W203/CL203 Suspension (Shocks/Springs/Sway Bars) Discussion/Upgrade Thread
#1001
2013 ML350
Mike, check out www.shox.com They had the best deal on H&R Coilovers for my wagon.
#1002
03 g35 coupe...........02 c32 Sold
if your going to get coil overs...don't get the hr coil overs. They have no damper adjustment so you might end up in the same situation as you are now. You should get the tein SS or kw variate 2, both have damper and height adjustment.
If your happy with your current drop, then i would just get the koni's since you already spent the money on springs.
#1003
2013 ML350
#1004
Location: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
Looks good ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
![](https://mbworld.org/forums/attachments/c-class-w203/140793d1223163429-w203-cl203-suspension-shocks-springs-sway-bars-discussion-upgrade-thread-cimg5423.jpg)
Is the RENNtech suspension adjustable ? I don't remember, since it was so long I was looking into it.
If it is, I would try to see if they can bring the front down just a hair more.
But that's up to you and the ride quality.
What type of shocks does the RENNtech suspension use ?
Carlos
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
Saprissa@aol.com
Carlos
Saprissa@aol.com
#1005
![Lightbulb](https://mbworld.org/forums/images/icons/icon3.gif)
so i was researching and is it true that the tein basics for the C230 Kompressor Sedan the drop height is only = F:0.4~1.3" / R:0.3~1.5")
i'd be better of getting h&r springs and cutting 1/2 a coil...(1.4 Front / 1.3 Rear w/o cut)
any help cuz i want that slammed look... id prefer the coils so i can raise during winter....
also would i be able to get a proper alignment w/o cambers???
thanks thanks thanks!!!!![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
#1006
MBworld Guru
white and whiter
i have the TEIN SS. same height adjustment range as the basic.
here's my ride height (front can go down another 1" and half) (rear can tuck the tires if I want to)
and no you can't get proper alignment without camber kit or arm.
![](https://farm4.static.flickr.com/3276/2911076180_dd024b8388_b.jpg)
#1007
Frank, can you tell me more about the alignment? Is the dealer still able to do your alignment? Do you just get it 'close'? What's the deal? I can't imagine you running around with ~400hp out of alignment.
#1008
2004 C230K
im planning on cutting half a coil on the front since everyone is telling me that it sits high up front. And also i have stock shocks and i dont know about the rear would it be alright with stock and whats up with a number 1 pad in the back is it lower if i had stock pad on the back or if i have a number 1 pad on the back if so where can i get this pad thingy?
#1012
MBworld Guru
white and whiter
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
I've only had alignment done once and that was when I had the RENNtech springs.
didn't bother doing alignment afterward because the car tracks straight, tire wears very even, and no abnormal wear. all the bushing wear and everything else was checked regularly, so I never had another alignment done. probably will do one soon enough.
#1013
You can get them from your dealership.
#1014
its better to give coil overs then springs. Keep in mind the weight of the car isn't distributed perfectly, given its a sedan and it costs money to design a car with perfect weight distribution.
The driver side is going to have more weight then the passenager so the driver side is going to be lower then the passenager side. With coilovers, you can compensate for the difference in heights and have the same drop all around.
1'-1.5'' isn't really a big enough drop to throw off the alignment specs much. You will have more negative camber, but shouldn't eat your tires much faster then oem specs long as you get a alignment.
Its always recommended to get alignment any time you touch your suspension. Alignments are cheaper then new tires.
#1015
1996 MB E320 & 2010 Nissan Elgrand
Daiso, go with COs man! I've noticed many used low mileage COs for sale right now in classified.
DO IT! and Go RAPS!![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
DO IT! and Go RAPS!
#1016
when i had my civic at the lowest tein settings it cambered bad and my tires only lasted one summer.... really dont want to buy new 19" tires every summer
nibo i wont lower my car until spring cuz im under warranty until nov so it wont make sense to lower it for winter.... i think im gonna buy brand new tein COs cuz on k1motors they go for less 900 brand new!!!
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
#1018
Moderator Alumni
so if get the COs and drop it at the lowest settings i can get a alignment at a local shop without camber kits???
My rear tire wear has been good considering that I didnt really deal w/ my rear camber until recently - you can tell the tires were eaten up on the inside more than the outside, but nothing too dramatic. Front tires look like they have even tire wear and my camber up front has been about -1.7 since I lowered the car.
Hope that helps. I imagine if you go lower in the rear with any coilvoers, you will have to buy new tires often or get a camber kit. Id suggest the second
#1019
2004 C230K
so should i get a spring pad #1?
or ill be alright with just the springs with the stock shocks with regular pad on the rear?
can someone explain to me whats the difference having a Spring Pad #1 on the back and having a stock pad
#1020
yup its similar to what trutaing said. Whenever you lower your car you will always have negative camber unless you get a camber kit. The alignment shop be able to align it pretty close to oem spec.
it will eat your tires faster then oem, but it shouldn't be too bad.
#1021
I think it's been 3 years now if not mistaken.
I see, next year it is then
#1022
I'd stick with stock pads if you run H&R springs since you'd have bigger gap in the fronts compared to the rears with these springs
You could cut the fronts if you want to go lower and change the rear pads to thinner pads
Not sure what pads do you have in your SS suspension. It was pad no 4 in my 2002 non-sport C200
#1024
And I'm pretty sure W203 and W210 are using the same pads
#1025
to me when i drove my civic with - camber i could hardly tell the difference(cornered alot better w/ less body roll) but my buddy told me driving a car w/ -camber is dangerous and i shouldnt do it .... is he right or just being a p***y???
