noise was gone for a few days then i started hearing the clunking again so yesterday i check it out myself again and i tighten the Sway Bar end links and the noise stop so all the clunking is coming from the end links it doesnt look or feel loose when the car is jacked up but i guess when the car is not jacked up the weight makes it jiggle around while driving causing the clunking knocking sound. i don't know why it keep getting loose am not sure if its because of the tein struts has a bigger hole where the links goes but i am going to double nut the end links and used some loctight on the weekend i let you guys know how this goes.
Old 10-26-2006, 12:23 PM
  #271
drexappeal's Avatar
WaveyKat. Same solution I had. When I tightened the swaybars, the knock/clunk went away.
Old 10-26-2006, 12:30 PM
  #272
Blake P's Avatar
'09 A4 S Line
Anybody have a picture of where I'm supposed to tighten and what tool I'll need to do it?
Old 10-26-2006, 12:35 PM
  #273
drexappeal's Avatar
B, in my case, it was just the rear. Just need to tighten the bolts that connect the swaybars at the end. Should only be 2 bolts (1 left, 1 right). I'd recommend an impact wrench.
Old 10-26-2006, 05:52 PM
  #274
Jweiss@carlabms's Avatar
make sure you guys check out our special on the spring and coilover. thanks
Old 10-26-2006, 08:21 PM
  #275
WaveyKat's Avatar
Something Slow
i was using a 16mm socket but the whole thing keeps turning and not getting tight this ***** drving me crazy.. i think i will just get the thicker endlinks and make the 10mm hole on the sway bar and strut bigger so i can fit the 12mm end link what yall think?
is there some sort of Special tools they use to tighten this i think i need the Female & Male Torx Tool set
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
Quick Reply: W203/CL203 Suspension (Shocks/Springs/Sway Bars) Discussion/Upgrade Thread
