W203/CL203 Suspension (Shocks/Springs/Sway Bars) Discussion/Upgrade Thread
#951
Here's a good article on sway bars.
http://www.stealthtdi.com/SwayBars.html
It was after reading this I went with a bigger rear bar.
Before you do anything, measure the existing bars.
I would swear I read somewhere the AMG bars were included on the wagon.
Then you need to decide, is the car understeering, or oversteering.
Mine was understeering terribly, always did. If I went into a curve hot,
at times I would turn the wheel, and it would just kinda....like not turn!
I had to set myself up for the turn slow down, and throttle thought it, to bring the **** around.
Going uphill was fun, downhill, scary!
After the thicker rear bar, I just...turn! The tires grab...it's a beautiful thing.
The final piece that really completed an otherwise frustating expenditure of
nearly 2 grand on suspension, at least until I put the thicker rear bar.
For certain they were included in the facelifted SS230 and Coupe 2005+.
(Facelifted)
For me, I don't want any thicker.
Sway bars prevent your independant suspension from acting independantly.
Which can be good....or bad.
As I have VERY stiff springs, I don't need no stinking 26mm front bar.
Way overkill for the coupe, with CO's.
As I said, I think the 22/19 combo is great for the coupe.
Reason being, MB never saw fit to tune the suspension for the coupe, just put whatver they put on the sedan with no thought.
The coupe doesn't have all thatweight hanging out in the rear.
The center of gravity is more forward, and the roofline + pano put more weight close to or just forward of the rear axle.
You gotta decide for yourself what you think the wagon needs.
I had a 2005 sedan loaner, I thought it handled pretty well right from the factory. Updated springs, and thicker bars.
(Facelifted)
#952
1 Post
'02 C320 Wagon
Then your balance is neutral, and you should increase the sway bar size by an equal percentage at the front and rear of the car, if you want to keep that behavior.
I think I explained myself better above, but what I meant was don't go out and buy a huge bar for just one end and leave the other end stock or near stock.
#953
MK IV .:R32
the article was good though thanks
So I'm think AMG Front with the H&R Rear now...
#954
2013 ML350
Spring Pads Not used with Coilovers???
Hey folks, Been on a few mos. STFFing, but need to confirm an item.
I will be installing H&R Street Performance Coilovers on my 04 C240 wagon soon.
Did i read/understand correctly that you do not use the rear spring pads with coilovers?
If someone could confirm that, i would appreciate it,
Thank, Greg
Thank, Greg
#955
'09 A4 S Line
Thank, Greg
Thank, Greg
#957
PN's for AMG bars (possibly superceded)
Not sure which is front or back...
2033233165
2033231565
Bushings
2033232285
2033230081
2033233165
2033231565
Bushings
2033232285
2033230081
#958
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
#959
MBworld Guru
white and whiter
if you want a little more oversteer go with Eibach, if you want to just improve the stock handling go with H&R which is setup more like the stock to produce understeer. Or you can go with AMGs which you can usually find them used off member's C32 or 55.
#960
I have the Eibach front and rear. Check it out here at DriveWire.com:
http://www.drivewire.com/products/me...way-bars/6343/
I am very happy with the setup, and the price is really good if you get the front and rear together.
#961
MBworld Guru
white and whiter
#962
MK IV .:R32
I want to get less body roll and some better handling BUT I WOULD LIKE TO AVOID UNDERSTEER AT ALL COSTS
should I go for the Eibachs or with the AMG front and H&R Rear?
that is a good price for the set. I searced for my car though (2005 c230) and I didnt find them.
They should fit right?
#963
05 c230 kompressor
i need help guys, i lowered my 05 c230 and started to hear a noise coming from the front when coming to a stop or going 0-20mph like a weird road noise and i would feel little grinding through the steering wheel. i have the H&R coilovers, so i lifted it back up and it went semi-away. does anyone know what this can be? thx in advance for any help
#964
1996 MB E320 & 2010 Nissan Elgrand
#965
'08 CLK320CDI AMG// '13 E500 Coupe AMG// '17 E350d AMG
Problem with lowering!
Hi all,
I have a problem in my car (C coupe) after installing eibach springs and koni sports, the front rigth side of the car is lower in 1cm than the left side!
The rigth side (lower) is the correct hight, and I allready changed the springs for the other side (rigth to left and left to rigth) but no changes!!! :dunno:
The only difference I could see is alignement, the rigth wheel is 1cm ahead than the left one (more 1cm of wheelbase on the rigth side) but my tyre guy says it have nothing to do with alignemt!!
Meanwhile I istalled eibach springs in my brothers car ( C coupe also) but with stock shocks and the car sitts correct!!!
Any one have more ideas!? :hmm:
#966
'02 CL203 M111
How long have you had them ?
Maybe you just need to drive it for a while so the suspension will settle down evenly.![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
On the other hand 1cm higher in't dramaticly much...
You probably want to post in the suspension thread if you want helpfull answers.
#967
So it's the shocks then?!
I actually have the same problem with Tein COs. The rears are all the way down, but both sides have different heights.
It could be the springs pads that I left in there tho in my case. I was told springs pads have to be removed when installing COs.
#968
'02 CL203 M111
#969
At the rear its all ok, spring pads are allright but only at front there is this problem!
I will take some pics of my car and my brother.
#972
1 Post
'03 C320 Sedan, '04 SAAB 9-3 Cabrio
Sorry if this is a stupid comment, but are you guys sayimg the AMG sways are a straight bolt-on to the 203 sedan or coupe? Does it make sense then to just go to the dealer and have one or both installed? I am thinking to reduce body roll without going to a hard-riding setup so the 16mm AMG rear seems like it would give me a slight improvement.
Dom
Dom
#973
I still don't know what the shim is but, its any of these parts?
![](http://www.roadraceengineering.com/3g/howto/koni/koni_instructions10.jpg)
PS: if is missing something, isn't better to remove the other one!? this way I get the car lowered more, as it look better![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
Also... anyone cuted the bump stops? its needed?
#975
Dom
Dom
