2019 S560 Metal Shavings in Oil Pan
If you like the car, see if the dealer will allow you to inspect the filter for metal bits.
There are no circumstances where shavings in the oil pan are not a major problem, a new engine will be needed shortly.
I would question the source though, it would be very odd to have metal shavings in the oil in a car of that mileage. Was the oil changed regularly?
(unless you are a diy'er or garage PLANNING FOR THE REMEDY - which should have been noted in the original post)
