HK amp in '05
Old Jun 18, 2005 | 02:24 PM
Jim Banville's Avatar
'06 Lexus GS300 RWD, '07 Camry SE V6 auto, '91 190E 2.6 auto
HK amp in '05
Does anyone know the EXACT location of the amp in the '05 sedan w/ upgraded audio? Pics?
thanks!
Old Jun 19, 2005 | 05:37 AM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
...same location as in the pre 05s...rightside wheelwell in trunk...behind the panelling...those 203s in the US without the HK amp have the HK bracket with some high performance foam there...
greetingz,
Old Jun 19, 2005 | 10:44 AM
SUNILP's Avatar
2015 E250D
greetingz,
SOME REAL HIGH PERFORMANCE STUFF! Must act as a sound deadner for the entire car.
Old Jun 19, 2005 | 07:27 PM
Thanks! I have the standard audio, but I'm considering getting the OEM rear deck sub and a small amp to drive it
Old Jun 20, 2005 | 01:06 AM
nlpamg's Avatar
Super Moderator Alumni
2019 GT3 RS, 2017 M3 30 Jahre
what happened to "oh, the non-H/K sound system is plenty good for me?" :p
Old Jun 20, 2005 | 12:02 PM
Hardy har har :p
It is fine for no additional cost,but I'm now feeling I want just a little more bass fill. I don't want a bulky subwoofer box though. Unfortunately, I was quoted $260 for the rear shelf subwoofer and enclosure/bracket. WAY too much! I'll try find a decent, low profile free-air 10" sub for $100 or less to mount there.
Does anyone have any pics of the OEM sub woofer, either mounted or not?
thanks!
Jim
Old Jun 21, 2005 | 09:40 PM
I wonder how this would fit/perform?
Old Jun 21, 2005 | 10:04 PM
ChaRgeC230's Avatar
05 c230 SS
hey thats what im planning on doing.. i have the standard radio...do you know where the speaker wires are for the line converter?
Old Jun 21, 2005 | 10:57 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
It says its made for small enclosures. Your rear deck will not be good enough; even if it is completed sealed. Google for some sub modeling programs and you'll get the idea.
Old Jun 22, 2005 | 12:17 AM
W0n6_3d4n's Avatar
C200K (w204)
The impedance kinda funky, 7.6 ohm?? Am i reading right??
Old Jun 22, 2005 | 08:55 AM
That company's website has a speaker forum and the maker says it would perform "well" in an infinite baffle (i.e., mounted in rear deck with no enclosure).
Yes, the 8 ohm was the first model produced. They were originally designed for mounting into standard 2x4 walls as home theater subwoofers. Home speakers are typically 8 ohm. They are supposed to be working on lower impednace fo car applications.
Apparently, Alpine and Pioneer also produce very slim subs. I'm just having trouble finding into on them.
Old Jun 22, 2005 | 09:48 AM
W0n6_3d4n's Avatar
C200K (w204)
Look into Alto Falstaff or Phase Aliante, they are slimline woofer, only 10cm deep, but dunno whether they like infinite baffle or not, price may not be suitable but :P. Are u talking about Pioneer/Premier TS-SW124D, it sure look slim. I haven't seen slimline Alpine subs before, have any link??
Old Jun 22, 2005 | 01:24 PM
I think it was Blaupunkt instead of Alpine. The 10" Blaupunkt TW1000 is 2.5" deep, but I don't think it is out yet. Retail is $180.
Old Jun 22, 2005 | 01:28 PM
JohnCL's Avatar
'01 C320 || '14 Honda Pilot EX-L
Jim,
I don't know how much bass you want or need, but have you thought of something like a Bazooka tube sub? I know that you said that you didn't want a big box and I understand that, but the tube can be mounted over to the side and left plenty of space for other stuff. Also, Infinity has that BASSLINK which is pretty compact.
Old Jun 22, 2005 | 01:39 PM
Thanks, but I want no bass box/tube in the trunk. I'm only looking for some bass fill, not "hear it down the block" booming bass
If I can't fit a good 10" or 8" free-air sub in the rear shelf, with an amplifier hidden under the carpet trim, I'll just stick w/ stock stereo system.
Old Jun 22, 2005 | 01:42 PM
JohnCL's Avatar
Gotcha, let us know how your search turns out. Good Luck.
Old Jun 22, 2005 | 02:19 PM
Does anyone know how to remove the rear shelf cover w/ fold flat rear seats? I searched, but the instructions I found were sort of vague.
Old Jun 22, 2005 | 03:21 PM
SUNILP's Avatar
2015 E250D
you first have to remove both C pillar covers. Remove SRS airbag plastic thingies and unscrew the bolt under neath first. Then remove weather stripping. Pull c pillar cover towards front of car. Shine a light inside where you removed the weather stripping and unlatch cover.
Old Jun 22, 2005 | 03:32 PM
Capt Nemo o2's Avatar
'05 C230SS 6MT, 1966 Triumph TR4a IRS, Shelby Cobra 427 Supercharged
http://www.crutchfield.com/S-dfbS5sk...520#morephotos
Jim, try this, its not much cheaper though ($224). It looks very similar to what MB uses, just not as fancy. And its a German brand too!!! If it fits, and sounds good I may even replace my sub with that and and get a higher powered amp.
Old Jun 22, 2005 | 07:06 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
That 4" may be OK for a box but it will never fit between the structure and the shelf which is what he is looking for.
Old Jun 23, 2005 | 09:51 PM
Tishers's Avatar
'06 C350 4MATIC
Two eight ohm speakers wired in parallel will result in a 4 ohm impedance. If you do this make sure you wire them exactly the same way so they don't try to cancel each other out (one going in, while the other is going out)
Old Jun 23, 2005 | 09:53 PM
Tishers's Avatar
'06 C350 4MATIC
Oh, don't let the ohms and impedance thing worry you. Ohms in this context is for DC resistance of the coils. Impedance is how the speakers behave under AC conditions.
Old Jun 25, 2005 | 01:43 PM
Guido&Nancy's Avatar
Exclamation Still loking for the amp for the sub
Hello there,
I have the standard radio with the sub in the back sounds resanable but the back is a bit low, I would like to turn up the amp connected to the sub, does anybody know if the amp can be turned up? othewise i'm probebly going to replace it for a more powerfull amp and keep the standard sub, has anybody done this and if so what's the result?
Further I can't find the amp, I did find several Handy (phone) stuf and made a picture of where I thougd it would be can anybody point out where to look for the amp?
Looking forward to your info regards Guido & Nancy
p.s. Answers can also be in Dutch (i'm from the Netherlands)[IMG]
Old Jun 29, 2005 | 05:11 PM
ChaRgeC230's Avatar
05 c230 SS
does the stock standard radio have a sub or amp? im trying to find the wires for the lin converter...
Old Jun 29, 2005 | 10:09 PM
The stock radio is used for both "standard" and "upgraded" audio systems. It has amps built in for driving the speakers when used in the standard system. When used in the upgraded system, it connects to a trunk mounted amp vis fiber optic connection. I stopped by my local MB dealer and got a print out of the 2005 stereo's wiring diagram. Unfortunately, the list of connections on the back of the radio included in the diagram doesn't show standard, electrical line-level outputs
