WaveyKat Mods & questions
Old Jan 26, 2007 | 01:39 PM
  #326
BKLYN_C's Avatar
MB
Originally Posted by tee_tz
People stop saying this. At 65MPH crash then yes, Mercedes Benz cars are safe. But at anything over 80MPH it doesn't matter whether you are driving a Ford or Ferrari, a Benz or VW, only God can save you. My point is, he was just lucky, Mercedes does not 'vouch' that their cars can protect you on a 90MPH impact.
Think about that every time you accelerate past 80MPH...
Tee_Tz.
No car will save you in 100mph collision
All bikers are suicidal maniacs
Old Jan 26, 2007 | 01:42 PM
  #327
ultraman206's Avatar
M5
Whatchoo talkin' 'bout, Willis?
Old Jan 26, 2007 | 02:10 PM
  #328
BKLYN_C's Avatar
MB
Oops, sorry, didn't notice you were here
My dad tried to teach me riding a bike when I was 12. I coverd a distance about 10-15 yards and hit a tree. So, no bikes for me
Old Jan 26, 2007 | 06:54 PM
  #329
KIRA's Avatar
2002 C230 coupe , NOt THE AVATAR!!
Ok I Delete It!!
Old Jan 26, 2007 | 06:59 PM
  #330
Mercus's Avatar
2006 C230SS Blue/Black, 2003 SL500 Silver/Black
Originally Posted by Brabus_x2
DELETED - Amdeutsch
think about the one is "close" to u... speeding ain't fun...
this pics make me feel bad for the driver..
I will never sleep again. Thank you.
Old Jan 26, 2007 | 07:00 PM
  #331
14cue's Avatar
05 C55
that's gross, dont need to show that stuff here.
Old Jan 26, 2007 | 07:04 PM
  #332
KIRA's Avatar
i delete the picture don't freaking quote it!!
Old Jan 26, 2007 | 10:06 PM
  #333
Tangerine's Avatar
Is @ Home
So thats what the underside of a C class looks like.
Scary.
I would probably never get behind the wheel of a car if that've happened to me. But since my car is slow I don't even bother with it.
Old Feb 20, 2007 | 09:39 PM
  #334
Fai+H777's Avatar
ML55 AMG
Elec. Stab. Prog. Visit Workshop! ???
That appeared on my screen. Can anyone tell me whats gone wrong please.
Old Feb 20, 2007 | 09:43 PM
  #335
Racin_fool's Avatar
2008 E63 wagon (1 of 62)
For those of us that don't know, what do you drive? Be more specific than just a C-class..
Also, there are numerous things that could cause that warning to come on. Best to just visit the dealer and get it looked at.
Old Feb 20, 2007 | 09:57 PM
  #336
WaveyKat's Avatar
Something Slow
https://mbworld.org/forums/showthread.php?t=121626
Old Feb 20, 2007 | 10:00 PM
  #337
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
bump to merge...
Old Feb 20, 2007 | 10:02 PM
  #338
drexappeal's Avatar
Merged this thread with the new thread that was created.
Old Feb 20, 2007 | 11:24 PM
  #339
TruTaing's Avatar
Moderator Alumni
w203 m112
Did you try resetting/reteaching the esp? This error is common when you have to jump your car (and maybe other power related issues?)
The whole rotate the wheel all the way to the left then all the way to the right, then back to the center? (just hoping ya arent gettin robbed)
-j0hn
Old Feb 20, 2007 | 11:53 PM
  #340
Racin_fool's Avatar
Not saying this is the fix for you, but another common failure causing this warning is the Steering Column Control Module depending on what year model you have. There was a string of them a while back that were failing left and right..
Old Feb 21, 2007 | 12:17 AM
  #341
patrick_y's Avatar
2006 E55 and 2002 E320
Originally Posted by WaveyKat
ok took my car in and the Sa told me it could be because i have 19 wheels and lowered my car thats why me ESP light is on and i need a wheel alignment now i have to remove my heel and put the stock ones back on DAMN!!
Just a suggestion.
I once had the same problem in an E320 W210 Mercedes. The ESP, BAS, and ABS all flashed on the display saying "Malfuction" and "Visit Workshop!" After taking it there, they said that there was a brake lamp switch failure and that it was an easy fix (I'm sorry I can't provide more details).
Just a possibility. The electronics fail all the time. Might not be anything wrong with the car except for a computer chip short circuiting.
Old Mar 3, 2007 | 06:07 PM
  #342
WaveyKat's Avatar
Something Slow
Installed KW Variant 2 & Sold The Tein Basic
THE GOODS
Please notice the #4 Spring Pad in the back ground that i cut in half so it will sit flush with the KW V2 Rear spring perch
H&R New Style 10mm Spacer for Front Wheel Only
the Ride at the Highest setting in the Front & lowest setting in the Rear with KW Variant 2 & Spring Pad #4
the ride with the coilovers highest Settings in the front and Half way up in the rear
I will be leving the Car this Height untill Winter Is Over
The Ride with the KW-V2 is way better than the tein to me.
SO AM KINDA BACK TO THE FACTORY LOOK BUT HAVE THE OPTION OF LOWERING AND ADJUSTING THE DAMPERS..
Old Mar 3, 2007 | 06:12 PM
  #343
14cue's Avatar
05 C55
That looks great.
KW V2's are what i want.
Did you take off your front lip?
  #344
MHPHOCKEY's Avatar
2014 Audi S5 Cabriolet 3.0T
Cool looking setup. Where is your front lip???
Old Mar 3, 2007 | 06:17 PM
  #345
WaveyKat's Avatar
Something Slow
i took it off i still got it... its winter didn't wanna be plowing the streets lol
thanks.
Old Mar 3, 2007 | 06:36 PM
  #346
Ryanr317's Avatar
R129, XF Sportbrake, SC400
Looks good man. Any difference in ride quality?
  #347
rlee02135's Avatar
2004 C32 ///AMG
looks good!
Old Mar 3, 2007 | 06:46 PM
  #348
white_w203's Avatar
is SOLD
why dont u lower it some more in the front? the rear looks good.
Old Mar 3, 2007 | 06:47 PM
  #349
C24owner's Avatar
'08 E550 4Matic
Looks good bro...
Where did you get the spacers from?
Old Mar 3, 2007 | 07:14 PM
  #350
WaveyKat's Avatar
Something Slow
got the spacer from purems.com.. i need to add the 10mm spacer to lower it some more right now i still got the 5mm on and the spring perch is very close to the tire.. the ride quailty is great compare to Tein its Way better.. maybe its because i have the Dampers set between soft & Hard
