need advice did somethin stupid in my car..
ok so i was going to my friends house making a left street going about 15-20ish and i gassed it through the turn and drifted a little and hit my front passenger side rim and it bent it..its the oem funnel wheel..and i got a flat..ok fine..so i was like **** and me and my friend swapped the spare out but my alignment got tweeked out and the wheel is all screwed up and is out of alignment..i dont think i broke the axle cuz it still drove all the way home jus it rubbed a lot and the wheel was still turnable it jus made noise cuz it rubs toward the side facing the back of the car..i didnt even fully hop the curb i kinda jus hit it and stopped...big mistake..but now im stuck in a rock and a hard place..what could be the case? i know mercedes doesnt warranty this type of stuff or do they?...i jus need help to see if i can get this fixed easily without much coming out of my pocket..b/c most likely im gonna end up having to buy a new rim..which in turn makes me jus want to get aftermarkets b/c its the fraction of what mercedes will want for a oem 17 in wheel..im mainly considered about suspension and alignment...all help is very much needed lol..
Hm. I would like to help you... but... please help me by doing a better job in writing! Once you damage the alignment it is very hard to get it back to manufacturer specs. You can browse through internet, such as eBay, to look for stock Mercedes OEM wheels. Good luck bro.
2006 E55 and 2002 E320
Agreed, it'd help if the sentences were structured.
I was in a Lexus IS300 that did the same thing, left turn, drifted, rear passenger side wheel hit the curb with considerable (but not tremendous) force throwing me into the window as I was sitting in the rear passenger side seat.
You can hear it if you have axle trouble. The cracked axle will have a different sound. It will have an unbalanced whirring sound that increases with speed.
The stock wheels are cheap, the rears are around $300 a piece, the bad part will be that you have to replace both rear tires if the difference is more than 3/32 inch.
Suspension should be fine, sway bars, shocks, springs will be fine. However, the axle is what I'd be worried about. Alignment will not necessarily solve the problem, you'd be lucky if it does. If it's something alignment can fix, then a mere $1000 will solve the problem for the alignment, wheel, and two new tires. If not, be prepared to spend a bit more.
And no, of course they don't warranty your crashing/drifting into a curb.
first I've got to say, WTF you don't have a drift car, sucks learing the hard way. So i'm guessing your suspension is going to be ok and unless you're having any odd noises i would guess your axle is ok also. I haven't checked the setup first hand but i'm guessing that it's a lateral arm.
hey man, sorry to hear abt the damages,
take the car to a local mechanic that does alignment, it should cost alot less than what mercedes offers, and you can check out the classifieds, or ebay for one used OEM rim (which 17 are u running on!? the 7 spoke style B or the 5 spoke ones?) but good luck
yea hopefully its not too bad..its my front passenger wheel..not my rear, but we'll see what happens, i have the new 5 spoke style wheels, i dont care for the rims, im worried about suspension. Ill prolly end up getting aftermarket rims now, sooner than i expected. i know its not a drift car, but its my first rwd, lol i know im stupid, but i learned the hard way. thanks guys, and ill keep an update going as soon as i can..
Drifting yet hit the front wheel, not the rear on the curb. Either overcorrected or understeered and wasn't drifting at all.
I bet you'll cost close to $1K to fix:
1 new wheel ($300)
2 new tires ($400)
alignment ($100)
anything else damaged (parts + $100/hr labor)
1 new wheel ($300)
2 new tires ($400)
alignment ($100)
2002 C230K, 2013 BMW 328, 2015 BMW X5
I'm more worried about your steering rack over the axle. Have you been underneath the car to inspect for damage? You really need to get the car up, take off the covers and inspect the suspension components. Depending on the angle of your hit. You could have tweaked a control arm.
Is the car bucking under heavy braking?
Let us know the outcome.
1 new wheel ($300)
2 new tires ($400)
alignment ($100)
1 new wheel ($300)
2 new tires ($400)
alignment ($100)
Wait, if it's the front wheel... Isn't that understeer? I'm totally confused here.
THAT'S NOT A DRIFT, THAT'S CALLED PLOWING.
I'm so confused.
This is also my first RWD car (my first car at that), and I don't go drifting, and I'm two years younger than you.
ok ok enuff bustin the *****..i dunno what happend but i jus downshifted and went thru the turn and i ended up hitting my front wheel..oversteer galore..but whatever..i learned the hard way..
the cars in the shop, we'll see what happens...
you may be two years younger than me, but your parents prolly also bought your car...so lets stop the bashing...i tested the limits of my car and thats what happened..lesson learned..never do again..
2015 E550 Coupe, 2012 E350 4matic Sedan, 2016 fully blown out custom camaro 2SS
Damn dude sorry to hear about your bad luck, but like you said now you can't look at some new rims, hope thing's work out and your out of pocket is kept low.
Goodluck!
Goodluck!
dude that sucks, sorry to hear that... hope everything gets fixed properly...
anthuny, don't listen to him, he likes to get on his high horse and be holier-than-thou.
definitely lesson learned, everyone at no matter what age does something stupid. plus, your tires could be going bald and that may have been the issue...
Originally Posted by patrick_y
Learning how the limits of your car... priceless.
I'm so confused.
I'm so confused.
Dont worry bro i learned my hard way when i almost killed myself when i use to drive a W126 560SEL. it was during winter when the road was kind of slushy and i also gassed it a little too hard and fortunately i was ok but my car hit a tree on the side.... just as long as you are ok. Dont get me wrong i still mess around in my C320 but i just do it when its safe lol.
G Luck
G Luck
G Luck
G Luck
k well car came out the shop..had to order parts until work can be done. ordered:
one new control arm..it was bent...
one new front wheel..
i know a wholesale dealer so i was lucky to get each for 200's..so if the control arm + alignment fixes it..ill be good to go..
oh yea..my tires were brand new..its just that our c230's are TORQUE MONSTERS WOOOO..yea right...*sigh*...
C230K Coupe/Orion/C4/C5/CD/AMG Spoiler/V60/TeleAid, 2 MGB's
1 new wheel ($300)
2 new tires ($400)
alignment ($100)
1 new wheel ($300)
2 new tires ($400)
alignment ($100)
Originally Posted by raymond g-
anthuny ...this didn't happen as you were leaving the theater parking lot
after having watched Fast a/t Furious: Tokyo Drift, were you?
Lol... I hope not! That'd be hilarious! C230 doesn't have a lot of torque... plus it's harder to control a car when there is no Limited Slip Differential. Glad everything came out alright.
no no i didnt go watch that damn movie and go drifting lol...ill keep yall updated as soon as the parts come in hopefully by fri/sat...thanks for all the help ..and ball bashing..such a loving family
Yep, I figured you tweaked the control arm.....
Pat, whats with you always bringing your age into discussions? Just curious. But in any case, Pat is right, your car didn't drift, it plowed with understeer.
Ed
I would first like to apologize for committing the "ball bashing", as this was honestly not my original intention and I realize that I do come off as quite the insensitive person here and I'm not helping as much as I could in this case.
Lastly, I mentioned my age because of what Anthuny said over here. I guess it's not really applicable.
Anthuny, you're an intelligent person who can face the music when you do something wrong. Most people who do have accidents in their automobiles rarely admit their fault so readily; however, you are perhaps some of the few who are mature enough to realize sometimes it's their own driving when they hit something and they would usually blame it on anything but themselves. Lastly, I don't consider this as a "stupid" mistake, it's just a mistake, perhaps you're a little too hard on yourself.
I've seen much more stupid mistakes. Someone tried to drift and grab the e-brake and grabbed something else (that also had a handle) that shouldn't have been in the car to begin with. Next thing I know, we hit the curb and I'm thrown into the window.
Lastly, regarding your tire pressures, you might wish to consider in the future to have the front at an even lower PSI to prevent plowing.
update: ..mercedes forgot to order my parts, how nice is that? I call and the guy says UH OH. That told me right away they forgot, so parts wont be here til monday/tuesday, when in reality my car should have been driving right now..MB sales reps, gotta love em
