W203/CL203 Suspension (Shocks/Springs/Sway Bars) Discussion/Upgrade Thread
there are no "best brand" that's all in one's head. You can go with H&R, Eibach, RENNTech, Brabus, TEIN for springs.
how limited IS your budget? even the springs can range from $250-600 pre-install.
This made the rear much lower than the front (and of course, I forgot to take a good pic of it
) You can kind of see the rear wheels tucked under the wheel well about 1/4 ~ 1/2"
Picked up the 17mm spacers ( A 210 325 04 84 ) from my MB dealer ($8/each) to replace the 5mm ones I had stock. Brought it up level again:
Yeah it needs a good bath.
While I was under there I noticed the stock sway bar in the rear was kind of beatup so I replaced that with an H&R part as well.
Then did the fuel filter, spark plugs, cabin filter, flushed the tranny fluid, got it tinted & took off a dealer badge.
Oil change and flushing the brake fluid next!
Thanks for the spring btw.
I recently purchased a C32 and LOVE IT. However, I was looking on ebay and the C55 looks alot lower, and presumably from factory since all the ones on ebay looked lower in the front than the c32. I read the suspension posts and decided I want H&R sport and konis, until i saw the C55 stance.
Can I use C55 springs on a C32? How about the shocks? Would the entire strut assembly be swappable for a C55 strut/spring/shock? has anyone done it?
The curb weight for a c32 is about 40lbs less than a c55, so weight cannot be the reasoning behind the c55 lower front stance. stock handling is mas o menos but ive read on these boards that the c55 handles like a laser. also, what happens to esp if i lower my car?
thanks
you can have 4x4 stance, normal stance, c55 stance, lowrider stance + any comfort to stiffness setting you want compare to C55 all it got is 1
Can c55 springs and shocks fit a c32?
Guess there was too much tension/stress on it and it gave way
Here is the link to that page on Ebay that i bought the springs
http://cgi.ebay.com/ebaymotors/ws/eB...m=260277149398
And im gonna post some pics of the springs them self.
