Y Just Install a K&N When U can Have Cold Air......
"02" C230K Coupe
I just got done installn my intake system, took it for a test drive and the power difference is noticeable. What do u think ?
Originally Posted by Usmc2k
What do u think ?
A box on 4 wheels
Originally Posted by mleskovar
I think it will decrease your power because the intake is now taking in hotter air. Or did you mean the "noticeable" difference was less power Does look different though. I believe form follows function so it doesn't look better to me.
"02" C230K Coupe
the filter is right where the stock opening is for the stock intake. So it is getting in cold air. But yes it is suckn n more air so it is a mix of hot and cold. Mostly cold do to the air flow from the stock intake opening.
Originally Posted by Josh K
It's more of a WAI (warm/hot air intake). Do a dyno and see if you've gained anything.
I just don't see an intake that long actually giving you real grunt until the top end, but isn't that where these smaller engines already prevail?
C55 ///AMG, 535xi
Originally Posted by Cappa26
I'm pretty sure it increases the performance, not decrease, can anyone confirm this?
it kinda looses that 0-15 power, but after that it picks up and has this crazy intake sound...im assuming this is the same on the C230ks, kuz I have a K&N cone on my ML500
1 Post
2002 C230 Coupe(M111)
Originally Posted by ricky.agrawal
Do you think he'd still see any gains?
Long Intakes= Improve torque on the bottom end.
THe above is irrellevant with forced induction. End of story.
1 Post
There's no way this thing is an improvement over the stock system with a K&N. Yeah, it makes more noise, and there's nothing wrong with that either. But I seriously doubt any HP increase...
Originally Posted by Outland
Short Intakes= Good top end
