Air Filter Replacement = HP Gain?
Old Dec 18, 2005 | 05:13 PM
MHPHOCKEY's Avatar
2014 Audi S5 Cabriolet 3.0T
If I replace the air filters on my 2006 C 230 (V6) with the Green or K & N will I gain some power (or at least feel lilke I do)? I gotta make this thing faster without spending a fortune (my forture will go to some rims haha)!
Mike
Old Dec 18, 2005 | 05:48 PM
advans's Avatar
C55 ///AMG, 535xi
Mike
yeah it'll make the car go really fast!!! it will give u atleast a + 1.0hp gain
Old Dec 18, 2005 | 06:08 PM
MHPHOCKEY's Avatar
Advans: Have Car Face wall, about 200ft away, Floor Gas for 30 Seconds, will deploy Airbag
Sarcasm appreciated!
Old Dec 18, 2005 | 06:26 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Advans: Have Car Face wall, point at MHPHOCKEY from benzworld about 200ft away, Floor Gas for 30 Seconds, will deploy Airbag
Old Dec 18, 2005 | 07:22 PM
white_w203's Avatar
is SOLD
faster.........ummmm the only mod you can get is intake and exhaust. proly a 5hp gain, but you won't "feel" the difference.
Old Jan 23, 2006 | 08:05 PM
c230K415's Avatar
AMG GTS
Horsepower gains eh?.....get a guy to push your car while you move....more gains than bothering with a goddamn custom intake and a K&N drop in
Old Jan 23, 2006 | 09:02 PM
BabyBenz6spd's Avatar
2005 C230 Sedan 6spd
Damn...just answer the question
I have a Drop in K&N filter, I notice these things after install
-RPM rise faster after 4000RPM all the way to Redline (Paper filter made the engine feel like its outta breath after 4000RPM)
-Better engine response
-Car feel more alive (HP gain?)
-As far as how many HP gain, I never dynoed so I wouldn't know
-change the tone of the engine, just a little bit but Its noticeable to me.
Cappa26's Avatar
A box on 4 wheels
Mike
I just dropped in a K&N filter to tell you the truth youll feel a .1 % difference only. The sound will change a little bit a high rpms, but other wise it wont do much. 1-2 HP gain for most people I believe.. if its 0 hp gain no pt in swapping it in.
Old Jan 23, 2006 | 09:39 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Y'all have to remember he's got an '06, so the effects he feels may not be the same.
Since you've got a NA (normally aspirated) V6, I'm not sure if there are any "cheap" power mods for this engine. If you change the filters, you will most likely not gain any power. A lot of the 240/320 owners changed their stock filters to Green filters, but that wasn't the reason they felt power increase either.
For the most part, changing your air filter won't give you more power, but since you have a V6, it's quite possible that there will be more power mods in the near future. No matter what, in order to gain significant power, you'd have to shell out some $$$. You say that you want to make your car faster without spending a fortune. First of all, what is a fortune to you? If that means $100-200, then I'm sorry to say that you're **** out of luck. If that means $1,000-2,000, you might have something to work with in the $500-600 range (i.e. exhaust, ecu flash, maybe future C.A.I. will be designed).
It's all just a matter of how much you would be willing to spend and if it's available to you (and even then, if you really want to put the effort in to search for manufacturers that are willing to make products for engine, you could always do that).
Old Jan 23, 2006 | 09:46 PM
ctC230K's Avatar
excites your girlfriend
you forgot a chip?
Old Jan 23, 2006 | 09:59 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Originally Posted by ctC230K
you forgot a chip?
Don't think that whitey forgot but you did. OP is talking MY06.
Old Jan 23, 2006 | 10:04 PM
ctC230K's Avatar
they don't have them for 06 yet? eh well eventually
Old Jan 23, 2006 | 10:20 PM
c230K415's Avatar
AMG GTS
This might have been posted several times but the search feature just kinda sucks....well my question is...what screwdriver head do you get to removed the cover that encloses the air filter? where would you get the screwdriver head and how would you ask the workers there for it?
Old Jan 23, 2006 | 10:22 PM
Capt Nemo o2's Avatar
'05 C230SS 6MT, 1966 Triumph TR4a IRS, Shelby Cobra 427 Supercharged
If I remember correctly it is a #10 Torx head.
Old Jan 23, 2006 | 10:29 PM
c230K415's Avatar
AMG GTS
thank you very much. nice rides by the way *re-reads your signature* damn man.
Old Jan 23, 2006 | 11:19 PM
NP! And thanks!
Old Jan 24, 2006 | 02:09 AM
pshek's Avatar
2003 C-Class Sportcoupe
You might notice more difference with foam air filters compared to the K&N paper filters. ITG makes foam air filters; more airflow and better filtering.
Old Jan 24, 2006 | 07:31 AM
C-Dub's Avatar
C230 WZ - Six Speed
K&N replacement improved throttle response. Don't know if improved HP, but makes you want to gas it all the time!
Old Jan 24, 2006 | 08:50 AM
There for a negative side effect of having a high flow filter
Old Jan 24, 2006 | 10:41 PM
Outland's Avatar
2002 C230 Coupe(M111)
Don't forget fouling the MAS if you don't service it correctly.
Cmon...who is gonna notice even 3HP? The change in temperature each day causes more of an output fluctuation. Buy a big fat bottle of nitrous for that V6 C230...bout all you can do at the moment.
Old Jan 24, 2006 | 11:21 PM
They could also buy the internals from the 3.5 motor (or is it not like the 240 and 320, same block different stroke length and pistons?)
Old Jan 25, 2006 | 12:41 AM
richardsayzz's Avatar
-Black- '05 C230 Kompressor SS
The K&N filter for the 05 c230 comes preoiled right ?
Old Jan 25, 2006 | 09:29 AM
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
funny thread.
Old Jan 25, 2006 | 05:14 PM
c230K415's Avatar
AMG GTS
Old Jan 25, 2006 | 06:36 PM
ctC230K's Avatar
no when you get it you just have to soak it in some of this for an hour.
