View Poll Results: To tint or not to tint
Yes
340
90.19%
No
37
9.81%
Voters: 377. You may not vote on this poll
Tinted Windows W203 Thread - All You want to know about window tinting a C Class
Rating: Thread Rating: 10 votes, 5.00 average.
Old 01-18-2005 | 07:25 PM
  #726
05Css's Avatar
Ok I will answer both your questions from personal experience. That is true that the tint will get scratched with time when open and close the windows. That happened on my 02 C class. I then replaced the tint on 2 of the windows and for the next year no scratches at all. I think when I replaced the tint the previous scratches helped smooth the contacts. So in other words worse case scenario you don't get that mold skin done and the tint scratches you can replace it and my belief is the second time around you should be fine. Now on a positive note I bought a C230 05 and have had it for 3 months now and not one scratch. Not sure if the problem has been fixed on the 05s but seems like it to me. I never had the mold skin put because I really don't want anyone messing with my windows. Plus if it does scratch its only from the inside, the scratches cant be seen from the out side.
Now the second question. I have tinted 1/4 of my front windshield. Yes, the tint will not stick on the dotted areas. So one of 2 things will happen. One is once its placed the heat from the sun will start to form a shape around those dots. If it comes out even then great leave it alone. If however its not even and some parts look nice and some parts look more stuck then just take your finger from the inside and press on the dotted areas till they are all even. One major point, there is no perfection because of the dot's. So if you are extremely picky then don't do it. Again worse case scenario it can be removed. Tint is easy to take off. May cost you a couple of bucks but it wont be too bad. Let us know what you do.
Old 01-18-2005 | 08:01 PM
  #727
LorinserCClass's Avatar
The True OG Modded out W203
They did not put moleskin on mine but this 'fur' type lining....I am getting the car from the shop right NOW, so I will let you know how that works.
Old 01-19-2005 | 11:51 PM
  #728
808_230K's Avatar
'05 C230 coupe
just noticed the scratches on my tint last week... gotta dig up my warranty info to see if the shop can replace it for free. damn if I'm paying twice for that huper optik
Old 01-20-2005 | 02:08 AM
  #729
brabusCcoupe's Avatar
Talking
Someone stated that the moleskin eventually will wear off and the scratches will reappear. Has anyone that has actually installed the moleskin had this problem? Im running into the same problem(the vertical scratches) and dont want to remove the door panel and all that jazz if it will not LAST. Any comment will be very helpful. Thanks
Old 02-10-2005 | 07:49 PM
  #730
jaytee's Avatar
Tint made remote key fob unusable
I just got my car tinted with 15% Llumar tint and was very pleased. Unfortunately there was a drawback, as I can no longer unlock my car using the key fob from far away. The only way I can unlock my car is if I point the key fob at the infrared sensor near the door handle.
I wanted to know if anyone else have had this behavior and I was surprised not to see anything about it when I searched this forum. I called the Mercedes service department about it and was informed there was a technical release put out by Mercedes saying that metallic tint can reduce the AM/FM signals and give you 50% less range with your key fob due to the receiver/antennae for the remote being in the top part of the rear windshield.
In my case, I lost no reception in my radio stations, but lost all reception using my key fob remote. I don't mind having to be close to my car to unlock it, but was just a little disappointed that this wasn't considered when building the car. Being in FL, most everyone has their car tinted, and this is the first time I've seen this behavior on any model. I should be grateful though, as this is the only complaint I have with my car and it's something that I did to it!
Attached Thumbnails Tinted Windows W203 Thread - All You want to know about window tinting a C Class-tint_job.jpg
Old 02-10-2005 | 07:54 PM
  #731
PsssTkiD's Avatar
'02 c230k coupe
i read about this way back, and ppl were only complaining on the coupe. i didnt know that this problem is also on the sedans.. hmmm..but yea....
Old 02-10-2005 | 08:02 PM
  #732
CitronC230K_03's Avatar
2003 Citron Green C230KMT
my coupe is fine and ive had my car tinted for 2 yrs.
i have Llumar as well.
Old 02-10-2005 | 08:41 PM
  #733
tifosiv122's Avatar
SLS AMG | S65 AMG | GL550
My coupe is fine as well...5% all around.
Erik
Old 02-10-2005 | 09:19 PM
  #734
rockintunes23's Avatar
From: Delaware, United States. (First ~little~ state)
Mercedes-Benz
Take the tint off the front two windows and your problem will be fixed.
Old 02-10-2005 | 09:41 PM
  #735
TurboChicken's Avatar
C230 sports Coupe
I am not particularly impressised with my range on my remote but it does work from probably 250 feet away clear shot but by putting the remote under my chin i can add another 150 feet to the range. i think these numbers are right but sometimes i'm not so great about approximating; and that is with a 35% tint all the way around. i wonder if they cut something when cutting the tint or some how screwed something up. try to unlock your car when the remote is near the rear window.
Does anyone elses tint get pretty scratched up from going up and down???
i love the fact i got the tint all the way around but i could live with out the scratches.
Old 02-10-2005 | 10:39 PM
  #736
BklynBenz's Avatar
CL500
any good tint shop that has experience with mb's knows to remove the factory gaskets and replace them with felt or moleskin to prevent scratching
Old 02-10-2005 | 11:44 PM
  #737
tifosiv122's Avatar
...and has lifetime warranty on their product...scratches = new tint job for free.
Erik
Old 02-10-2005 | 11:57 PM
  #738
BlackC230Coupe's Avatar
Former Vendor of MBWorld
Fast Cars!
I had this EXACT problem on my coupe! STFF! :p
Old 02-11-2005 | 12:02 AM
  #739
Zonoz's Avatar
2002 Black C230K
Yeah this is a common problem with tints and with coupes at least, also I'm not sure about sedans but if you don't have moleskin (or other fabric or have it stripped) you're going to develop streaking on your windows from dust particles.
Old 02-11-2005 | 12:26 AM
  #740
rrf's Avatar
rrf
The remote key uses RF and has IR as a backup. The IR is all that is working for you now. (direct line of sight, maybe just 30 feet?)
The RF section uses an amplifier that is connected directly on the rear window.
The problem probably is that the RF amplifier connection is broken. The amp is also used for the radio reception, ... so: Do you notice that the radio works poorly now?
Old 02-11-2005 | 01:08 AM
  #741
Outland's Avatar
2002 C230 Coupe(M111)
I'm not big on tinted windows. I think this thread is kinda funny.
Old 02-11-2005 | 01:11 AM
  #742
ChristianJan's Avatar
c230 Kompressor Coupe
i didnt know that the IR works even away from the sensor!? crazy, i always just pointed in front of the sensor haha. oh well.
Old 02-11-2005 | 06:51 AM
  #743
vadim's Avatar
'19 GLC 300, '19 TM3SR+
Actually, you are not far from truth: IR has a very short range and a narrow angle of operation. You can test your range easily by trying to lower/raise windows from a distance, which is controlled by the IR, not RF.
Old 02-11-2005 | 10:02 AM
  #744
I have a coupe as well and had mine tinted for 1.5 years with no problem at all.
Old 02-11-2005 | 12:04 PM
  #745
i thought the IR range was only like 5 feet or so.
Old 02-11-2005 | 03:20 PM
  #746
Oil Change's Avatar
I had limo tint once. They keys worked just fine.
Old 02-11-2005 | 03:23 PM
  #747
urban legend maybe?
Old 02-11-2005 | 04:02 PM
  #748
SpicyC320's Avatar
2004 C320 SC
When I picked up my car from the tint shop, I noticed that I'd have to stand right next to the sensor to get the doors to lock/unlock - which I wasn't too excited about of course.
Before, I was able to get the lights to blink from the 2nd floor of my office building but after I left the shop, I couldn't get a reaction even when as close as being next to the trunk area.
Fortunately for me this was a temporary thing. After dinner and all that, I tried testing my keyfob again. I was standing a few cars away and was able to unlock the door. "Reception" got better over the next few days.
I've had my car tinted for about 6 months now, and keyfob works almost as good as before (though not as sensitive). I don't think I can unlock the door while from the 2nd floor of this building anymore, but it still works when I'm inside the building on the 1st floor.
Old 02-12-2005 | 03:58 PM
  #749
im getting my car tinted very soon, i just hope it doesnt create any problems like in this thread because my range is pretty far and i like it like that.
Old 02-16-2005 | 01:11 PM
  #750
Dubs42's Avatar
Tinting tip
Im getting my c 230 komp ss tinted monday for $250 with moleskin and full warrenty
i was just wondering if and how much i should to tip? are u even supposed to tip? thanks
You have already rated this thread Rating: Thread Rating: 10 votes, 5.00 average.
Quick Reply: Tinted Windows W203 Thread - All You want to know about window tinting a C Class
