W203/CL203 Suspension (Shocks/Springs/Sway Bars) Discussion/Upgrade Thread
On the other hand, for maximum straight-line acceleration, the greatest traction will be attained when the camber angle is zero and the tread is flat on the road.
The driver side is going to have more weight then the passenager so the driver side is going to be lower then the passenager side. With coilovers, you can compensate for the difference in heights and have the same drop all around.
1'-1.5'' isn't really a big enough drop to throw off the alignment specs much. You will have more negative camber, but shouldn't eat your tires much faster then oem specs long as you get a alignment.
Its always recommended to get alignment any time you touch your suspension. Alignments are cheaper then new tires.
So I guess put a fatter pad if the front is too high?....to like even it out??
I'd stick with stock pads if you run H&R springs since you'd have bigger gap in the fronts compared to the rears with these springs
You could cut the fronts if you want to go lower and change the rear pads to thinner pads
Not sure what pads do you have in your SS suspension. It was pad no 4 in my 2002 non-sport C200
oic i guess ima go get a rear spring pad #1 and as for the front im cutting half a coil up front
I do know one thing, you can't raise the front that much in winter time. The rears you could, not the front. You have 17s for winter, so it should help
I have 16s for winter and it was still too low even after I raised my fronts all the way
I think your SS shocks would be strong enough for aftermarket springs. Non-sport shocks would be a different story. I had Eibach and 19s with my stock non-sport shocks and it was just plain limo bouncy
Someone is selling SS Tein COs in classified! Do it now
You want the damper adjustment, so you change the shocks to soft for comfort and stiff for sport. Shocks can compensate for the the stiffer spring rates to a degree.
usually with just lower springs, the stock shocks are not designed to ride with the lower ride height and stiffness. Hence the oem shocks tend to wear out faster with lower springs.
if your car has a lot a mileage and you need to replace the shocks anyways. make sense to buy coilovers so you can replace the whole thing while the car is apart.
Lowering your car helps with looks, but also helps with the handling. The lower center of gravity will allow you to corner faster and put less stress on your tires when your cornering at high speeds.
There's more, but thats the basics.
The only way to allign rears for camber is by installing a camber kit.
Peter
now i know i want tein ss or h&r coilovers.... more expensive but it would seem its the best of both worlds.... height adjustable, and damper( so i can set it to soft and it will feel like oem, but lower?)...
nibo i really really want to buy right now but i gotta save some cash
cuz i would rather buy brand new cuz with used you really dont know how many miles are one them even if they claim only a few.... unless i see some used bilstein cuz i think they have life time warranty on shocks....
cuz i would rather buy brand new cuz with used you really dont know how many miles are one them even if they claim only a few.... unless i see some used bilstein cuz i think they have life time warranty on shocks....2004 C240 Wagon
H&R Coilover - Street Performance Part # 29367.2 Specific to wagons 02-04 model years
Set to about 3 turns from lowest setting
Wheels=TSW Croft 18x18 32 et Front 18X9.5 35et Rear
Tires = Falken Ziex 512 225/40/18 front 255/35/18 rear
Comments: ~ 1/4" clearance between back of tire and coilover perch on front. Rears clear with 255 tires. As many have said on here- good luck with 265's.
Is the Bilstein Heavy Duty or Sport the way to go?
Then, How does the answer to the above compare versus the Koni Sport?
Based on previous posts I lean toward Bilstein, but I'm not sure if HD or Sport is the way to go because most of the threads do not distinguish.
Thanks,
JLD
SPORT (S)
For the performance-minded driver, Bilstein “Sport” shocks deliver absolute mastery of the road surface. Designed to push a car’s suspension to it’s performance peak, these shocks are well suited for use with special springs, antisway bars or other suspension upgrades.
HEAVY DUTY (HD)
For most vehicles including full-size sedans, SUVs and trucks. These shocks provide improved handling and stability without sacrificing ride comfort. They offer super damping ability that makes them ideal for heavy hauling for occasional off-road use, while maintaining an exceptional “street” ride.
So the SPORT makes no mention of 'without sacrificing ride comfort' but the HD seems more suited to larger vehicles. I never go off the road or haul anything. SPORT might make more sense, but I worry that the ride comfort may suffer. Anyone with experience with both?
I'm getting H&R springs to lose the bouncy feeling tho..
Havent been on this forum in a long time, good to be here again. I would like to raise my 02 C240 back up again a bit and would like to locate some late model C230K Springs to do so (the C240 Stocks are too high).
I have Eibach Pro Kits on my car right now and am willing to do a straight swap or pay you for your stocks. I am in the Bay Area so I can pickup or ship UPS Ground to the Lower 48 at no charge.
Thanks again!
EDIT: looks like a preliminary search shows that coupe and sedan springs are interchangeable, though Eibach lists two differing springs for C240 sedans and C230 coupes...
Where approximately in the Bay Area are you?
