W203/CL203 Suspension (Shocks/Springs/Sway Bars) Discussion/Upgrade Thread
#277
2004 C32 ///AMG
there is a new spring availible for the c-class
ZENN springs....1.2"F 1"R drop
http://cgi.ebay.com/ebaymotors/NEW-M...50172361QQrdZ1
#282
R129, XF Sportbrake, SC400
#284
1 Post
2005 C230SS
I have an 03 C230SS and the gap between the tire and wheel well is huge in the front (3 fingers gap). I was sitting next to a new C230SS today and noticed that it was approx an inch lower than my setup. Could I hypothetically just change out my 2003 springs with 2004.5 or later springs and get away with it or would I need the shocks too? Anyone getting rid of their stock setup?
Mike
Mike
#285
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Yes. You can change to 2004.5+ springs and the ride height would change. The shocks should be the same, but even if they weren't the same, that would only affect your ride comfort.
Another way to change the ride height in the rear is to change the spring pad. There are 4. Sport Sedans, I think, come stock with #2 pads.
#286
'09 A4 S Line
#287
It's possible that the shocks are different, but it wouldn't make a difference for someone going from 2003 OEM to 2004.5+. Anybody that is gonna do that, doesn't really need shock upgrades or changes until the shocks are shot.
#288
'09 A4 S Line
I agree, but I bet there are some folks (like me) who consider their OEM suspension to be worthless after upgrading to an aftermarket setup, so he could probably get a whole 04.5+ suspension for next to nothing. Hell, I usually end up leaving my OEM parts at the install shop for them to throw away or sell... whatever as long as I don't have to deal with it.
#289
#290
1 Post
2005 C230SS
I bought a set of 06 sport springs from a board member and should arrive Wednesday. I have never changed springs in a Benz so this will be a good learning experience. Had prenty of practice changing out suspensions on my GTI I used to have. Wonder if this will be similar. Did a brief search on how to install springs hoping to come across a good thread with pics, but came up short.
Also looked at the DIY stickies but none referenced actually changing out suspension parts.
When I install the springs, I will post measurements differences and pics for those who want to go this route.
#291
Super Moderator
#293
Super Moderator
#294
2004 CLK 500 Coupe; 2001 Ford F-450 4x4 7.3D 6sp 4dr
Thanks.
#295
Blake and WaveyKat (and Suman), Were you able to remove the klunking sound from your suspension yet? I have been dealing with the same sound for some time now, now at all 4 corners. I do have over 110,000 miles on the stock suspension and I am sure that I am due for some issues, however, I am really interested if your fix took care of the issue. Any directions for an IT guy who hasnt been under a car for a number of years, where and how to fix the noise? ie tighten the endbolts on the swaybars.
Thanks.
Thanks.
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
#296
-Eric
#297
Correct, not one change. I have had no need. Just oil changes, etc... OEM Front brakes at 75K, Panorma roof at 49.9K. Thats it. No issues, other than the klunking sounds. Sure, I have noticed taking a country road corner posted at 45, doing over 55(ok65) hitting a few bumps, the suspension is getting soft, however, that is to be expected with 110K on the struts. That will be my next question. Since I am going to need to replace some components, what is the groups sugestions to "inexpensively" upgrade the suspension. Ride height is fine, however it wouldnt hurt it to be down some, and it could be just a bit firmer.
-Eric
-Eric
If you want to stick with OEM, there are a few places online that would be great. I'm not sure if any of the sponsors offer OEM shocks for a good price, if at all. I would also try the website that a lot of people got the "new key" from. They have great prices (I've checked other parts on that site as well and it was much better than directly going to the dealership).
If you want to upgrade the shocks, my suggestion would be to go with KONI adjustable shocks. I think there is 3 settings on those shocks, but from what I've been told, the softest setting for the KONI's feels even better than stock and provides better dampening.
If that doesn't eliminate that "clunking" sound you are hearing, then you'd have to investigate into other "issues".
#298
'09 A4 S Line
Thanks.
Thanks.
#299
Now we are talking.
Blake thanks for your update as well.
To anyone, The reason that my suspension and brakes seem to have lasted so long, is that my commute is 65 miles each way, and only 2 stop lights, very light traffic.
Thanks all for your suggestions.
-Eric
#300
Eric,
Thanks for posting the question in the Suspension thread instead of starting a new one. You don't know how much smoother that helps the forum run (especially with the search function).
