Anti-Sway Bars R&D for C32/C240/C320/C230k
well, unless they maintain the harmonic balancer/damper, there is no way i'm getting them...
I'm with you, young!
what happened to xmas?
what are you referring to when you say "our bars"?
the kleemann's are 24/22mm
the evosports' are 24/19
are you kleemann/eibach?
Mach430, yes, they have them in their warehouse, or at least they say they do.
I checked with my local tire shop and they have the Eibach Anti-Roll kit available now for $350. PM/E-mail me if you're interested as maybe I can get it a little cheaper if we do a group buy.
I'm interested if the Eibach ones are not pink/purple
Both bars are about 20% stiffer than stock. The front bar is 3-way adjustable, and the rear 2-way. Each adjustment is about a 5% increase in stiffness. The bushings are similiar to factory bushings, in that they only need to be lubed about once a year, as opposed to urethane bushings which require lubrication approximately every 3 months.
OK, let me try to understand this. KLEEMANN sway bars are made by Eibach and as I remember they are at about $450. Now you're saying the Eibach ones are available for $350. Do you mean Eibach make their own sway bars for the Coupe for $350? If so, what is the spec for the Eibach's own version?
More info on our EVOSPORT Adjustable Anti-Sway Bars:
