Shifting tips for 6-speed?
Anyway, my question is about optimal shift points for the 6-speed (duh)....To get this car to 60 (and beyond) at its quickest, at what RPMs should I shift? Is the power band simply the listed max torque range or does each gear have it's own optimal shift point? Anyone happen to know them?
I had driven a stick all my life until my G35 (simply because the 6-speed wasn't available at the time) and the three or four times I test drove the C230, the car was really lunging when downshifting to pass, say from from 6th gear at 60 or 70 mph to 4th through 80 or 90...does rev-matching in this car eliminate this assault on my passengers, or is smooth downshifiting something I will have to learn to live without? Obviously once I own the car I'll learn how to smooth her out, but I don't want to wait that long.
Any tips for smoothest upshifting during normal driving would help too.
Thanks!! Cheers.
Do you single- or double-clutch? I was never taught to double-clutch, not to say I can't or haven't done it, just that it's unnecessary as it only saves the synchros...and isn't that what they're there for, to make double-clutching unnecessary? Unless there is further damage being done by blipping the gas with the clutch fully depressed??
Thanks!! Cheers.
the reason it lunged is because you tried to shift too fast and the engine was not slowed down enough, orrrr you tired too hard to rev match and made the engine go too fast before you let the clutch out.
drive the car for 3000 miles then you will know when to shift and what it should feel like, until then you just need to drive and learn about the car.
BTW If I was a cop I would be pulling people over and giving tickets left and right for doing the speed limit and below in the left lane, While they are not speeding, they are illgally driving in the left lane, which is for passing, which NY does not enforce nor post. If you want to do the speed limit you are supposed to be in the middle lane if there are three and in the right if there are two... Sorry... Just had to vent... yesterday comming home from school I gut stuck behind someone doing 50 in the left and a person doing 50 in the lane next to me and boxed me in...
Just listen to and watch the cars in formula racing and they use this exact technique. You should always be in the right gear and speed as you enter the turn, thereby controlling the car better as you go through the turn and enabling you to accelerate out of the turn. On many occasions this will require more than one down shift, especially with a 6 speed gearbox. In order to control the amount of engine braking you want you need to match the revs to the road speed you want.
Anyway shifting gears in response to road conditions and traffic is the fun of driving a manual gearbox.
In terms of clutch wear, resting your foot on the clutch pedal all the time, or even between shifts, causes many more problems than utilizing the gearbox by shifting.
I appreciate your input though, ct, I'm itching for it to get here so I can start driving a car instead of merely propelling one, and this is the only outlet I have until then!
Cheers.
