Strange Noise From Muffler on Cold Start
My C230K (3 week old with 900+ miles on the Odo) makes weird noise on cold start and the noise lasts for about 30 seconds. It sounds as if an old Harley's warming up in your bedroom. Nearly as noisy just as bad. It sounds troubling - I thought I might have a hole in the muffler.
Is it the the noise/sound we referred to in other posts?
ALso what is the optimal RPM or MPH points for shifting to a higher gear when engaging the touch shifter?
Thank you All.
Peace
2. If you have auto transmission, you don't need to be concerned when to shift ( in manual mode ).. even if you manually shift, the computer won't let you do anything without it's permission
My C230K (3 week old with 900+ miles on the Odo) makes weird noise on cold start and the noise lasts for about 30 seconds. ... Is it the the noise/sound we referred to in other posts?
My guess is that the exhaust valves are kept open longer on cold starts to warm up the cat. Is this a resonable assumption or does anyone have a better explanation?
with MY experience...yes..it has been my S/C..as when i changed exhaust the sound went away...and then when i put a 3 inch exhaust straight back....it was worse....
its hard to get the sound gone (in which if you do...it kills performance) due to the S/C
it's not the s/c, the sound for the first 30s to 1min is from the air pump. it runs until the cat is warm enough in order to keep emissions down. you could probably turn it off, you just wouldnt have as pleasant a scent in the mornings, and you might not pass smog check with it off.
benzy230 is right, it IS the supercharger that is used to supply more air to the catalytic converter at startup to heat it up faster. In other cars the same effect is achieved by using air pumps. MB engineers decided to save some cost and weight by using the air pump that's already there - the supercharger. The price - this signature John Deere sound that we have to enjoy every morinig. Electric air pumps are much, much quieter...
In either case, I am certainly not ashamed of it. But hey, I think I had different motivations for buying mine that some other folks here.
