Hydroplaning ...Be Careful
Old Jun 19, 2002 | 08:17 AM
Jerry MB230K's Avatar
Driving 55 mph on a 55 MPH road, and my MB slides about 1 or 2 feet to the left when i'm trying to drive straight. Didn't notice any flashing triangles on the dash to indicate any ASR or other systems engaged.
I'm quite surprised that a new car with new tires and advanced stability control would swerve to the left.
Old Jun 19, 2002 | 08:19 AM
Hydroplaning - Yes, it was raining heavy
Forgot to mention .. it was raining heavy when my car hydroplaned.
Old Jun 19, 2002 | 09:06 AM
MarkL's Avatar
2002 C240 6-spd (ret)
When tires are hydroplaning, there is insufficient contact between the tire and the road to hold the vehicle in place. Since all anti-skid systems use braking and/or engine output reduction to control the unwanted direction, it also depends on tire traction on the road to correct the problem, right? I mean if you drove over a solid section of ball bearings, no anti-skid system would help. You need sufficient traction at one or more corners to stop the skid.
Old Jun 19, 2002 | 09:22 AM
avlis's Avatar
2008 VW GTI
You say it slid to the left. Did it "turn" or "steer" to the left or make a lateral "shift" to the left as if all 4 tires moved sideways?
I think the ESP system compares driver input to "yaw" sensors and makes a determination. If the entire car moved laterally, I think the yaw sensor would be unaffected and still think the car was on a straight course, hence, no flashing triangle. If the rearend started to "come around" the yaw sensor would see that and attempt to straighten things out.
Old Jun 19, 2002 | 10:05 AM
NANA's Avatar
C230K Manny, Albaster White/Oyster Leather/C1/C5/C7/CD
Just out of curiosity, what kind of tires do you have? Do you also have C7 package?
Old Jun 19, 2002 | 01:22 PM
galaxygrrl's Avatar
c230k, black, auto, c2 (let the sunshine in), Bose, leather, and CD
Not that this would help much, but did you have traction control on "W". It does make a difference. Hydroplaning happens, there is not much you can do about it, but stay calm and act smart.
Old Jun 19, 2002 | 01:47 PM
WebGuyNJ's Avatar
2002 C230K
The 'W' setting is only available on automatics, correct?
Old Jun 19, 2002 | 01:55 PM
Lynn's Avatar
The "W" setting is not part of the traction control. The "W" setting forces the automatic tranmission to start in second gear.
Old Jun 19, 2002 | 02:02 PM
MarkL's Avatar
That's right, and it also uses a 2nd reverse gear. I don't know where galaxygrrl got that info from!
Old Jun 19, 2002 | 02:15 PM
mverboom's Avatar
C270CDI Avantgarde 2001 Sedan AMG rims and skirts
I did a driver training course with some friends. Two of them also have a c270cdi, 1 is almost the same (also a manual). His was not very stable when braking and doing evasive manouvres on a wet and slippery underground. Best to describe it was that is was nervous. Mine wasn't. The instructor thought it was the width of the tires, but that wasn't it (mine are wider). It turned out that I have Pirelli's and he has Continentals.
Come to speak of continentals, everybody in my group who had stability problems had continental tires...
Mark
Old Jun 19, 2002 | 02:50 PM
All systems were on .. the car was not in "W" mode .. not sure if 'W' would make a difference at 55 mph when the auto xmission is already in 5th gear.
I have standard tires ( not c7 )
Old Jun 19, 2002 | 02:56 PM
galaxygrrl's Avatar
Sales guy who said to always use it when it was wet and that it would help.
Old Jun 19, 2002 | 03:05 PM
awaken's Avatar
Common misunderstanding. It helps only start, not to drive on slippery surfaces. If you start on 2nd gear instead 1st less torque applied to the wheels and less chances to wheelspin. The same technique applicable for manual tranny
Old Jun 19, 2002 | 04:58 PM
DtS's Avatar
DtS
C200 Kompressor
The "W"-mode also engages another shift-program so that upshifts will be done sooner (given that you don't floor it, then it will be no difference).
Old Jun 19, 2002 | 06:10 PM
trench's Avatar
2002 C230 K
Makes sense, would be less potential wheelspin if engaging the new gear lower in the torque peak.
BT
Old Jun 19, 2002 | 06:21 PM
Goggles Piasano's Avatar
C230 K coupe Orion blue, Evo, prem leather roof, premium sound and cd changer, auto.
If you have Michelin tyres or Contis, they are nowhere near as good in inclement weather as say Pirellis. I have the Michelin Pilots (C7) package and have experienced touch and go situations in minimal snow conditions. On a previous car I had Michelin Alpin Winter tyres that really gave me a pause on a highway offramp doing no more than 30 kmph. The same day I had these tyres replaced with Pirelli Winter and Ice tyres which gave dramatic and superlative performance in all winter conditions. I just came back from Italy and in Rome came across a tyre shop that sold performance tyres, the Pirelli P7000 series will be the next set for my coupe next summer. This winter the Pirelli Winter and Ice tyres will be in place of the Pilots.
P/S To the European posters, Why are there so many diesel engined Mercs with such low displacements in Europe. Every CLK was a 200 (with the exception of one car) as were E class cars (200 cdi) and even S-class sedans. A class cars were as common as Fiats and those silly Renault "Smart cars". I only saw one ccoupe on the A-1 highway (this car doesn't seem to be very common in Europe as well). Furthermore what is the reason for so many mercs without number designations? I saw only one CL55 parked outside of the Rome Opera house, possibly Pavaroti's
Old Jun 19, 2002 | 06:47 PM
DtS's Avatar
DtS
C200 Kompressor
Why so many diesel cars with small displacement? Simple! A gallon of gas costs ~$4 in most european countries. A gallon of diesel is commonly much cheaper (in most countires, Great Britan f.e. excluded). Plus the consumption for a diesel engine is much lower. So it's a question of fuel-pricing!
Old Jun 19, 2002 | 06:48 PM
trench's Avatar
2002 C230 K
Fuel is much more expensive there than here - notice nobody in Europe drives around in big-a$S SUVs. I also think that for some countries (the UK) there are tax advantages to driving a diesel.
Cheers, BT
Old Jun 19, 2002 | 09:10 PM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
Don't forget rather high taxes that are based on engine displacement.
Old Jun 19, 2002 | 09:16 PM
steve s's Avatar
1996 C36 AMG, 1995 Volvo 850 Turbowagon
diesel engines also tend to have gobs of torque, helps with moving people
did u hit a puddle of standing water? doesn't matter what kind of tire u had...u can always experience hydroplaning. my s-02 were a lot better than the pzero assy...some max performance tires do better in wet than all-season tires also.
