W203/CL203 Suspension (Shocks/Springs/Sway Bars) Discussion/Upgrade Thread
Rating: Thread Rating: 6 votes, 5.00 average.
Old Oct 17, 2008 | 08:36 PM
  #1051
K9ff's Avatar
08 E63
I think they are different... from my research many many moons ago... ahha
I am all over the Bay Area; from SJ to SF to WC... got it covered =)
Let me know if you do find that they are interchangable. Thanks!
Old Oct 19, 2008 | 05:39 PM
  #1052
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
If for some reason you guys don't work something out, I have some Stock Coupe springs from a 2002. I'll happily trade you. However I'm in So Cal.
If you want to buy them, I'd take $50 and you pay shipping.
E
Old Oct 19, 2008 | 09:01 PM
  #1053
Andonixxx's Avatar
SL450
would they fit a 2006 c230?
Old Oct 24, 2008 | 02:46 AM
  #1054
SA C-Class's Avatar
'04 C 200 Kompressor
More Coilover Woes
Just thought I would throw this out there, just incase anyone else had a similar issue and can offer advice or to let the guys know that wanna fit H&R coilovers to keep an eye out for a similar issue...
Had my coilovers fitted a couple of months ago and had my ride height set... one day decided to take off the 19's and play around with the ride height to see exactly how low I can go... was busy on the passenger side and seen as I could not go much lower than what the ride height was set at the shop, did not bother with the driver side...
Wednesday i decided to put on my std (15") wheels, which has 31 offset and is a 6J wheel so there should be more than enough clearence for the coilovers and wanted to see how low I could go...
Passenger side... turned the coilovers all the way down... now problems looks major cool... Driver side... could not loosen the spring perch... no matter what I tried, they were stuck... ended up half stripping the teeth on the lower (smaller) nut... now with my luck, they probably gonna tell me it's my fault and I probably have to buy a whole new front strut...
Should probably have gone with the TEIN's or even the freekin (Taiwan) D2 coilovers...
Old Oct 24, 2008 | 12:01 PM
  #1055
rocafel1a's Avatar
05.C230K.SS
hmmm...i would actually think h&r coilovers are reliable and dependable...wow...
Old Oct 24, 2008 | 03:42 PM
  #1056
Synergy001's Avatar
05 C230 Sedan
did you spray it with WD40 first? probably dirt got stuck in the threads...
Old Oct 25, 2008 | 02:06 AM
  #1057
SA C-Class's Avatar
Yes I did spray with some Q20 (supposed to be similar to WD40) but will try WD40 to see if it helps... Also thought the H&R should be brilliant quality but the spring perch and lock nut material seems a bit weak to me... like I said stripped of the 'teeth' on them... looks like I am gonna have to try and buy new ones at least...
Old Oct 25, 2008 | 04:54 AM
  #1058
Glyn M Ruck's Avatar
Super Moderator
They both have the same Lubrizol concentrate in them so should not make any difference.
Old Oct 25, 2008 | 06:47 AM
  #1059
SA C-Class's Avatar
Thank you sir... you know much more about this than most of us do... in your opinion, do we have any products available in SA similar to PB Blaster or at least what would be the best penetrating lubricant we have available here...
Really appreciate your advice...
PS just so by the way... if you are interested or at least aware of anyone else interested... I have a set of Eibach springs available (Free to good home)... they were in the car for about 6 months or so
Old Oct 27, 2008 | 10:30 PM
  #1060
K9ff's Avatar
08 E63
Thanks for the responses, but i actually need the sedan springs off the c230...
willing to pay for them or swap with my pro-kits.
thanks!
Old Oct 28, 2008 | 01:56 AM
  #1061
kirax2's Avatar
I drive a Toyota Hybrid...
so u want 05+ spring?
i have 02 stock coupe spring and shock with only 20k miles
Old Oct 28, 2008 | 03:38 AM
  #1062
shivi1345's Avatar
MK IV .:R32
I have an '05 sedan...PM me
Old Nov 2, 2008 | 01:54 AM
  #1063
ThA5oLuTiOn's Avatar
Mercedes-Benz & 11sec. All Motor Honda
'04 C230K HELP ON SUSPENSION SETUP
Hi everyone, Im new to this site and i have an 04 C230k sport, is really great i found this website with alots of information towards my car.
First thing i wanna do to my car is, put some nice suspension setup on my car but im stuck between "Teins basic damper" or "Tein super street" suspension setup. I really want my car to ride smooth on some 19s inch wheels or if any body could help me pick better suspension setup,advice or opinion please feel free and tell me. I would really appreciate very much, Thank you.
Old Nov 2, 2008 | 02:57 AM
  #1064
kirax2's Avatar
Tein basic would do the work just perfectly + height adjustable too
Tein SS is just basic but has another "stiffness setting" like the sleep number bed
how much difference were they?
if like under 300 then i might just go for SS
if is more Basic will do the work perfectly
Old Nov 2, 2008 | 01:30 PM
  #1065
Thank you for your response back, I appreciate your help.
The retail prices on the suspension setup is...
Basic damper=$1250.00
SS=$1660.00
The difference is $410.00, you think is just worth getting SS besides the Basic damper?
Old Nov 2, 2008 | 03:44 PM
  #1066
kirax2's Avatar
SS=$1660.00
wow i guess Tein raise the price.. before when i still have my coupe, i saw Basic are only going for 800-900 brand new... well for 1660 is not worth it, if you just want some look and ride quality just go for basic
SS is kinda too much because they are kinda close price to Bilstein PSS9 (what i have on my coupe)
http://www.tirerack.com/suspension/s....H0&perfCode=P
Old Nov 3, 2008 | 12:50 PM
  #1067
Thanks for the link...Bilstein PSS9 setup looks good too. Yes Tein raise up the price on almost everything... I guess im going with Basis setup then, Thanx for your help and advice.
Old Nov 3, 2008 | 02:13 PM
  #1068
TruTaing's Avatar
Moderator Alumni
w203 m112
Those are some REALLY high prices for tein products.... Im pretty sure you can find them for 300+ less brand new from some of our sponsors...
Old Nov 3, 2008 | 03:22 PM
  #1069
MBZAMG32's Avatar
02 C32 AMG
You can get H&R coilovers for $1200 on tirerack.
Old Nov 3, 2008 | 04:33 PM
  #1070
vectorz's Avatar
2005 clk320 cabriolet
CLK (W209) shocks on C240 (W203)?
I just bought a '05 CLK cabriolet and the smoothness is far better than my C240. I'm wondering if I can get CLK shocks/springs and install them on my C240. Anyone know?
Old Nov 3, 2008 | 07:06 PM
  #1071
Can you please tell where, i could get them cheaper please. If you dont wanna say it public just pm me if you can, Thank you. I also wanna thank you for the help on the prices, because here in Olando FL is really bad with $$$ right now.
Old Nov 3, 2008 | 07:07 PM
  #1072
Would H&R coilover would give me that good look and ride quality?
Old Nov 3, 2008 | 08:27 PM
  #1073
TruTaing's Avatar
Moderator Alumni
w203 m112
H&R COs are probably known to be the softest COs for the w203. In other words, probably the most comfortable
I bought mine from CreativeAutoworks a few years ago. Im sure if you check out the forum sponsors, you could still find find basics for under 900 and SSs for around the same price as H&R COs.
Old Nov 3, 2008 | 08:41 PM
  #1074
So i will be looking more into the Teins setup. Im going to look around in the forum sponsors thread, hopefully i find something. I will let you know the results Thanx.
Sorry but, Im new to this website. Where the "forum sponsor thread" at? or if you could give me a link for it...
Old Nov 3, 2008 | 09:44 PM
  #1075
coin's Avatar
'06 CLK500
Fitment-wise, yes they'll fit ...
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
