Tein S Tech Springs
Old Jun 5, 2006 | 07:34 PM
  #51
Blake P's Avatar
'09 A4 S Line
Originally Posted by FrankW
just so you guys know. TEIN is currently looking for another C320 to do the R&D again on the Coilover. If you are around the greater LA area it's worth to contact them.
Ask Jackson to do it!
Old Jun 13, 2006 | 10:20 PM
  #52
W Cole's Avatar
makes your daughter horny
Tein Springs?
I found some tein springs on ebay for a steal ($110 + shipping). I haven't seen these talked about on this forum before, is anyone running them? Whats the drop look like? How about the ride comfort?
Unless someone has good expierience with these I think I'll just go the H&R route with the higest pad (#4?) in the rear and 1 coil cut off the front...
Thanks,
W Cole
Old Jun 14, 2006 | 01:25 AM
  #53
JesLet's Avatar
2002 c 240
Yes there was.. go search this forum about "Tein S-Techs"... I have S-techs on my 02 C240, stock shocks, cut 1 coil in front, stock rear pad. Unfortunately my car is still high but I'm satisfied though.
Old Jul 26, 2006 | 11:41 AM
  #54
papo109's Avatar
Exclamation Anybody installed Stech Tein Springs on a C240???
I Have a 2002 C240 and i wanna install the S tech Springs from Tein.
I was wondering if anybody has installed these in their C240???
Have you had any problems with the springs???Did you need camber correction???
Will i have to change the stock shocks or no???Did the gap in the front close??HOw low did your car drop???
These are just questions im wondering before i buy these springs.If anybody can hepl me out id appreciate it.
Here is a pic of the Stech springs.
Old Jul 26, 2006 | 11:44 AM
  #55
Blake P's Avatar
'09 A4 S Line
Nobody lowers with springs anymore. Coilovers are all the rage!
Old Jul 26, 2006 | 02:23 PM
  #56
papo109's Avatar
Y is it that everyone is lowering with coilovers?????
Old Jul 26, 2006 | 02:48 PM
  #57
MJ50's Avatar
Super Moderator
bone stock E55 AMG
you can adjust the height w/ coilovers...
at least get spring/shock combo...
Old Jul 26, 2006 | 02:53 PM
  #58
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Please search before posting new threads. TEIN S-tech springs have been discussed before.
Merged.
Old Jul 26, 2006 | 02:55 PM
  #59
Blake P's Avatar
'09 A4 S Line
MJ has it right. You dial in the exact drop you want and have a matched spring/shock combo. If you get just springs, the stock shocks will blow because they weren't built to handle the added compression. You can match springs pretty well with Koni shocks, but they certainly weren't made to work with one another the way c/o's are. By the time you spend the money on springs and shocks, you could have just gotten TEIN Basic coilovers and done it right!
Old Dec 27, 2006 | 02:05 PM
  #60
Ryanr317's Avatar
R129, XF Sportbrake, SC400
I'm thinking about getting these springs. Anyone know what the stock pad number is on a 2002 C320 sport? I wasn't sure if they had a different pad from the non-sport models because the ride height seems very close. I'm thinking about getting the highest available pad for the rear so that it won't end up rubbing and so the drop will look more even.
Old Dec 27, 2006 | 02:12 PM
  #61
drexappeal's Avatar
I'm pretty sure all sport models have the #2 pad. Remember, spring pads are only in the rear. Highest pad would be #4, but you probably will want to stick with the #2.
Old Jun 1, 2007 | 07:17 PM
  #62
Hummell's Avatar
2004 C230 Kompressor Sport Sedan / 2007 Nissan Murano
Are these authentic? They say they will drop my c230 ss by 1.5 inches...anyone have any experience with these on a 2004 c230?
Thanks!
Hum
http://cgi.ebay.com/ebaymotors/Tein-...spagenameZWD1V
This appears to be the same set of springs, just less drop and less expensive?
http://cgi.ebay.com/ebaymotors/Tein-...10034426QQrdZ1
Old Jun 5, 2007 | 11:40 PM
  #63
mbarrad's Avatar
2005 C230SS
Thanks!
Hum
I was wondering the same too. I am also looking into Tein S Techs.
Old Jun 6, 2007 | 10:37 AM
  #64
outaurleague's Avatar
w211 e500
I had them on my 240 before the coilovers, and it was a nice drop, 2.5 in the back i think 1.7 in the front. Really made a difference on the 240, but yeah like drex said, for the other models, i dont think you will notice it much. But as long as i had them, they were fine. Good luck !
