Alert! Do Your Inner Door Seals Look Like These?
Old Jun 10, 2002 | 09:14 PM
MB-BOB's Avatar
Admin Alumni
See Garage
Alert! Do Your Inner Door Frame Seals Look Like These?
My 2001 C-Sedan was delivered with black inner door frame seals (see picture below, arrows). The plain rubber seals are quite grippy, and rub on your clothing as you enter/exit the car. Over the course of a year, the frame seal on my driver’s door became visibly worn and thin along a 3-4” length of the B-Pillar at the place indicated by the RED arrow. So, I asked the dealer to replace this seal under warranty, which they did...
...with a NEW design. See next post…
Old Jun 10, 2002 | 09:15 PM
MB-BOB's Avatar
Admin Alumni
See Garage
…In this picture, you can see that the replacement seal is no longer raw rubber, but upholstery over rubber, to match the interior color of the car. It doesn’t catch your clothing like the former, but is marginally harder to keep clean, due to the light color. Charcoal interiors won’t have this problem, of course.
After replacing the Driver’s door seal, the dealer realized that the other doors no longer matched, (duh?), and they have since replaced the remaining three seals. This photo shows the difference between the front and rear doors while the three additional seals were on order.
My question: Can you folks with 2002 models tell us if your cars have these upholstered seals as standard? Or the exposed rubber ones? Do the 2002 Coupes have upholstered seals, or rubber?
My Suggestion: Anyone with exposed rubber seals (2001s?) should inspect their driver’s door frame seal for wear at the point indicated in the previous post… You may be entitled to an upgrade when it wears out.
Old Jun 10, 2002 | 09:31 PM
MarkL's Avatar
2002 C240 6-spd (ret)
Hi MB-BOB, haven't talked in a while. Funny you should mention the rubber seals. Last week, after my hail damage headliner fiasco, I visited my dealer to look at some details in a new C sedan to compare to mine. They gave me the key to a C32 with charcoal interior. I noticed the "new" fabric seals right away, and thought it was nicer than my rubber seals. But, I thought it might have been related to the charcoal color, thinking that the lighter colors use the rubber to avoid the soil issue you mentioned. Now that you posted this info, I see they changed them all to fabric. I wonder if it just looks nicer, or if it does a better job of sealing out noises, etc? Since my C240 is a 2002, they must have made a production change part way through the year. Anyway, I don't think I rub against the seal when I get in -- I'm kind of on the small side, and I actually try to avoid rubbing too hard against the side seat bolster also to avoid scuffing.
Old Jun 10, 2002 | 09:37 PM
Fuzzo's Avatar
So markL are you saying that even the charcoal interior should have a cloth outer lining on the seal... hmm... i'm pretty sure I have rubber..and my car was an early 02 as well....
Old Jun 10, 2002 | 09:40 PM
MarkL's Avatar
Right, the new C32 I saw with charcoal interior had the fabric seals instead of rubber. My '02 C240 was built in July 2001, I wonder when the change occurred.
Old Jun 10, 2002 | 09:51 PM
Fuzzo's Avatar
Thanks for the info.. my car was built around the same time as well.... If anyone has a charcoal interior and has fabric seals.. please post a pic
Old Jun 10, 2002 | 09:59 PM
MB-BOB's Avatar
Admin Alumni
See Garage
MarkL, the seal is just as quiet as before. I find the door opening a little small for my 6 feet frame. I rub that portion of the B-Pillar, even when I consciously try not to do so.
I'd suggest you and Fuzzo check your rubber seal for wear anyway. You might be surprised.
Just to clarify... they're still rubber seals, just covered in fabric.
Old Jun 10, 2002 | 10:18 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
yes, those cloth doorseal is standard on my C32 AMG (april delivery)...and all the late 02 sedan model i think. C32 has those newer doorseal from the begining.
Old Jun 10, 2002 | 11:00 PM
Jim Banville's Avatar
'06 Lexus GS300 RWD, '07 Camry SE V6 auto, '91 190E 2.6 auto
My '02 C240 has the "cloth" seals. Nice
Old Jun 11, 2002 | 12:34 AM
Lynn's Avatar
My coupe has rubber seals. Wear on the seals is not a problem, because the coupe doors are longer. Even though I have the seat almost all the way back, I never rub the seal.
Old Jun 11, 2002 | 08:11 AM
viper's Avatar
Its amazing that your dealer will replace all the seals. I think most dealers would just replace the bad seal with a new rubber one at least during the warranty period. Otherwise they will have to replace a lot of perfectly good seals at considerable expense just so they all match.
Old Jun 11, 2002 | 09:21 AM
MarkL's Avatar
Yeah, the cloth covering looks nicer. BTW, I wanted to ask if you've cleaned the lower parts of those seals, where they can be accidentally kicked when getting in or out. Those guys who were in my car working on the hail dents got them a little dirty -- not sure how to clean w/o messing them up.
Old Jun 11, 2002 | 10:39 AM
MB-BOB's Avatar
Admin Alumni
See Garage
My dealer told me they no longer make or stock the plain rubber seals for the sedans. The only replacement available was the upholstered one... hence the swap-out of all four. The whole point of this post is to alert others with plain seals to the probability of an upgrade when theirs go bad.
Lynn, yup, I like the longer door in the Coupe for that reason. I understand that the B-Pillar is heftier on the C-sedan compared with other sedans, for rigidity and safety reasons. (All of the MB loaner cars I've driven are easier to enter/exit, because their B-Pillars are thinner, front to back.)
MarkL, yes the tan seals get scuffed with the shoes easier. I'm hoping some Simple Green and water that works on the door kick panels will also clean the seals when the time comes. I prepared myself to work harder to clean a Java interior, but it's proving to be much more of a chore than I expected.
Old Jun 11, 2002 | 11:12 AM
MarkL's Avatar
I've only had to clean my seat bolster areas about every 6 weeks with MB Interior Care (works great and takes about 5 minutes). I've only cleaned the leather inserts once w/ MB Leather Care, but I need to do it again this weekend. For a light-colored interior (I've had many), it's one of the easier to keep really clean, IMO. I think I've had to clean my inside windshield surface more than the seats, and not just the center area. I had this experience w/ my Passat also -- it's hard to really clean that surface w/o leaving some streaks. I think I need something other than Windex.
Old Jun 11, 2002 | 11:18 AM
MB-BOB's Avatar
Admin Alumni
See Garage
LOL, MarkL. For years I used straight vinegar to cut the "foggy residue" build-up. But I was given a car care promo kit when I bought my '96 Dodge minivan. It had some Chrysler Glass cleaner (spray foam type) that really works well. I won't go back to vinegar, anymore. I understand that Stoner product is good, too, but expensive and quick to run-out.
Old Jun 11, 2002 | 01:43 PM
viper's Avatar
Yes thanks for letting us know. I was only making a point that its going to cost them a lot of money to replace 3 other seals when only one is bad. Just surprised that they would thats all. Sounds like you were offended by my comment ?
Old Jun 11, 2002 | 01:45 PM
BrabusCClass's Avatar
GL450, Sienna SE
I have rubber seals and they looked deformed when I first got them so I had it replaced. I wonder how I can get them to replace it again... I think the fabric is much better like you said.
Old Jun 11, 2002 | 02:43 PM
MB-BOB's Avatar
Admin Alumni
See Garage
Viper, not offended at all. If MB doesn't want to stockpile the plain seals, it's their problem to match the replacements to the car when the originals go bad under warranty.
My dad had a Buick where the cloth upholstery on the driver's seat unravelled at the seams under warranty. They apparently had similar problems on several cars with these seats, because stock of the original pattern cloth seats were no longer available by the time his went bad. So the dealer ended up replacing ALL the seating surfaces in the vehicle. That was expensive, too.
Old Jun 11, 2002 | 04:31 PM
SoCal240/6's Avatar
'01 C240/6
Dealers love to replace parts. They get paid by MB for the parts and they get paid by MB for the labor.
Old Jun 12, 2002 | 11:51 PM
AMGracer's Avatar
ML,
I for years I have been cleaning the inside of my windshield with regular glass cleaner and......get this.....newspaper. Yeah, just take a bit of old news paper, crumple it up and dry the sprayed on cleaner with it. You'll never get a nicer cleaner streak free look than by this method. I was hesitant to do this too my car at first but my girlfriend did it to her car so I thought I'd give it a try.
Excellent trick
Old Jun 13, 2002 | 01:06 AM
JustinTRW's Avatar
C32 AMG
My 2002 C32 AMG came with the upholstered seals. Very nice.
Old Jun 13, 2002 | 10:02 AM
MarkL's Avatar
Originally posted by AMGracer
ML,
Excellent trick
Thanks -- actually, I learned this trick from a neighbor many years ago when I had a mirrored wall in my dining room. The newspaper did a great job. I just never tried it in my car because I thought it would be a mess, like getting newsprint on the dash, etc. I'll give it a try.
Old Jun 13, 2002 | 11:45 AM
revstriker's Avatar
K Car
I finally remembered to check last night, and my 2002 C320 has the black rubber seals. No wear marks on them yet, and I haven't noticed myself rubbing up against them. I think the upholstered one's look a lot nicer though.....
Old Jun 18, 2002 | 02:37 AM
xc240x's Avatar
2001 C240
Post
My c240 has the cloth seals... i recieved my 240 in about march 2001, i have oyster interior... who knows when the seal change occured?!
Old Jun 18, 2002 | 04:18 PM
MB-BOB's Avatar
Admin Alumni
See Garage
The change in seal design appears to have happened sometime after the 2002 model run began. Your 2001 should have plain rubber seals, yes?
