Official S-Class/W220 Style Taillights Thread
#502
01' C32o
#503
MBworld Guru
white and whiter
spray tint can is about $20-25. be sure to use automotive tint cans, not the tint sprays for the model cars because they fade.
lots of masking is needed. after that it's just spray and wait and spray and wait...till it gets to the darkness you want. They dry darker usually, so don't go all "it's not dark enough and use the whole can".
#504
guys seller is not being helpful so I turn to MBWorld ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
http://cgi.ebay.com/ebaymotors/00-01...spagenameZWDVW
ad above says it will fit 2002-2005 but 2005 and 2006 tail lights are the same? I got a 2006 and need to know if this will plug in. It's the NON-LED.
someone please let me know I really appreciate it
#506
2003 C230K SS
There are 2 different versions the 00-04 and the 05-07. I think one has a 4 pin connector and one has a 6 pin connector. I know you can mod the 6 pin to fit the 4 pin and vice versa but it would be way easier to ge tthe right ones. I think the 4 pin is for 00-04 and the 6 pin is for 05-07.
#507
excites your girlfriend
Hey Drex, I got an easier way to change the look of the tails!
Just take one of the bulbs out on the lower row and then it shuts that row off and only lights up the triangle leds on the top! Looks like a real S Class now!
Only the error messages are a PITA to always clear off the MFD.
#508
S Class Tail Lights; do they fit?
This may sound stupid, but I saw this everywhere in this blog; s class tail lights.
Are these lights, you are referring to, looking like s class tail lights or are they really s class parts that fit on c class? (do you follow me??)
For instance, would this fit on my w203? (I know the ad clearly states w220)
http://cgi.ebay.com/ebaymotors/MERCE...spagenameZWDVW
#509
there's already an entire thread on the conversion/swap- i think this is the thread you are looking for https://mbworld.org/forums/search.php
#511
2008 Black Out C350 Saks Edition / 87 VW GTI
Don't think so
#512
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
#513
03 c240
#514
2002 Mercedes-Benz C240 sedan
W220 tail light mod
Does anybody know if the W220 tail lights fit the W203's? If it does what kind of mod would be needed for it to work?
#519
Please also look through the AFTERMARKET MOD / DIY THREAD here:
https://mbworld.org/forums/c-class-w203/108681-aftermarket-oem-modifications-diy-faq-s.html
#521
#522
2003 C240
I think I'm going to be doing a switch from the LED lights to the non-LED ones. My question is, do the non-led lights use the stock bulb holder? If not, can someone tell me how it plugs in? My LED ones have been giving me problems....thanks
#523
Non-LED ones don't use the OEM bulb holder. Separate sockets are wired together to the connector, just like the LED's. I never tried matching up the OEM bulb holder to see if it will work, but it's something you could try, I suppose. Just not sure if the bulb placement matches up.
#524
MBworld Guru
white and whiter
#525
2003 C240
I think I can do without the LED, but the look of the S tails wins over stock for sure
