W203/CL203 Suspension (Shocks/Springs/Sway Bars) Discussion/Upgrade Thread
Well, if it's just for a catalog photoshoot. Go with the TEIN S-tech's. It'll give you the most amount of drop for just springs and the most affordable brand new.
any idea how much itll drop my 07 sport sedan on the stechs?
Whatever it says the drop is for a 230K SS on the website is pretty much what it would be for your car. My car was the R&D car for the 230K SS and I had updated sports suspension for 2004.5, which was maybe 1/8 inch higher than your car currently at most.
But the springs are definitely different. They tested the prototype 320 springs on my car and the front looked like I was about to take off compared to the OEM sport springs.
They wouldn't know the answer to that because the R&D on it was done before the v6 230 came out. I mentioned that above also.
Okay, so to go over it 1 more time, once and for all, no repeats:
2003-2005 vs. 2006-2007
- weight distribution is very similar (very small change if any)
- mounting points are same across all chassis (possibly not the c55 - but not positive on this)
- Only reason the 230 vs. 320 was WEIGHT distribution and 320 was heavier (obvious reasons), therefore different parts for heavier v6 engines. And yes, the 320 is heavier than your v6 230.
Okay, that should eliminate anymore doubt. If you want more answers, search for the TEIN thread that I had started way back when I first did R&D.
Again, I mentioned this in another thread - Last time I went into TEIN to have my prototypes adjusted, they mentioned that the compatibility between the 230K coupe, sedan and 230 v6 model should be the same. The heavier v6 (320, 350) should be the same.
OE W203 dampers are essentially impotent for any spirited encounters. When higher rate or reduced ride height springs are factored in the performance equation, we’re even more SOL.
If only one could install a prepped E46/92 M3 suspension on an AMG…
crazy question:
w209 and w203 share the same suspension, right? I know the brakes can be swapped over, but can CLK 63 black series suspension be swapped over? :x
Adding the CLK Black series suspension (if at all possible), wouldn't change the body dimensions/wheel wells of the w203, so you'd still be subjected to the same setups for width.Like Blake said, only way to increase the width would be to go widebody.
