Installing a OEM sub???
Old Jul 9, 2005 | 09:52 PM
gaiex's Avatar
'13 E500 Coupe AMG// '17 E350d // '24 E53 AMG
Its possible to had the Bose sub to a non Bose car???
I want a little more bass to my audio system in my coupe, I allready upgraded my only four speakers to Clarion 6.5" 2 ways at front and Clarion 6.5" coaxial back, but I want a liitle more bass in the back, because all my speakers are at front, on the doors
I doesn't want to install a amplifier, and I was thinking if just installing a bose or H/K sub in the trunk will do the work!?
But how to do the installation, or the sub is auto-amplified???
I prefer the OEM sub because it doesn't fill the trunk and I don't want a lot of sound Power!!!
My mom's C wagon has H/K sound and I like the sound, almost the same quality of my dad's A6 with Bose :p
Old Jul 9, 2005 | 10:13 PM
vraa's Avatar
You're not going to get a lot of power out of the Bose sub, it sucks a lot.
You'll be better off, and probably a lot more cost effective if you took you're time designing the same thing around aftermarket stuff such as JL or even Rockford Fosgate.
Old Jul 9, 2005 | 10:29 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Gaiex
The BOSE sub sucks. Plus its controlled of the fiber options. You'd be better off finding a small sub for that space and a small add-on amp that you can hide behind the trim.
Remember that the sub in your Mom's car is a dual voicecoil approx 135 mm and the original one in the coupe was, I believe, 100 mm x 150 mm single voicecoil.
Old Jul 10, 2005 | 07:06 AM
gaiex's Avatar
Originally Posted by amdeutsch
Gaiex
OK I see, so the installation would be some pain in the ***, but what to fit in a so small space???
Does the new coupe also have H/K like the sedan?
I heard here some time ago that H/K sound sucks, but thats not I think of my mom's wagon H/K
Old Jul 10, 2005 | 07:08 AM
vraa's Avatar
There are a lot of subs that are designed for tiny enclosures, it'll take a while to find though.
Try an audioshop to see what they suggest.
Old Jul 10, 2005 | 08:49 AM
Jim Banville's Avatar
'06 Lexus GS300 RWD, '07 Camry SE V6 auto, '91 190E 2.6 auto
http://www.edesignaudio.com/product....b=Apps&cur=USD
Very small enclosure & 14mm Xmax
Old Jul 10, 2005 | 10:01 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Jim,
That one is too large and too deep for what I understand gaiex's wishlist requirements are. In addition you should link something that is available in his home country. :p
I believe he would be best served by something no bigger than 6 1/2" (165 mm) with shallow mounting depth since he is looking to augment the low end of his existing setup.
Old Jul 10, 2005 | 03:08 PM
gaiex's Avatar
Jim,
You're rigth, and I don't want to have a box filling my small trunk, and I just want a bit more punch, not super power :p
Is the Bose and H/K sub auto-amplified or it have some kind of external amplifier??
I sold some time ago my Alpine (4+1) amplifier I didn't want to have aftermarket installations, I done all modifications I wanted in my last car a 3 series BMW and I'm sick of doing that, only OEM mods as possible for now :p
Old Jul 10, 2005 | 03:39 PM
What are the dimensions of the cavity behind the trim that the Bose subwoofer assembly occupies? The driver I recommended only requires 5 inches of depth and a sealed box of approx. 1/2 cubic foot, is relatively inexpensive and would KILL the OEM Bose sub!
Old Jul 10, 2005 | 06:01 PM
gaiex's Avatar
I can't measure without taking of all rigth cover, and after that it have a cover in the same space of the bose sub
I found some pics with the bose sub and taked 2 pics of my space:
Attached Thumbnails Installing a OEM sub???-fdeff455.jpg   Installing a OEM sub???-fdeff596.jpg   Installing a OEM sub???-sub-bose.jpg   Installing a OEM sub???-space.jpg   Installing a OEM sub???-space-2.jpg
Old Jul 10, 2005 | 06:07 PM
gaiex's Avatar
Is the H/K coupe sub the same size of the bose one?
Does it work the same way as the bose, fiber optic and small amplifier?
Does the H/K sub performs better than the bose sub?
Old Jul 10, 2005 | 06:29 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Gaiex. See post #3 above for BOSE.
Old Feb 14, 2006 | 10:04 AM
gaiex's Avatar
Ok, I found a BOSE sub for my coupe for a real nice price, very nice indead, I'm thinking getting it, but I know it works via fiber optic, anyone have more info on this, plugs or squematics???
Then I will need a amplifier...
For the price of the sub (cheaper than other aftermarket subs, and allready with box) I think I will give it a try
Hope anyone could help me
Old Feb 14, 2006 | 10:48 AM
StillKickin's Avatar
Mine 2005 C230 Kompressor, Dad's 2005 ML350
DONT DO IT!!! Get an Infiniti BassLink or Bazooka tube....far simpler installs and better results with a minimum of space taken up.
Old Feb 14, 2006 | 05:03 PM
Elliott's Avatar
'03 C230 Sedan
BOSE sucks...I dont get the hype...maybe its great for home audio but take it from me as someone who has worked a few years at a retail electronics store...almost anything aftermarket for the car is better than bose...within reason. I'm not saying go out and buy a Jensen sub or something crappy like that. If you want the status symbol of audio...which often times is the only reason people buy the BOSE system...skip the bose and go JL or Eclipse or something of that nature.
Buying BOSE aftermarket for cars =
Old Feb 14, 2006 | 05:14 PM
gaiex's Avatar
My reasons are in post #1
And if there is any way it work with other amp, I think I will do it.
I don't want super bass and nothing in my trunk, and to do a box for a new sub in the same place of the bose sub its $$$, more than the bose sub I saw and a small amplifier
Old Feb 14, 2006 | 06:53 PM
electromethod's Avatar
Honda Grom
Well... there are self amplified Bazooka tubes. They come in 6 1/2's even so you can toss one in your car in ZERO time. No offense but if you want to put OEM system in your trunk, then odds are you just don't have enough experience installing aftermarket components. Perhaps you should just go to a shop and have them install it? Either way, check out the bazooka's, since it might be something you can be comfortable installing .
Old Feb 14, 2006 | 07:25 PM
gaiex's Avatar
I just want to know if its possible or not to install only the BOSE sub.
I had aftermarket sytems allready in my cars (apline and others) but I just want to install the Bose sub because of the OEM looks and clean space.
I have 4 clarion (80 rms), 6.5" 2 ways and Clarion 6.5" coaxial speakers at front allready with the stock Audio 10CD and I just need some bass at the back.
About the bazooka tubes, NO, they are a bit €€€€ and I don't want more things in my trunk
I could make a sub Box to put in the trunk rigth side, like I did in my BMW, but I don't want to have so much work doing that or paying someone to do it, and because the final looks aren't the same
Old Feb 14, 2006 | 08:26 PM
Honda Grom
Bazooka's aren't expensive over here....... don't know how much they run over there.... but here you can pick an el8a for 99 dollars. Anyhow, sounds to me like you don't have experience with fiberglass so your options for a slim install are going to be just that..."slim." Here is another thought.... do you use your rear deck on the coupe? You can always put a small depth free air subwoofer there and it won't be taking hardly any extra space. HTH and good luck!
Old Feb 15, 2006 | 01:09 AM
Moviela's Avatar
Hey Gaiex,
If the sub you have is like th picture in post ten, it will fit in your car nicely. The audio is sent from the Head Unit in the dash on fiber optic cables via the D2B bus. The Bose driver gets it power from a wire in the trunk. You might need to add a fuse in the rear SAM module. There is a power amplifier in the sub assembly that converts the light signal into an electric signal, then boosts the bass. The enclosure was specially designed for good response in the coupe. What I don't know is if the optical cables are in your car. I also don't know if the HU needs some "version coding" for use with the sub amplifier. Others have told me that cars in Europe are not "pre-wired" and you should try to get the harness with the sub. If you post a picture of the sub, or the connector panel, I'll look for a wiring diagram.
Old Feb 15, 2006 | 03:10 AM
rubensans's Avatar
Brabus K3
I have install it.
I bought the bose sub on e-bay.
Then I bough a 250W kenwood amplifier with remote control that has speaker input.
Will try to get photos and data.
Old Feb 15, 2006 | 09:35 AM
gaiex's Avatar
Here are the pics of the sub:
Old May 5, 2006 | 04:15 PM
gaiex's Avatar
I bougth the sub and it was very cheap (50€), now I'm searching for an aftermarket amplifier to connect it, I'm thinking on a 4 channel amplifier, to connect my front focal speakers and the Bose sub...
Any one know the power of the Bose sub???
I want to know it just to not buy nothing much powerfull and expensive
Old May 5, 2006 | 05:54 PM
patrick_y's Avatar
2006 E55 and 2002 E320
Sigh, and I'm complaining that the HK audio system in my car has too much bass.
Old May 5, 2006 | 07:38 PM
drho2004's Avatar
2005 C230 SS
eh? i think the h/k in my '05 has little bass, even with the bass turned all the wayto 10+. i find the 'sub' to be a joke on that system. good highs, decent mids, but thats about it. too much bass? i've read the opposite most of the time
