First mod- flat hood ornament
To fix: Pushed the emblem all the way in the bracket while off the hood.
--The instructions tell you to mount the bracket and them put silicone on the emblem and push it on. I did all this while off the car, and make sure you push the emblem all the way on. That way when you tighten down the bracket, the emblem will seat up against your hood. It should actually pull the emblem out of the bracket a little. If you do it right there is no gaps.
Too bad the blue color fades over time with outside sun exposure.
he told me to use a little bit of multi-purpose epoxy.
i first mounded the housing brackets.
as instructed, i then put a few drops on the back center of
the emblem and applied gentle pressure. with proper tightning, it's pretty flush all the way around. be carful not to get the epoxy on the body of
your car though...otherwise...
this technique worked for me though.
tommy, my business partner has lost interest... I owe you 10 minutes. I could package those up in a donut hole and send them along sometime.
