W203/CL203 Suspension (Shocks/Springs/Sway Bars) Discussion/Upgrade Thread
Rating: Thread Rating: 6 votes, 5.00 average.
Old 07-31-2009, 12:08 AM
  #1226
d1no's Avatar
05 c230k 6spd
i went to walmart and bought a air impact gun and got all the bolts off easy when i was installing my springs.. it was like 25 bucks but you will need an air compressor to use it idk about the electric ones.. prolly not strong enough
Old 07-31-2009, 12:13 AM
  #1227
rocafel1a's Avatar
05.C230K.SS
yo webber, what new suspension are you installing? no more eibachs?
Old 07-31-2009, 03:06 PM
  #1228
Malsor13's Avatar
2001 c240
i have the same problem. my rear left side is rubbing on the tire. im thinking it either has to be the shock or the coil. so im thinkin about just replacing both. probably getting the oem springs and bilstein sporty heavy duty shocks. anybody have any experience with this or any thoughts? and anywhere to get the coil springs besides the dealer that dont lower the vehicle? also been trying to search but is there a diy on here?
Old 08-01-2009, 01:56 AM
  #1229
jayton41's Avatar
05 C55 & 06 C230 SS
Originally Posted by XsuperbeeX
+1
Jayton:I can take you on any day on your c230 you idiot... no offence to the other c230 owner... dont take to me to use your DADDY'S c55... =.= + I DIDNT BUY THIS COUPE... I would get an evo... even so the coupe has grown more than before...
y because u have a bigger engine !!! no duh idoit btw according to ur mods list ur car is a ricer ..infact its the exact defenition of a ricer ... if u dont know wat it means look it up ...u havent don 1 power mod to ur car and ur over on my posts tryin to tell me **** dude honestly stop sweatin ya self because ur a nobody cuz
Old 08-01-2009, 02:01 AM
  #1230
jayton41's Avatar
05 C55 & 06 C230 SS
Originally Posted by BigBodyBenzC240
Resurrecting a 2 week old post to start some beef. Just let it be. If anything let your car talk for you with how it looks/performs!!
dont worry about it cuz ..its solved yo i gotta ask u... i notice that my c230 has kind of bad throttle response..how mush in a scale of 1-10 does the sprint booster help ???
Old 08-01-2009, 04:05 AM
  #1231
W203E35's Avatar
2006 C350 Sport 6MT
Sprint booster amplifies the signal. So if you are doing 1/4 throttle it will amplify it to around maybe 2/4.
Or you can convert it to cable.
Also since our transmissions have Adaptations you can reset it which improves throttle response.
Search for "Sneaky ECU Reset"
Old 08-01-2009, 11:56 AM
  #1232
Super Moderator
Glyn M Ruck's Avatar
Guys - I think that the left is always first to rub - but if the car is sitting higher right than left the RHS shock has probably failed on the rebound.
Old 08-01-2009, 03:17 PM
  #1233
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
This happened to my car and the dealership replaced the left rear shock absorber under warranty. No issues since. This was at around 35k miles. I'm at 57300 now.
Old 08-01-2009, 05:03 PM
  #1234
paypaboi's Avatar
03 W203, 13 E350, 13 W204, 14 C218
my left rear does the same too but i have KWs
Old 08-01-2009, 07:53 PM
  #1235
jayton41's Avatar
05 C55 & 06 C230 SS
karo so ur saying mercedes uses electronicly controlled throttle??
Old 08-01-2009, 08:16 PM
  #1236
W203E35's Avatar
2006 C350 Sport 6MT
Yup, it's called "drive-by-wire" rather than the good old fashion cable.
http://www.sprintboostersales.com/sp...?make=mercedes
SprintBooster sends an improved signal to the ETC (Electronic Throttle Control) which is amplified or "boosted" so that throttle is noticeably more responsive throughout the entire rpm range.
Old 08-01-2009, 08:18 PM
  #1237
W203E35's Avatar
2006 C350 Sport 6MT
I know a lot of people use sprint booster but I myself wouldn't trust it. You never know what can happen.
If you are going to spend money to make you car into a track car then I would suggest you spend the money and convert the throttle to "cable".
Edit
By the way I was reading a pretty interesting article on the Autocross and it seems like most people say "Manual" is the best but a lot of pros say that "automatic" is the best. They change the torque converter and change some transmission parts and it's much better than a manual because when you let go of the gas the car tremendously slows down so you don't have to worry about down shifting "manual" and just focus on the course.
Jayton have you heard anything like this?
Old 08-01-2009, 10:12 PM
  #1238
tekmox's Avatar
Nothing
Need help on Eibach Sways
I was installing a set of eibach sways today and find that the endlinks on doesn't fit on the eibach sways. The sway bar had a much smaller hole then the end link. I got the eibach set 2564.320. Please tell me I got the correct bars. This is being put onto a C32 AMG.
Old 08-01-2009, 10:43 PM
  #1239
jayton41's Avatar
05 C55 & 06 C230 SS
sorry to tell u bro haaha but u got the wrong sway u should gone with
h&r's and theyre adjustable..but u shoulda done sum research first to see what endlink hole size ur car haz .
Old 08-01-2009, 10:56 PM
  #1240
jayton41's Avatar
05 C55 & 06 C230 SS
Edit
yea true i think il try to make it cable ...and no i havent heard about this automatic jaba jaba..i think its bull ..no offense...but i was just planning on getting a quaife 6-spd sequiental racing tranny and keeping it simple..yaa digggg
Old 08-01-2009, 11:54 PM
  #1241
infected's Avatar
2007 ML500
Those are wrong. AMG has a 12mm hole.
Old 08-02-2009, 12:02 AM
  #1242
MBworld Guru
FrankW's Avatar
white and whiter
you should do some research before giving out stupid *** informations.
The Eibach sway is also adjustable. 10mm endlink hole can be just drilled out to 12mm. it doesn't make any difference on how it's adjustable.
Old 08-02-2009, 12:06 AM
  #1243
MBworld Guru
FrankW's Avatar
white and whiter
Old 08-02-2009, 12:08 AM
  #1244
W203E35's Avatar
2006 C350 Sport 6MT
Hey non taken. I have never been to an autocross so I dont know much. It was just an article that I saw.
Here is what I read.
"Many racers believe they need a manual transmission, if they road race or autocross their car. Road racers downshift before entering the turn. They use the engine's compression to help in braking the car. When the driver gets back on the power, with a manual transmission, he is in the correct torque range and will have instant acceleration. On a tight slalom course, an argument can be made for using an automatic tranny. You put it in one gear and just concentrate on not hitting any cones.
California Performance Transmissions' Lancaster disagrees. He said, "Downshift and upshift timing are non-issues, allowing the driver to concentrate on proper vehicle placement when entering and exiting turns, which can be accomplished without lifting from the throttle in most instances. A properly designed torque converter, such as one of our Heavy-Duty Mega-Torque units, will also provide additional torque multiplication that is not available with manual transmissions. And California Performance Transmission has pioneered overdrive four-speed transmission swaps and can provide units behind virtually any engine/chassis combination."
But Keisler told us, "We have seen a significant number of swaps the other way, from automatic overdrive to manual overdrive transmissions. In addition to the benefits in weight and heat reduction, many drivers just believe, as we do, that a stick is just more fun to drive.""
http://www.kitcarmag.com/techarticle...ech/index.html
Old 08-02-2009, 06:13 AM
  #1245
infected's Avatar
2007 ML500
Was yours drilled Frank or do they have a kit with 12mm holes?
Old 08-02-2009, 07:46 AM
  #1246
MBworld Guru
FrankW's Avatar
white and whiter
they don't have a kit with 12mm hole when i got'em.
Old 08-02-2009, 07:54 AM
  #1247
tommy's Avatar
2004 Civic Si. FWD for the Win!
That's a classic - showing your own stupidity is never the best way to try to give a smartass answer.
Old 08-02-2009, 08:14 AM
  #1248
BigBodyBenzC240's Avatar
...a panty dropper...
After having the sprintbooster I would never want to go without. It makes the car a lot more fun. No HP boost, just quicker throttle response. I would rate it a 10 since I wouldnt drive without it now. It is a def mod which you will not regret!!
Old 08-02-2009, 10:45 PM
  #1249
skittles's Avatar
Moped
Talking w203 H&R sport springs almost 3k miles
k. i wanna sell my h&r springs that i used for a few thousand miles. still have the box stickers paper works. first 150 LOCAL gets the set. thanks for looking!
SOCAL BY THE WAY!!! and these have not been cut. no pics yet. they will be off tuesday night.
EDIT: should fit all c-class and clk(w209)
Old 08-02-2009, 10:55 PM
  #1250
RichW's Avatar
2002 C230 Coupe
Suspension rattle (even after replacing bushings/ball joints)
Hey guys,
I'm kind of stumped on this one. I had a noisey rattling suspension, and there was some play in the wheels (left to right) when it was jacked up. This indicated ball joints, so I went ahead and replaced all 4 thrust arms (left/right lower, left right upper) which gave me new ball joints and new bushings.
The suspension overall is better, and eliminated the left-right play in the wheels, however there still is rattling when I go over some bigger bumps. Anyone got any ideas as to what I should check next? Shock assembly? Wheel bearings maybe? Would sway bar end-links cause this? Sway-bar bushings? What's the diagnostic procedure to verify which of these things are the cause?
Any help or advice would be appreciated!
Rich...
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
Quick Reply: W203/CL203 Suspension (Shocks/Springs/Sway Bars) Discussion/Upgrade Thread
