How to put C55 spoiler on!?
Old Nov 14, 2005 | 01:34 PM
MercedeSC32's Avatar
'07 SLK55, '04 C32, '04 Escalade
Hey guys, i have a question about how to put a c55 spoiler on to my car...what are the neccessary steps to it? like prepping? what tape do i use? what should i do after puttin the lip onto the trunk, should i not drive for a while?
Old Nov 14, 2005 | 04:18 PM
advans's Avatar
C55 ///AMG, 535xi
do a search, As i remember, RazorFish that had a few pictures.... of his C55 with some clamps, but I remember some old car, theres a type of silicone u can use
Old Nov 14, 2005 | 04:34 PM
CitronC230K_03's Avatar
2003 Citron Green C230KMT
FrankW also installed it on his C32
Old Nov 14, 2005 | 06:13 PM
appleguy's Avatar
2008 BMW 335i Convertible; SOLD*2004.5 C230 Sedan*SOLD
If it's from the factory, then it should have the adhesive tape already on it. The MB factory does a real nice job with the adhesive since it is all die cut to fit the contours of the wing perfectly. They even have some pull tabs on it.
When I had mine installed, the body shop prepped the trunk surface with a wax remover/degreaser. They then peeled back the release liner from the tape and carefully applied it to the car.
I also believe that the factory wing has some screw bosses in it as well if you wanted to drill through your trunk and screw it down... i opted not to do this.
Hope this helps!
Old Nov 14, 2005 | 06:51 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
3M tapes. clean the surface of which you'll be puttin the spoiler on. spray 50/50 windex/water solution on that surface and put on the spoiler so you can adjust it if it's a little off. leave the car in garage for at least 12hr to let dry. clamp the sides if you wish, some find it necessary to keep the side down.
Old Nov 14, 2005 | 07:35 PM
how should i clean it? what type of cleanin products? degreaser? what kind? wax remover??????
Old Nov 14, 2005 | 07:36 PM
pokerFACE's Avatar
^^ it is not a factory spoiler, thats why it doesnt come with 3M tape.
---i wont say anything more!
Old Nov 14, 2005 | 08:30 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
warm soapy water will work
