Mobil One
Old May 13, 2006 | 11:54 AM
  #51
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Originally Posted by nlpamg
so the manual says 0W-30...
I went to pep boys and they didn't have it, they said they never heard of 0W-30 and asked what car I had and they were like that's why.
Yeh, go ask for inverted torx sockets and get the same response...I did. Kragen sells 'em though in a set for less than 20 bucks...but doubtful they even know it...
Ok back to oil.
0-40 M1 is what I run. But you can use other grades and brands according to the booklet supplied with the car...
Old May 13, 2006 | 03:30 PM
  #52
patrick_y's Avatar
2006 E55 and 2002 E320
Yea, just make sure that on the back, it says "MBZ 229.5 SPEC" which means that it meets Mercedes Specifications on the oil.
Old May 27, 2006 | 01:29 AM
  #53
jan ken po's Avatar
'05 SS Brillant Silver
Boy this sure was an entertaining thread...I guess STFF is good for something.
So from what I gathered so far...since my dealer used a filter with part number 271-180-00-09 (non fleece) then dumped 8qts of Mobil 1 10W40 in there on my last oil change....then it is not too bad??
However, the preferred/recommend combo is a fleece filter (000 180 26 09) with 0w-40 correct?
Which effect pisses me off because they "sell" you on the you won't need another oil change for 12k miles, but then don't put in the parts to make that happen....sunza-byches!!!
Old May 27, 2006 | 10:37 AM
  #54
jan ken po's Avatar
Ahhh gets even better...so I called parts. They don't have the fleece version only the non-fleece. And of course he had no idea what I was I talking about when I said fleece. LOL
Old Apr 9, 2007 | 12:35 PM
  #55
Benzino's Avatar
03 c230
my mechanic told me to put in 5w- 30, so is that the wrong kind of so. cali? and 6.5 quarts?
Old Apr 9, 2007 | 03:10 PM
  #56
kickR's Avatar
'14 CLA 45
Since this thread was dug up again:
I got the message to fill up 1qt by the next tank stop. Anyone know how much is left when this message shows up? Instrument cluster even after the elec. check jusy says fill it with 1 qt but doesnt tell me how much is remaining
Old Apr 9, 2007 | 04:46 PM
  #57
wingless's Avatar
Debadged 6-Speed '05 C320 Sports Coupe
This post has the answer.
Old Nov 7, 2007 | 02:00 AM
  #58
Benzino's Avatar
03 c230
Ok I have always used 10w-30 but your thread says not to. What do I use and how much then? I drive a 03 kempressor with 80k mikes.
Originally Posted by wingless
This link has very complete listings for all the MB oil classifications. As previously stated, MY '05 vehicles require MB sheet 229.5 oils. Also, MY '98 through MY '04 require sheet 229.3 oils, but may use 229.5 oils, but those require the fleece filter.
Of particular interest is this information, contained within the link:
some oils which are not recommended:
Mobil 1 SuperSyn 0W-30 SL/SJ/CF A1/B1/A5 9.7 doesn't meet 229.1 nor ACEA A2 or A3
Mobil 1 SuperSyn 5W-30 SL/SJ/CF A1/B1/A5 9.8 doesn't meet 229.1 nor ACEA A2 or A3
Mobil 1 SuperSyn 10W-30 SL/SJ/CF A1/B1/A5 10.1 doesn't meet 229.1 nor ACEA A2 or A3
These 3 oils do not meet MB spec of > 3.5 cP for high temperature high shear strength.
Old Nov 7, 2007 | 12:44 PM
  #59
wingless's Avatar
It is possible to use either the Mobil 1 5W-30 or the Mobil1 10W-30. While it is possible to use those oils, those oils do not satisfy the requirements MB defined for your vehicle.
An alternative option would be to utilize an oil that satifies the requirements defined by MB. For MY '98 through MY '04 vehicles, those require sheet 229.3 oils, but may use 229.5 oils, but those require the fleece filter. One oil that satisfies the MB 229.5 standard is Mobil1 0W-40.
