Spacers
need your help,please...
I have replaced stock wheels with authentic AMG 17/7.5 fr.,17/8.5 r.on my 2005 C230 SS,but they look kind of slim/skinny.Could you suggest what size of H@R spacers and bolts i should get,that they would look flush with fenders.
Regards,
Serg
I have 17" AMG wheel set up too on my C320 Sport Coupe, and only the rear looks like it needs to be a little wider. I'm thinking of putting 5mm or 8mm H&R spacers in the rear. I just have to adjust my CARLSSON suspension up a notch, to make sure I don't rub.
My advice, start out with the 5mm on the rear, and if you like 'em, get another set for the front. Or if you don't, move the 5mm to the front, and get 8mm for the rear. See what works best for you, both "looks" wise, and physical fit (rubbing depending on how lowered the car may be).
Hopefully, someone with a bit more saviness on spacers for the Sport Sedan will post some more info...
Carlos
Saprissa@aol.com
I haven't bought my H&R spacers yet, but does anyone know:
- when you buy the spacers, do they come with longer sized bolts ???
Carlos
Saprissa@aol.com
Thank you very much for help I appreciate it.
Tommy,
You have 20mm H@R's,what set of wheels/tires is that 7.5 fr./8.5r.225/45/17,245/40/17 ?
Regards,
Serg
So, if your question is will your rim/tire combo work on the rear w/20mm spacers, I don't know, sorry.
hope the fender would get worn from time to time.
er,can't post a pic. now ,will later
