aaack! One Whiper not working!!
It was a freezing morning... went to whipe, and none of the whipers went, so obviously it must be iced over...
I loosen the driver side wiper, and then I go for the passenger.
the 2nd one was really iced on so I didn't wanna rip the rubber, so I left it.
I must've whiped only 4-5 strokes that whole drive, the next day, when all is melted and the weather a LOT better, I whipe and only my drivers side one whiped.
Went to check, and the passenger side whiper can now be moved freely with little resistance... Whereas the drivers side one is hard and cannot be budged unless I do it from the controls in the car...
Needless to say, my 2nd whiper doesn't work now!!..
Is it 2 independent motors, so motor 2 is burnt out?
or is it just a stripped nut or something simple??
thanks... How can mercedes not account for whiper obstructions?!?!
I swear any other car, that is 3-4 yrs old, this would not happen to...
And I say this, b/c this is one of MANY little things to go!!!
so far, I've had a bit of input, it is 1: A loose bolt (doubtful from what I saw)
2:
Gear stripped... approx $600 Fing dollars.
Pardon my french...
Im thinking of just tying a string to it, and pulling it when I need it!!!
Using your wipers while they are frozen to the windshield can result in a torn wiperblade (by far the cheapest damage) stripped gearing OR snapped wiperarms (not likely on a mercedes - way more common on other cars)...
greetingz,
greetingz,
Exactly. The damage is done by your ignorance.
Be glad MB chose to use a strong motor to keep at least one of your wiper running instead of burning out. Hopefully the gear attached to the motor side is ok so you just have to replace the wiperarm (Shouldn't cost $600). Remove the bolt and see it for yourself.
2:
Pardon my french...
was wet overight.
temp drop, so drozen to windshield.
freed one wiper.
2nd was too frozen to free.
I did a TOTAL of 3-4 SINGLE WHIPES.
I dont think that is ignorant, and 2 were done initially without realizing whipers were frozen.
2 more after while driving, 1 to see if it freed yet with heat on windshield, 2 to clear a small obstruction on drivers side.
If u people consider this ignorance, wow....
Anyways, my luck, it was just a BOLT!
woohoo...
