Lowered Car and new Cluster
'09 A4 S Line
Originally Posted by sunman
I have the standard AMG c32 front and rear bumpers.
2004 SL 350 & E class 200K avantgarde
Wow, good job, Dr. Sunil.
It really same cluster of my car---05 W211 Avantgarde(sports version).
You can see better smooth character on cluster...
and better than black colored cluster of regular W211.
'09 A4 S Line
THe trunk lip spoiler is acually a Lorinser which was purcahsed WAAAAYYYY before the AMG version came out.
Couple of questions......What happens to the Distronic now that you changed the gauge cluster??? It looks like you no longer have the display area for it.
Also, I checked your web site, but could not find specs on your cars color. Is it Pewter or Brilliant Silver??? Also, which AMG rims do you have, 17" C32 or 18" C55??? And lastly, you are the only one that I've been able to find that added a heated steering wheel. How difficult is it to do and which wheels from other models will work??? I had a heated steering wheel in my totaled BMW 5 series and can't imagine living without it.
Car look aswome and you should be commended for your passion!
#32
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Sunman, looks great! For all the work you put into the OEM changes, it must be so rewarding.
#34
2015 E250D
Distronic still works fine with a 209 cluster. It was once offered for the 209 series. Car is pewter silver. AMG 17" rims currently. I have AMG 18" style III in my garage which I am going to put on soon. Heated wheel is expensive as you have the change all the switches in the steering column to 211 switches, 211 steering wheel and 211 airbag.
#36
Super Moderator
Originally Posted by Sauceboy01
Looks like we're not getting an answer as to how much it was!
all I know is that it's out of my price range! hahaha
#37
Sunman, how did you get heated seats in the rear? DIY?
#40
EVE
I already stated 800-900 above. THe rear heated seats are transplanted with electronics from a w202. They are automatic, 2 level, auto off.
flip
#41
2015 E250D
conversion to the new cluster DOES NOT require conversion to MOST. If you do replace a 2001-2004 car with a new cluster from a 209 style, then you have to get a 209 cluster from 2003-2004. If you have a MOST based 2005 C class and want the 209 style cluster, then you have to get a 2005 209 cluster.
#44
Originally Posted by nlpamg
dude, I don't want to know...
#45
Super Moderator
Originally Posted by drexappeal
LOL...as is majority of the stuff Sunman has done to his whip! He's got some crazy cool toys in his w203, but just couldn't find the time or the money to do all of them.
#46
One question sunman. Is the centre pixel display capable to display all the functions like the w203 display, or is it less pixels and you loose a bit of resolution? Also at night which one displays better?
#47
Super Moderator
bone stock E55 AMG
You should really get C55 spoiler to along with your 999+ OEM mods.
#48
2015 E250D
The display of the 209 cluster is a higher resolution display than the 203 cluster. IT displays the same amount of information if not more. It also has a bar that goes around the center of the cluster depending on when you set the cruise at or when you set the limiter. THe bar marks the speed position. THe odometer and gear indicator is on a separate display below the main display.
The 209 cluster looks much better at night and especially the white one becuase the white dials have a soft glow to them. The entire dial lights up and not just the numbers.
