W203/CL203 Suspension (Shocks/Springs/Sway Bars) Discussion/Upgrade Thread
Model: 2000 C240
Miles: 35.500 miles
Springs: Stock
Shocks: Stock
Wheels: 19x8.5-9.5 ET32 (I think)
Tires: Michelin Pilot SP2 235/35 - 265/30
Comments:
Driver only-> Major rubbing on the Rear Left while heavy right cornering. Minor rubbing on Rear Right while heavy cornering.
2 medium rear passanger-> Rubbing on Rear Left on bumps.
Model: 2000 C240
Miles: 35.500 miles
Springs: Stock
Shocks: Stock
Comments:
yes blake, be happy, by shocks need to be replaced, and like you always say, might as well go all the way.
Well, I am in the market for either...
Tein Basics
Koni adjustables with eibach springs
h&r cupkit/coilover
I'm running on the frank group buy double spoke amg reps, 19x8.5 front 19.9.5 rear with falken fk451 235/35/19 and 265/30/19.
However, I want the most minimal drop ever, perfer around 1 inch, a litle more or a little less, no more than 1.5" drop front AND rear.
I usually have 4+ people in the trunk, and I would not like the feel of rubbing. I also dont want to roll my fenders or do any sort of shaving. so...
any suggestions for this picky motherf-er?
Tein Basics
h&r cupkit/coilover
If you want the "perfect" ride height and comfort, go for fully adjustable coilovers (TEIN Super Streets and KW V2's will most likely be the least expensive).
From what it sounds like, you don't want much of a drop and if you never plan to show the car, you can always go with the Eibach or H&R springs and Koni Adjustable shocks. Just don't complain when it's not dropped enough for your taste. Considering you haven't dropped your car for all this time, I think you'll be happy with it. If you want to conserve on the amount you spend, go TEIN S-tech's with Koni Adjustable shocks.
No matter what you choose, just make sure you either have adjustable ride height or adjustable dampening or both.
Tein Basics
h&r cupkit/coilover
TEIN Basics is the way to go. It's affordable, and it'll let you adjust the ride height.
Ultraman206 was selling his brand new set in the classifieds: https://mbworld.org/forums/classifieds/213126-fs-w203-tein-basic-coil-over-damper-kit-brand-new.html
I'm considering two...I'm looking at koni adjustables+tein s-tech springs..its about $800
Tein Basics is about $750 and its more "adjustable" than the shocks/springs combo.
I am leaning towards a set of Tein Basics unless Gaston can get me a deal on the H&R c/o
if u r actually considering h&r coilovers, might as well get the tein super street cuz they are fully adjustable and around the same price as the h&r coilovers. h&r's are only ride height adjustable, so at that price, super streets are better bang for the buck.
any suggestion on wheres the cheapest?
Anyways, it's a matter of choosing between adjusting the ride height or adjusting the damper.
http://www.performanceproducts4benz....ame=Spring+Pad
In your case, B, you don't track your car or intend to, so there's no reason for you to need that type of setup. It's basically all up to the user and what they'd prefer. For me, I'd never get anything except fully adjustable coilovers just because I like having the option of doing whatever I want with the suspension.
Do you get a drop with H&R springs and stock shock? Does it affect the ride much? I like the way C55 rides (but i wouldn't mind it to be a bit stiffer), however i'd like to lower my car a little bit. I know i should consider a cup kit or coilovers, but i have a tight budget and i have other mods in mind right now (I'm also getting H&R sway bars). Is there anything i should be caution about (i.e. should i get #4 spring pads for the back)? Would you recommand cup kit over springs + sway bars considering look/performance/ride/$$$? Thank you
P.S. I have 19" Bremma with 265 width at the back, had some rubbing and rolled the fender already. Would i rub more if i lowered it?
Thanks!
