CEL for rear O2 sensor
Old Sep 28, 2005 | 04:38 PM
hobie's Avatar
'02 C230K
I had a parts store pull the code for me. Some posts suggest that this may be triggered by a bad MAF. Before I go to the dealer I'd like to know a couple of things: Is the O2 sensor part of an emmissions warranty (75k on car)?
MAF was replaced once already before 50K-Is part warranted?
Is the code a hard set or would it clear after a few cycles?
Any additional feedback would be appreciated.
Old Oct 3, 2005 | 07:31 AM
hobie's Avatar
'02 C230K
back to the top. anybody?
Old Oct 3, 2005 | 02:38 PM
Buellwinkle's Avatar
Much of that is covered under the emmissions warranty so I would start there. You didn't say what codes you got and if you don't have a scan tool to check codes and sensor output and understand what's normal you'll just be spending lots of money chasing maybes. Think about it, just parts costs for a MAF is $350, O2 sensor $180 each (2 of them), then what else will you replace?
Old Oct 3, 2005 | 10:30 PM
hobie's Avatar
'02 C230K
Hey Buell ! How the hell are you? Thanks for pitching in again. I'll try to get more facts. Check the CLK forum for my only post there, I value your opinion.
Old Oct 5, 2005 | 10:12 AM
MBtech1's Avatar
2011 C 300 4-Matic
The MAF will not trigger rear 02 sensor codes. Most likely its a faulty 02 sensor. The rear 02 sensor only monitors if the catalytic converter is working properly. If the cat isnt doing its job, it will set a cat inefficiency code. If the code just says problem with the rear 02 sensor, its probably just that.
Old Oct 6, 2005 | 11:02 AM
hobie's Avatar
'02 C230K
Thanks MBTech1, I'll double check the code and let you know what happens.
Old Oct 19, 2005 | 05:56 AM
hobie's Avatar
'02 C230K
Just to wrap this up. I found an independent shop with the MB computer. They replaced the rear O2 sensor that set the code. I had the front replaced as well, based on their reccomendation. Thanks for all your input.
Old Nov 1, 2015 | 02:23 PM
vsix's Avatar
JBs C63 PP( wifes car ), Mc Laren Pxx(toy), 2013 Mustang GT 5.0 ( DD ), ML 6.3 ( winter DD )...
Like this log here, correct?
But what exactly is the problem when both pop up?
O2 or Cat's?
