W203/CL203 Suspension (Shocks/Springs/Sway Bars) Discussion/Upgrade Thread
Rating: Thread Rating: 6 votes, 5.00 average.
Old Sep 29, 2008 | 04:20 PM
  #976
shivi1345's Avatar
MK IV .:R32
They'll likely feed you a huge line of crap as to why not to do it.
haha ya I can imagine
btw I just thought of this.....
the sways on the C55 are different from the ones on a C32, right?
Old Sep 29, 2008 | 06:35 PM
  #977
JLD2k3's Avatar
2002 C320
Originally Posted by shivi1345
I really don't understeer like at all. I know that is really wierd, but I LOVE IT (obviously)
I want to get less body roll and some better handling BUT I WOULD LIKE TO AVOID UNDERSTEER AT ALL COSTS
should I go for the Eibachs or with the AMG front and H&R Rear?
that is a good price for the set. I searced for my car though (2005 c230) and I didnt find them.
They should fit right?
They will fit. There is some issue with the 4-matics, but that is the only problem. The kits should come with the correct size bushings and grease for the bushings, so that should be all you need.
If you are trying to avoid understeer at all costs, go with the Eibach rear and the stock front. This will give you the greatest tendancy toward oversteer. However, you might just overdo it. This is why I went with the complete Eibach kit (tempting to go super beefy with the HR front and Eibach rear) as I felt it gave the best balance for what I was trying to achieve (smooth turn in with a very willing 'dive' feeling at times).
Good luck, and do it yourself. Have fun getting the rear out around the exhaust.
Old Sep 29, 2008 | 07:02 PM
  #978
Hokie1200's Avatar
2004 C230 Kompressor Sport sedan 6 speed manual, 2013 S550 Sport 20" AMG
I think the spring pad (shim) is under the spring in the front. If you jack up the front, you should be able to see the spring and the pad underneath.
There are also 4 pad thicknesses: 8, 13, 18, and 23 mm. So if you have a 8mm on one side and a 23 mm on the other, that's 15 mm (or 0.6 inches) difference.
Hope that helps.
Old Sep 29, 2008 | 08:14 PM
  #979
gaiex's Avatar
'13 E500 Coupe AMG// '17 E350d // '24 E53 AMG
Hope that helps.
This shims I get them from Koni dealer rigth?
I have to look it better, I never noticed this diference! The shocks allready came with the shims
Old Sep 30, 2008 | 12:10 PM
  #980
ShockerRacing's Avatar
2005 Corvette, 2002 MB C230 Coupe
Replacement front springs
I was just replacing the front brakes on the wifes C230 and I realized that the passenger side front spring is cracked. I am wondering the best place to buy a new set of front springs is without having to pay Mercedes prices. Any suggestions?
Old Sep 30, 2008 | 12:26 PM
  #981
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
I have an extra set of springs.
Already off the car.
E
Old Oct 1, 2008 | 11:04 PM
  #982
Mr_DO's Avatar
2004 MBZ C230 Kompressor sedan
Shocks and Struts
Hello,
I was thinking of buying KYB GR-2 struts and shocks for my 04 C230 sedan but they only have these struts and shocks available for a 03 C240. My question is, would this set fit my car? Any ideas?
Old Oct 2, 2008 | 02:40 AM
  #983
spyderpig's Avatar
'02 CL203 M111
Did you check how the springs sit in the shim? Check top and bottom of the spring see if it sits in properly. rotating it a little bit might help.
Old Oct 2, 2008 | 03:22 AM
  #984
pogijeffrey's Avatar
05 c230 kompressor
funny.. i had the same freaking problem. i had my teins cut and after driving it a couple days, the car sits lower on the passenger side towards the front. what could that be. i complained about it to the shop. i thought hey had cut them unevnly. and i know they wouldnt do that. so i said f(*k it. i"ll just put my h&r's that i originally had cut back on. i looked at everything. everything seems fine. i it looks like i have more of a camber in the front passenger side.
Old Oct 4, 2008 | 12:35 AM
  #985
Mikegpr03's Avatar
C63
if your wheel is more forward than another wheel then you have a caster issue. My car had the same issue I had my HR's on the front cut by 1/2 coil and the car's front right wheel was off (caster wise) I went to a shop here in miami,fl and they corrected my caster and camber aswell. Do you have a drift to the right?
Old Oct 4, 2008 | 12:46 AM
  #986
Mikegpr03's Avatar
C63
Best shocks for W203 with lowering springs
Gents what shock do you use/recomend that will give me a good ride. I lwered the car with Hr springs but I 'm getting a very hrash ride.The shocks feel worn. ??koni? kyb? bilstein? anyone with some good data please chime in
Thank you
Mike
Old Oct 4, 2008 | 12:48 AM
  #987
rocafel1a's Avatar
05.C230K.SS
i think h&r spring/koni shock combo is pretty common...
Old Oct 4, 2008 | 01:13 AM
  #988
CoupeCrazy03's Avatar
2003 C230 Kompressor Coupe, 2003 E320, 2003 Chevy Corvette Z06
I have Koni's with eibach springs on my E-class and I have to say . . . Koni FTMFW
Old Oct 4, 2008 | 03:19 AM
  #989
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
i think koni's are better for street and blistein is better more for the track.
Old Oct 4, 2008 | 10:15 AM
  #990
coin's Avatar
'06 CLK500
Get my coil and sell your spring.
Better look, better handling and height adjustable
Old Oct 4, 2008 | 05:22 PM
  #991
Mikegpr03's Avatar
C63
ok io guess Koni is the way to go if I stay with my springs. Whats a good price to pay for then and where should I buy them @? I tight on cash so I need my $ to go farther. Also I was wondering on the ride quality of the hr coilovers.
Old Oct 4, 2008 | 05:23 PM
  #992
Mikegpr03's Avatar
C63
My car's ride sucks right now. I hate going over the smallest bump
Old Oct 4, 2008 | 07:38 PM
  #993
TuneTime's Avatar
Former Vendor
Any AMG Thats Around..
C Coupe with RennTech Suspension done today
Just added a front and rear RennTech Suspension kit to a C Coupe. Here are some nice pictures of it!
Attached Thumbnails W203/CL203 Suspension (Shocks/Springs/Sway Bars) Discussion/Upgrade Thread-cimg5422.jpg   W203/CL203 Suspension (Shocks/Springs/Sway Bars) Discussion/Upgrade Thread-cimg5423.jpg   W203/CL203 Suspension (Shocks/Springs/Sway Bars) Discussion/Upgrade Thread-cimg5424.jpg   W203/CL203 Suspension (Shocks/Springs/Sway Bars) Discussion/Upgrade Thread-cimg5425.jpg   W203/CL203 Suspension (Shocks/Springs/Sway Bars) Discussion/Upgrade Thread-cimg5322.jpg
Old Oct 4, 2008 | 09:19 PM
  #994
saer1one's Avatar
2002 c32 AMG 2012 c250 Coupe
i had RENNtech springs installed a couple of weeks ago on my c32, i didnt feel a difference from the stock springs to RENNtech springs and i hope it stays that way. but it was the perfect drop with the stock suspension feel. not bounsy at all
Old Oct 4, 2008 | 11:43 PM
  #995
Tangerine's Avatar
Is @ Home
Thank you
Mike
I think that would be the springs at fault and not the shocks. If your shocks are worn/damaged they should not be able to dampen the bounce. Try the bounce test and/or check for any leaks.
Old Oct 5, 2008 | 12:43 AM
  #996
Looks good
Old Oct 5, 2008 | 12:47 AM
  #997
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
horrible place for that rear badge, but nice suspension.
Old Oct 5, 2008 | 03:27 AM
  #998
pshek's Avatar
2003 C-Class Sportcoupe
+1. Too many badges makes it look like it got tagged.
Old Oct 5, 2008 | 08:08 AM
  #999
advans's Avatar
C55 ///AMG, 535xi
c coupe ftw.
auto addiction in NY eh? I gotta drop by and visit.
the badges should be removed. the amount of badges on that car is enough to lower it!
Old Oct 5, 2008 | 08:43 AM
  #1000
Mikegpr03's Avatar
C63
I don't have a bounce and no leaks on all 4 corners. But the shocks have lost the ability to dampen (take the edge off) certain bumps. I'm not expecting a sedan deville but you can tell the shocks are not to par.
I regret getting the hr's and not coilovers from the start. I'm concerned that the hr coil overs will be a harsh ride aswell. I'm at a fork in the road and I wish I knew where to go from here...New shocks...or new coilovers...but which ones..?
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
