lowering the C230K
Old Aug 21, 2002 | 11:02 PM
ragga's Avatar
2003 C230 Kompressor
Exclamation lowering the C230K
i dont know black from white when it comes to modifying cars. can anyone please tell me what exactly i need to lower my 2003 C230 Kompressor Coupe about 1"-2".. someone said i need SHOCKS along w/ the H&R/Eibach type springs?
please help
Ragga
Old Aug 21, 2002 | 11:41 PM
Xeon's Avatar
based on my own experience, although i am no expert, i lowered my car with H&R springs..but kept the stock shocks.....the car is abt 1.5 inches lower...handles better....so..doest matter....but..everyone have different views..and different amt of money to spend
Old Aug 22, 2002 | 06:22 AM
ragga's Avatar
is 1.5" the lowest it can go w/ h&r springs? and... how much did you pay for yours, and what model springs are htey, so i can purchase.
Old Aug 22, 2002 | 08:51 AM
mdp c230k's Avatar
2002 c230k
H&R coil over kit will go lower than 1.5", but you will be scraping your bottom if you're not carefull.
Old Aug 22, 2002 | 09:43 AM
JeT's Avatar
JeT
C230Jeff,
Is there a specific Eibach kit that you need to buy or is there only one kit for the C230?
Old Aug 22, 2002 | 10:06 AM
JeT's Avatar
JeT
Thanks C230Jeff,
Are there any resulting problems with negative camber? Or is the lowering subtle enough to avoid having to check alignment and stuff?
Old Aug 22, 2002 | 11:52 AM
c230_2k2's Avatar
Alabaster White C230K Grey Int. and 2003 C32 pewter/charcoal gray
once you lower a car your alignment is altered , but for an inch lower it might not be as bad if you do 2 or 3...but i would still suggest to ahve it check for camber and alignment. Usually lowering with a spring is the best way to go not unless you have a lot of $$$ to spend....coilovers are good but how often are you going to adjust it? this is only good if your going to car shows and stuff. And if your really want to spend money on it , probably look for somebody who will install air bags suspension on it.
Old Aug 22, 2002 | 01:34 PM
ericg320's Avatar
S 500
Any one know a good installer in Houston?
Old Aug 22, 2002 | 09:10 PM
SKIDZ's Avatar
'06 CLS500
My opinion....
I, for one, figure that if I'm to dish out a bunch of $$$ to lower my car then the amount of drop should be noticable. And from what I've heard, the H&R Cup Kit would be my suspension component of choice. It'll give about a 2" drop up front and about 1.4" in the rear; .....correct me if I'm wrong. I'm still searching for an authorized dealer in my area that'll give me the best price for them.
Old Aug 22, 2002 | 11:35 PM
SLK Boy's Avatar
2002 C320
You don't have to replace the shocks when you lower the car, but you will wear out the stock shocks faster because they're not designed to withstand the shorter springs and higher spring rates. Also, since they changed the shock/spring setup on the W203's (the older benz's had the springs and shocks separate from each other), you might as well change them at the same time.
Eibach's tend to be a softer ride than H&R's. Eibach also makes springs for AMG (and Carlsson from what I believe). Bilstein Sport shocks are a good combination with lowering springs.
The good thing about the H&R cup kit is that the springs and shocks are matched. However, i hear they lower the car quite a bit. H&R also makes a coilover set for the W203.
Yes, you should get the car aligned after you lower the car (though I didn't do that when I lowered the SLK, and everything was fine ). Make sure they correct the toe...i'm not sure if they can correct the camber w/o a camber kit though..but i'm not sure about that....And don't forget to rotate the tires (if you don't have staggered wheels).
Old Aug 23, 2002 | 07:53 AM
bagwell's Avatar
From: Houston,TX-moving to The Woodlands,TX SOON!!!
Toyota Tacoma & Lexus IS250
I'm looking too....Progressive Auto Sports (1960 @Kuyk) was my latest visit on 08-22 - they work on a lot of MB there. I think they said $250 to install the Springs/Shocks.
I may stop by Awesome Transformations on 1960 as well
