EC Rest Button...NO AC! Help!
Old May 10, 2006 | 11:09 PM
JackTheRipper's Avatar
I recently turned on my car and the EC Rest button was lit up...and i pressed it....and it still remains lit...
my car is no longer under warranty...
has anyone ever experienced their EC Rest buttons not cutting off?
how much will this cost to fix?
PS my freaking back window won't roll up either :-(
C240 2001
thanks
Jack
Old May 10, 2006 | 11:22 PM
m444's Avatar
Audi C7.5 S6
Check your fuses.
Alternatively have someone check your Freon charge, to see, if there is a leak.
Old May 10, 2006 | 11:40 PM
i don't think it's a fuse or the freon..
i have been doing some reading....it seems to be some type of sensor...
anyone know anything about this?
Old May 10, 2006 | 11:50 PM
Trekman's Avatar
Silver 2002 C32, Silver 2006 CLK 350
maybe you need to reboot your car some how? maybe taking the power off by disconecting the battery? I dont know but I would try that and see if it works....
Old May 10, 2006 | 11:59 PM
that wouldn't mess anything else up now would it?
any of my service A's or B's?
would it erase where they are?
Old May 11, 2006 | 12:09 AM
Trekman's Avatar
well In dont know that. but when you disconnect your battery and reconect it you will have to do some resinc on your car like turning yout steeriing wheel all the way left and right, rolling your windows up and down and the sun roof.
how old is your battery? it might be going bad if its 3 years old and it will start doing wierd stuff.
https://mbworld.org/forums/c-class-w203/115277-list-faults-occur-after-disconnecting-battery.html
read that link it will tell you all the things that happend when you remove the battery and how to reset it. hope it helps
Old May 11, 2006 | 12:10 AM
Trekman's Avatar
it wont do anything to your service A and B
Old May 11, 2006 | 01:25 PM
Expat's Avatar
2002 C32
I'd be careful about disconnecting the battery, here's the thread that lists issues people have had:
https://mbworld.org/forums/showthrea...hlight=battery
