Damn Damn Damn Fudge - A Few Pics SSR Comps :)
Old Apr 9, 2005 | 10:52 PM
nukblazi's Avatar
So, it was another nice day so I took a crack at the SSRs again. At VIR I discovered the 235 fronts didn't clear the H&R coilovers. I couldn't even bolt it on, no chance.
They look so freaking good. The rear fits damn nice. Close to tight, but nothing that me and my utility knife and a baseball bat (ala Jeff Short ) couldn't fix if needed.
The front 235/40 tire rubs on the strut. It is seriously only a millimeter. I am going to get a 10mm spacer for the front. with the 20mm difference from front to rear 255 rears, it'll still be staggered. I think the 10mm will still allow clearance of the front fender. Might need to roll it though. I am pissed. I thought it looked so good. Nice to eliminate the rear gap with tire not spacers... 255 BIATCH. You could go to 275 but you'd need to get the offset really right. Really right. And that's without the rear coilover adjustment sleeve. Can't go any lower.
Here are a couple pics. While I was under there I did a general suspension inspection and lubed my sway bushings. CRC White Lithium spray grease rocks. You just drop the brackets a little and spray in. Nice!
http://s120313391.onlinehome.us/nuk_.../SSR/index.htm
Old Apr 10, 2005 | 10:22 AM
inFiniTE LooP's Avatar
2005 Volvo S40 T5 AWD, 2004.5 C230 Sport Sedan, 2005 E320 CDI, 2008 C300 4-Matic Luxury
damn, that sucks man, sorry to hear about that, it looks good too, is 10mm spacers the smallest they make? hope it works out for ya
Old Apr 10, 2005 | 02:34 PM
Blake P's Avatar
'09 A4 S Line
Doesn't H&R make a 5mm spacer?
Old Apr 10, 2005 | 04:48 PM
nukblazi's Avatar
Yes, I think so... I think the 5 will clear the strut but the 10 would clear the perch lower
Old Apr 11, 2005 | 02:22 PM
1Lop2K5C's Avatar
C63
H&R also makes 8mm spacers as well.
Old Apr 11, 2005 | 02:34 PM
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
Have all the issues with H&R spacers been settled ?
meaning, a lot of people complained at first that they unsettled the car, and cause vibrations, and what not...
Was that faulty installation, or some sort of problem with H&R spacers ???
I'm considering putting 5, 8, or 10mm spacers on my rear wheels.
Thoughts / Suggestions ???
Carlos
Saprissa@aol.com
Old Apr 11, 2005 | 04:08 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
I've had 20mms on my ccoupe for over two years now without any issues at all. In fact, this is the first time that I'm hearing of any issues.
The only real problem that I have with them is that they stick like glue onto your wheels and are a mother to take off. I've seen chamfered spacers which sound like a better mousetrap to me.
Old Apr 11, 2005 | 04:25 PM
Blake P's Avatar
'09 A4 S Line
Carlos
Saprissa@aol.com
I don't have spacers, but as far as I've seen the people having vibration issues are those with spacers on front wheels. As for the size you should use, I'd recommend taking measurements of how much clearance you have between tire and fender to avoid rubbing. If you have under 10mm clearance, I think you're better off leaving well enough alone because the difference would hardly be noticeable anyway.
Old Apr 11, 2005 | 04:43 PM
Saprissa's Avatar
my ride height is fully adjustable (CARLSSON RS), so clearance isn't a big deal.
I just want the outside of my wheels to be flush in line with the body of the car, and
I believe it would take somewhere between 5-10 mm. It will also really accent the wider tires I have in the rear which makes the back of the Coupé more bearable to look at !
The way the Coupé is shaped, it sits like a wedge so even if the car is flat all-around, the back always seems like its sitting higher. I can always adjust my rear height just a tad to allow for clearance. All that leaves is how many MM space to use.
If I remember correctly, I think the vibration issues did concern the front wheels, now that I think about it.
Carlos
Saprissa@aol.com
Old Apr 11, 2005 | 06:16 PM
tyro's Avatar
BANNED
Sometimes I'm a spacer
Old Apr 12, 2005 | 01:16 AM
pshek's Avatar
2003 C-Class Sportcoupe
H&R trak + spacers are hubcentric. I've had the 5mm on my coupe for a few months and no problems so far.
Old Apr 12, 2005 | 04:28 PM
carlssoncclass's Avatar
i know this place where u can customize spacer.
Any sizes u want.
Nico
Old Apr 13, 2005 | 03:22 AM
nukblazi's Avatar
I am going to get the 10mm and see how it goes. Nico, I will PM or email you if I need them machined down or a custom size
Thank you
Old Apr 13, 2005 | 11:39 PM
Outland's Avatar
2002 C230 Coupe(M111)
Nuk...um, get a garage.
Old Apr 14, 2005 | 12:40 AM
Thank you
Ya, just let me know if you need any help. Is nice seeing you here on mbworld too.
Nico
Old Apr 14, 2005 | 10:25 PM
nukblazi's Avatar
Had one, then I moved down here and took a townhome while I figured out what I am doing with my life.
We have selected a few areas including northestern PA, Orange Co. NY, Richmond, VA area, and the Realiegh NC areas... I've been consulting for one company for a year now and we are negotiating a hire. That will impact "where" we move and how soon I get my garage. Idealy, I am going to get a 2 car attached, and build a 3 car detached with an apartment and home office on the second floor
Old Apr 14, 2005 | 10:26 PM
nukblazi's Avatar
Nico
Will do and thank you!
