Pulls to the right...
Old Jan 17, 2006 | 07:07 PM
Benzino's Avatar
03 c230
Ok, Im not sure what im trying to say so please excuse me and try to fill in my blanks. I got some new tires today and after that immediately got my alignment done because my car was pulling to the right pretty badly and still is. When i got my alignment done i was talking to the guy and he said that i was still goign to have slight issues with the car pulling to the right because of the control arms couldnt be straighten out anymore or something like that and to see if they mad a aftermarket _ _ _ _ _ and that should solve my problem
Old Jan 17, 2006 | 07:29 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
sounds like the mechanic messed it up during tire installation...
Old Jan 17, 2006 | 08:16 PM
mleskovar's Avatar
'17 Jaguar XF
Camber bolts/kit? That's what they changed on my car when it was pulling to the left. Standard MB part that I believe comes in different correction increments.
Old Jan 17, 2006 | 08:35 PM
mick1's Avatar
2005 C320wz
my car used to pull to the right a little but after I changed all the tires, it now goes straight like an arrow.
Old Jan 17, 2006 | 09:10 PM
white_w203's Avatar
is SOLD
re balance the tires. or a weight might have fallen off the rim.
Old Jan 17, 2006 | 10:16 PM
ctC230K's Avatar
excites your girlfriend
mine pulled to the right when it was new, i got an alignment and it still pulled a little. someone said it could be the low profile tires following the curve of the road? doesn't sound too believeable to me.
Old Jan 17, 2006 | 11:20 PM
c230 o5's Avatar
BMW 135i
ok listn 2 me my rear right tire was mess up i hit a pott hole or something made my tire move fowrd next to the right side my car was moving all the way to the right i even had to hold my steering wheel to the left side 2 make it go straight , MB dealer told me some metal part was bent they replace it with some other part and they alignmentas well now its going good they gav me e the paper work that it was done in detail in a BAR GRAPH of how my weels are now
Old Jan 17, 2006 | 11:29 PM
mleskovar's Avatar
'17 Jaguar XF
Next time include all the information and save everyone time. Duh, you wacked your wheel and bent stuff is important information.
Old Jan 18, 2006 | 12:16 AM
Benzino's Avatar
03 c230
Today, i got my wheels and alignment done but when i got on the fwy it pulled to the right and later on in the day i drove it and it seemed to be going straight but idunno i shall see.
Old Jan 18, 2006 | 12:24 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
depending on your tires the car will follow the road due to many freeway in the States have grooves cut in them and a lot of sports tires will follow these grooves.
Old Jan 18, 2006 | 02:17 PM
MVillareal's Avatar
2005 C320 Sport, 2006 ML350 (the wife)
I had right-pulling problems about 9 months after I got my 05 c320. The dealer installed a camber correction kit and problem went away. It was also installed as part of the new car warranty. Hope this helps.
Old Mar 2, 2006 | 04:58 PM
NO_WUR_E's Avatar
'06 E350 Iridium Silver with pano
I just bought a set of 18" C55 AMG rims from someone. Rims are not bent and tires have only a few hundred miles on them. After they were installed yesterday, replacing my stock ones, the car now pulls to the right. Tires are PZERO ROSSO 225/40 ZR18's on the Front and 245/35 ZR18's. Is is the tire pressure which I have yet to check? Is it the tires which are consider ultra high performance tires that hugs the road????
Do I need an alignment to correct this problem? It maybe pulled slightly to the right prior to the switch...which seems to be a common problem stated in other threads. However, it seems pretty noticable now. Any feedback is appreciated.
Old Mar 2, 2006 | 05:32 PM
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Wuddup, man.
When's the last time you had an alignment done? If it's been a while and you already noticed the pulling before you installed the rims, I would have it realigned. It's possible that the pulling is more prominent now that you are running higher performance tires.
The diameter of the tires you chose is dead on according to the tire calculator, so I can see the choice of tire size being the cause. Assuming that the tire pressure is good in all four tires, then there's not much else I can think of, bro.
Old Mar 2, 2006 | 05:37 PM
NO_WUR_E's Avatar
Originally Posted by drexappeal
Wuddup, man.
Hey Drex, what's up bro!
Car is one year old this month at +15K miles. I just called the dealer and they are charging $220 for an alignment. I'll check the tire pressure tonight and go from there. Thanks for chiming in!
Old Mar 2, 2006 | 05:55 PM
drexappeal's Avatar
Wait, they're charging how much? Well, I kinda understand because from what I understand, MB has a special alignment tool, but...I would try and find an independent MB mechanic that'll do it for cheaper.
If worse comes to worse, go to a tire store that'll do an alignment for you. They normally charge around $40-50. Only thing is, I'm not sure if it will be "properly" aligned because of that alignment tool that MB uses, but it should still be better than what's happening right now.
