reverse TICKING noise
Old May 30, 2007 | 12:23 PM
moosejaw's Avatar
none
just wanted to chime my two cents.
I have ahd the same problem for a while.
A clicking sound when i start out and tap the brakes. And again when i engge reverse and then brake. Until I pointed it out did passengers in my car notice. It drives me nuts. In the morning i tense up in fear of hearing it. It is not acceptable for a car from any country to have this problem
Old May 30, 2007 | 12:28 PM
outaurleague's Avatar
w211 e500
Interesting, i havent noticed anything. I will look for that when i get off work ??? What to you Merc Gods think it could be ?
Old May 30, 2007 | 06:15 PM
advans's Avatar
C55 ///AMG, 535xi
normally this doesnt happen tho. its just after a heavy throttle driving, then when i back into my driveway, it ticks and drives me NUTS!
Old May 30, 2007 | 10:45 PM
coin's Avatar
'06 CLK500
I also noticed that my front-passenger side sometimes made the ticking noise.
My SA said that it was normal that the electrical system or something under the hood made those ticking noises .
Old May 30, 2007 | 10:52 PM
gregr09's Avatar
non-MB
Originally Posted by advans
the lugs are probably slightly rubbing against your brake assembly.
good call. brought it to the shop and it was the wheel lock hitting the brake assembly. grinded the bolt down and problem solved.
Old May 30, 2007 | 11:06 PM
advans's Avatar
C55 ///AMG, 535xi
great! I still have to solve mine!
Old May 30, 2007 | 11:19 PM
  #32
Outland's Avatar
2002 C230 Coupe(M111)
Push on the slush box master control lever till it reads "D". Problem solved.
Old May 30, 2007 | 11:35 PM
  #33
SlvrC230SS's Avatar
2006 C230SS & 2009 E350
I hope it didn't hit any abs sensor. but glad problem is solved.
Old May 30, 2007 | 11:48 PM
  #34
gregr09's Avatar
non-MB
I hope it didn't either. I babied my car all the way there. didn't go over 25mph.
Old May 31, 2007 | 03:04 AM
  #35
cappucciiino's Avatar
c350ss
I hav an 06 c350, noticed the same problem .. had them check it out when got serviced and they said faulty brake pad, they replaced it and it was fine for about a week or so and then it came back.. so annoying.. dunno what it is.
Old May 31, 2007 | 07:15 AM
  #36
advans's Avatar
C55 ///AMG, 535xi
its not brake pads.
I replaced both front and rear brake pads with paste/ rotars, did a brake flush, parking brake shoe was replaced. its still there, I think it might be the rear caliper.
Old Jul 23, 2007 | 11:47 PM
  #37
moosejaw's Avatar
none
My clunking sound is the driver side strut, confirmed by a tech in a independent shop. Gonna have dealer check it out
Old Jul 23, 2007 | 11:51 PM
  #38
advans's Avatar
C55 ///AMG, 535xi
hmmm....
for this ticking noise, it sounds like the caliper hitting the rotor, I'm goin to the dealers tomorow, see whats going on with a few OTHER weird noises...
I had my front torsion bars, endlinks, lower control arms replaced for the front. I think I might have damaged the rear, so that might have to be replaced as well!
Old Jul 24, 2007 | 12:23 AM
  #39
moosejaw's Avatar
none
thats what i thought too till the tech vibrate each wheel and noticed drivers side vibrated funny and made mor e noise then the other one. He confirmed it, strut was bad.
Old Jul 24, 2007 | 07:26 AM
  #40
advans's Avatar
C55 ///AMG, 535xi
sucks!
lets hope my SA covers everything
Old Aug 6, 2007 | 10:12 PM
  #41
moosejaw's Avatar
none
Nope the dealer wont cover my work cos the previous owner lowered the car and my SA voided any suspension issues from my warranty, Nevermind the fact that the car is purchased as a CPO in the condition it is in now ! I even have pics to prove it.
Old Aug 6, 2007 | 10:16 PM
  #42
advans's Avatar
C55 ///AMG, 535xi
hmm, my ticking noise is still there tho, and that "clock clock" noise i get from my rear drivers wheel is still there, the dealers cant do anything right! sigh...
did you ever take a clip of how yours sound like?
Old Aug 7, 2007 | 12:12 AM
  #43
moosejaw's Avatar
none
Sounds like a large clap. U can hear from outside
Old Aug 7, 2007 | 12:23 AM
  #44
advans's Avatar
C55 ///AMG, 535xi
if its a clapping noise, I think that should be the same sound as mike (waveykat)'s car.
Old Jan 1, 2012 | 10:08 PM
  #45
carbizindio's Avatar
2003 C32, 2002 S55, 1999 SL500, 2004 S430
hey guys, i found this issue that i saw on B**world.
"Has anyone else ran into this problem. The specs are 2006 C230 auto. When in reverse and under 5 miles per hour, when you are tapping on the breaks frequently, it makes a sound as if metal is hitting metal. MB knows about this issue, but say it is normal use.
Does anyone know anything about this. Thanks in advance! "
and I have the same problem, its this loud metal "ticking" noise, I have no idea whats wrong. I the brakes apart, added brake paste, reinstalled the brakes and cleaned the rotors, whats going on!??
I have the same issue as you do. Clanking noise only going in reverse under 4mph after hitting the brake hard, noise starts just before you back your foot off the brake. I have not inspected under the car yet but I walked along side of the car when we started the noise. At first I thought the noise was coming from the rear brakes but it doesn't sound that way. My first impression is the exhaust system coming in contact with another part.
Have you figured out what your problem is yet?
