Quick Question?
Old Jul 28, 2002 | 07:41 PM
Iceman's C230's Avatar
09' BMW M3 E90
Quick Question?
I just pick up a new issue of CAR magazine. It's an import magazine from Europe. Anyways i was just looking through the pictures when i came across a C230k. It had 197BHP 207lb-ft and top speed 149MPH.
So why does our car's have 192hp 200lb-ft and a top speed of around 133?? The engines are the same. What is different?
Old Jul 28, 2002 | 07:46 PM
blueC230K's Avatar
2002 W210 M112 | 2021 X247 M270 | 2015 Audi SQ5 | 2015 VW Golf R
Lightbulb quick answer
Hey Iceman, it's because the U.S. spec has the speed governor. You can get it re-program from the tuner companies.
Old Jul 28, 2002 | 07:49 PM
Lynn's Avatar
Quick answer.
One Deutsches Institut für Normung (DIN) horsepower is equal to 0.986 Society of American Engineers) horsepower. 197 DIN hp equals 194.242 SAE hp. For the new 1.8 liter coupes, 192 DIN hp equals 189 SAE hp.
The Euro cars do not have the electronic speed limiters found in North American cars. The top speed of Euro spec C230k's is aerodynamically limited.
Old Jul 28, 2002 | 07:50 PM
TimmyC230boy's Avatar
From: Sitting behind thing freakin desk of mine. Dreaming I was playing my Taylors, and driving my Benz. Long Live The VRAA!!!!!!
C230 Sports Coupe
so for the Euro spec coupe putting on a pulley or another HP upgrade raises the top speed also.
Old Jul 28, 2002 | 07:52 PM
Lynn's Avatar
It does right up to the point it hits the rev limiter.
Old Jul 28, 2002 | 11:37 PM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
Re: Quick answer.
They do, at 240 km/h
Old Jul 29, 2002 | 01:36 AM
Freddy's Avatar
Re: Re: Quick answer.
The C230K is not electronically limited in Europe. The speedlimitation on many cars is 250km/h but the C230K will not reach that.
Old Jul 29, 2002 | 01:51 AM
vadim's Avatar
Re: Re: Re: Quick answer.
See below: even the new 1.8L version reaches 240km/h, let alone the more powerful 2.3K:
Motordaten und Fahrleistungen
Anzahl Zylinder 4
Anzahl Ventile 4
Hubraum in cm3 1.796
Verdichtung 9,0:1
Nennleistung in kW (PS) 141 (192)
Nennleistung bei U/min 5.800
Nenndrehmoment in Nm 260
Nenndrehmoment bei U/min 3.500-4.000
Kraftstoffverbrauch / CO2 nach RL 1999/100 EG
mit Schaltgetriebe [l/100 km] bzw. [g/km]
innerorts 13,1
außerorts (EUDC) 7,0
gesamt 9,2
CO2 221
mit Automatikgetriebe [l/100 km] bzw. [g/km]
innerorts 13,2
außerorts (EUDC) 6,7
gesamt 9,2
CO2 221
Beschleunigung 0 - 100 km/h [s]
Schaltgetriebe 8,1
Automatikgetriebe 8,2
Höchstgeschwindigkeit km/h
Schaltgetriebe 240
Automatikgetriebe 236
cw-Mittelwert 0,29
Old Jul 29, 2002 | 02:13 AM
vadim's Avatar
Sorry, didn't pay attention: 250km/h is the Euro speed limitation, not 240. But with the a pulley upgrade the c coupe is quite capable of doing that ))
Old Jul 29, 2002 | 08:09 AM
Freddy's Avatar
Re: Re: Re: Re: Quick answer.
I am no expert, but I don´t think a pulley alone would make a coupe go faster than 250km/h
Old Jul 29, 2002 | 08:26 AM
DtS's Avatar
DtS
C200 Kompressor
Re: Re: Re: Re: Re: Quick answer.
Maybe not. Considering the C320 tops out at 245 km/h with 218 hps and slightly lower cW....
Old Jul 29, 2002 | 08:43 AM
C230 Sports Coupe
well if it is drag limited, any increase in HP should theoretically increase top speed, but i dont know to what extent it would.
Old Jul 29, 2002 | 09:49 AM
jswedberg's Avatar
C32 AMG
I know that (theoretically) maximum (drag-limited) speed goes up to the cube root of the horsepower.
So, for instance, going from 130 to 150 mph would require (150/130)^3 or about 1.54x as much horsepower (or maybe about 300 hp.)
Assuming you don't get rpm-limited.
Old Jul 29, 2002 | 10:06 AM
C230 Sports Coupe
yeah I knew there was a formula out there but wasnt sure what it was. Thanks,
So the pulley might not get you a higher top speed but it will get you there faster.
Old Jul 29, 2002 | 11:06 AM
vadim's Avatar
It tops at 240 km/h with 192HP (197 DIN BHP). A pulley adds 25-30HP. I beieve it should be plenty for another 10 km/h.
Old Jul 29, 2002 | 11:17 AM
vadim's Avatar
From what I heard, it should be a square function of the speed ratio.
192 * (250/240)^2 = 208HP.
The cube would give 226HP, which is still feasible.
RPM may be an issue, though, as 250km/h in 6th gear would be in the 5800 RPM area.
Old Jul 29, 2002 | 03:46 PM
preyx's Avatar
'02 C230K Coupe
Hey, as long as it doesn't hit redline...
