can i install subwoofers and new speakers while using my COMAND?
Old Aug 1, 2002 | 01:16 PM
Carter's Avatar
2002 Mercedes S500
i wanted to upgrade my system in my S500. i wanted to add two subwoofers, an amp, and new speakers.... is it possible to do all this while still using your COMAND system? thanks guys!
Old Aug 1, 2002 | 10:00 PM
Silver_Lana's Avatar
It should all be the same from what i understand but you should ask this question in the Audio and Electronics forum. It wil get more attention there.
Good luck.
Old Aug 2, 2002 | 03:47 AM
Phill B's Avatar
2 ways.
1) Get an electrical technician to wire on the RCA pre-outs to the original command deck in the car and amps/processors plugged into the RCA's.
2) Buy any of the Audio Control processors that have high-level inputs (i.e. speaker inputs). These units will then convert the signal to RCA outs for the amps etc.
http://www.audiocontrol.com/caraudio.htm
Any of the processors that have "Speaker level inputs" will do the job.
Good luck with it.
Old Aug 2, 2002 | 08:45 AM
JeT's Avatar
JeT
Originally posted by Phill B
2 ways.
Good luck with it.
Phill, would the guys at Queensland Audio know how to do this?I'm actually quite happy with the Audio 10 but may want to upgrade in the future. It would be good to have a mob that has done a mod like this before. I'm based back in Brisbane again now.
Old Aug 5, 2002 | 06:32 AM
Phill B's Avatar
Hi Jet,
Queensland Audio is part of the Northfield Car Sound group. Back in the days that I played with car audio gear I dealt with Q.Audio for purchasing Soundstream equipment and Northfield up at Nundah for installation.
Enjoy....
Old Aug 5, 2002 | 05:44 PM
Moser's Avatar
C320
2 ways.
Good luck with it.
If you get COMAND with BOSE, does that come with RCA's or is the BOSE amp connected differently?
Old Aug 5, 2002 | 08:56 PM
c230ksc's Avatar
2002 Mercedes Benz C230 Kompressor Sports Coupe
I HAVE A SYSTEM + COMMAND CONTROL WORKING
Hey guys whats up, i installed a system for $2000... It is one 12" JL AUDIO W7... top of the line subwoofer.... 2 rockford amps 1000 watt... boston acoustics pro series 6.53.... and fiberglassed the box, i can get the pictures for you soon, but i did it down at SOUND SOLUTIONS, and i can use the steering wheel controls still.... This is a 4000watt stereo system in my c230 sports coupe Kompressor... SOUNDS BOOM'N
Old Aug 5, 2002 | 09:08 PM
Moser's Avatar
C320
Re: I HAVE A SYSTEM + COMMAND CONTROL WORKING
So how did you connect up the COMAND Navigation system to the Rockford amps? Speaker level or Line inputs? How did you convert?
Old Aug 6, 2002 | 12:11 AM
c230ksc's Avatar
command control set up
I TOOK IT TO A STORE CALLED SOUND SOLUTIONS, DOWN IN BALTIMORE ... THEY ARE LOCATED RIGHT ON RT.40 THEY CAN DO ANYTHING...
