Problems with tailgate (trunk) on coupe?
Old Jul 29, 2002 | 03:18 PM
latent's Avatar
Do I have a problem with the tailgate (trunk) of my coupe?
I use the recessed slot to firmly throw the tailgate down. It appears shut. But on several occassions overr the last few days, I go to drive off and BEEP! warning on the dash that the rear end is not shut !!
Is it just a matter of getting used to it?
Old Jul 29, 2002 | 03:36 PM
session's Avatar
2007 VW GTI
i usually have to "throw" the hatch shut when using that recessed handle. it has never failed. you just have to use a bit of force.
Old Jul 29, 2002 | 03:41 PM
preyx's Avatar
'02 C230K Coupe
Actually, I have sometimes gotten the opposite result when "throwing" the trunk. It actually bounces back without latching! What I do on my coupe is just let gravity pull the lid closed, with minimal assistance. I'm not sure if this'll work on the sedans though.
Old Jul 29, 2002 | 03:47 PM
pixelpro's Avatar
c230k
two stages of shut
on my car it seems that there are two levels of shut(ness). if i just let the hatch fall it latches but not completely, i need to use a good deal of force to get it to fully latch down.
Old Jul 30, 2002 | 02:28 AM
vyse's Avatar
Huh, I find my trunk very easy to close. I also just let it close with gravity. Well, and a light push. It closes completely with a soft thud. I found it weird the first few times, it's so quiet it seems like it doesn't close but it's perfectly fine.
Old Jul 30, 2002 | 07:21 AM
dmichael's Avatar
2007 BMW 328xi sedan
I used to have to SLAM the hatch shut or I would get a warning. I asked the dealer to fix it and they adjusted it so low, it was scraping paint. So I had to get a #30 Torx screwdrive and adjust it myself - took about 20-30 minutes of fiddling with to get it just right. Now it closes tight the first time(even with both windows closed) with gravity. You dealer may be competant enough for this task on your next service, but if not, give it a try yourself. PM me if you need help.
Old Jul 30, 2002 | 07:25 AM
avlis's Avatar
2008 VW GTI
Mine closes with gravity also. No throwing.
Sounds like: "Whump!"
Old Jul 30, 2002 | 09:17 AM
Lynn's Avatar
Mine, too. It shuts very nicely.
Old Jul 30, 2002 | 10:55 AM
session's Avatar
2007 VW GTI
when i said "throw" i didn't mean very hard... i meant the action is like throwing it down. i don't have to pull very hard on it -- newton's laws are my friend.
