Clicking Sound On Startup
C200K - Brought in June 2002 Mileage 25000km to date
Two days ago, I noted that there is a click-clack sound coming from the centre console when I started the car. The sound will repeat itself for maybe a minute... then no more. When I restarted the engine there was no such sound.
However, this (click-clack) will repeat when I start the car after a long pause. Why
Tried removing the CD magazine - the sound still persist
Tried switching off Auto central lock - the sound still persist
Check the display- there is No Malfunction.
Apart from the repeating click-clack sound that goes off after a little, there appear to be nothing wrong with the car.
Can someone help?
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Can someone help?
1 Post
'14 GLK250 Diesel
If you mean by "center console" the center stack in the dash [radio, climate controls, etc], then this does ring a faint bell for me - it could be the climate control manipulating the air duct flaps, and doing it repeatedly instead of once and stopping. I thought I remembered reading about this problem somewhere - there might even be a TSB out on it. Check with your service center.
If you mean the center console area between the seats, then I have no idea what's going on, though once again, because of the ducts leading to the rear of the console and the storage area itself, I would not be surprised if the climate control system were the guilty party.
Yes, the centre console is the area where the radio, cassette player and other buttons are. Observed that the sound always click-clack 8 times within 1 minute. That's it. It then goes away. The same sound will repeat itself 8 times again when I restart the car. Funny... consistently 8 times and then go away.
BTW what is TSB?
BTW what is TSB?
1 Post
'14 GLK250 Diesel
Start then with the climate control system - may be the servos that set the air flaps in the system.
Technical Service Bulletin - a broadcast solution to a known problem to all authorized dealer service departments. It means there may be a known fix to the problem. Check with your dealer.
Just to update the forum. Sent my car to MBenz workshop and they had to replaced a broken operating lever. The labour cost is expensive because the whole dash board had to be removed to establish the real problem. The operating lever was cheap. Finally, no clicking sound anymore. Thank you very much for the advices rendered.
Aren't common problems (or well-known problems) should be paid by MBUSA due to poor quality items even if you are out of warranty? we are not talking kia or daewoo here. I think the C-class has a lot of those "common problems" and sucks
I agree, I think it's the servos in the air duct system. The ones in the E Class (W210) and S Class (W140) are especially loud. Haven't heard it from my C yet.
I have to say that I agree with fanito here, these C Classes seem to have a rather large share of small electronic jitters. However, let's look at it this way. What can you buy that handles like this car, has an audio system like this car, and will mechanically last as long as this car, for this kind of price? Not much, just a Subaru, BMWs have small electrical problems as well. Lexus IS is a good competitor though.
