What are Bi Xenons?
Old Dec 3, 2005 | 11:56 PM
stephen4785's Avatar
2001 C320
What are Bi Xenons?
I keep reading about peoples favorite mod is Bi Xenons but then I read another post that said there not a mod
Old Dec 4, 2005 | 12:05 AM
JeT's Avatar
JeT
Just a matter of semantics. It is a mod in the sense that if you did not buy the car with the bixen option then you are modding by installing them afterwards. They are not a mod in the sense that the bixens are OEM and are not manufactured by an aftermarket manufacturer.
Old Dec 4, 2005 | 12:06 AM
2001 C320
Would you please explain what they are? I know their headlights but other than that I have no idea.Thanks
Old Dec 4, 2005 | 12:10 AM
EV0LVE's Avatar
F10
bi=dual. xenon=xenon charged headlight a.k.a high intensity discharged h.i.d.
JeT's Avatar
JeT
Have a read of this thread and this thread, in particular MBenzNL's posts.
Essentially a movable plate creates the desired beam pattern. When the plate is raised, it produces a low beam light and when it is lowered it makes the high beam. The bulb used is a HID bulb so the color of the light is the same from low beam to high beam.
Bix provide much more light than a halogen using much less power. They are extremely bright and thus much safer for you during night time driving.
Old Dec 4, 2005 | 12:15 AM
jsloan01's Avatar
2025 CLE 53 AMG
"puts on flame suit"
Old Dec 4, 2005 | 08:36 PM
Cappa26's Avatar
A box on 4 wheels
Old Dec 5, 2005 | 01:17 AM
2001 C320
My car is an 01 was that an option for that year or did it come later?
And is it even an option or is it standard equipment?
Old Dec 5, 2005 | 01:59 AM
JeT's Avatar
JeT
Can you please put your location in your profile so that we know what sort of spec your car is. More and more new members do not put their location...not sure why.
Bixens are an option on the W203. If you are in the US then you can get them pretty easily from Steve a.k.a. MBenzNL. I am assuming you are not in the US because W203s were not available in the US until 2002. If you are in UK or Australia, they are alot harder to come by becasue bixens for a right hand drive car (UK Spec) are in very short supply...and if you have a coupe then it is nearly impossible to get them.
Old Dec 5, 2005 | 10:58 PM
2001 C320
Fixed
About how much do they run for my car? i just said w203 cause I thought there wasnt a difference but apparntly there is.Thanks
