19".. Where does your rear tire rub againts??
Old Aug 29, 2006 | 05:20 PM
SEXSPHERE's Avatar
//WALD C320 Magnifique [sold], BMW Z4 3.0i 6spd[sold]
I have 35mm offset, 265/30, slammed with H&R @ lowest setting, but when i have 5 people in my car, i still rub on the highway when i hit a bump, im just curious where did it rub againts?? Is it the fender? Or the bumper(bolt hanger)? I havent gotten my fender rolled yet but i dont think my tire rubs againts the fender though...
Old Aug 29, 2006 | 05:29 PM
Blake P's Avatar
'09 A4 S Line
The most common place for rubbing is against the back side of the fender just behind the bumper strip. There's a plastic tab that will rub no matter what tire size you run on 9.5"+ rear wheels if you've got a decent drop with a few passengers. You have to dremel/sand/cut that plastic tab off if you want to avoid rubbing.
Old Aug 29, 2006 | 06:01 PM
white_w203's Avatar
is SOLD
check where the tire is being worn out. usually you can see where the tire is rubbing.
Old Aug 29, 2006 | 06:09 PM
jo17jC230's Avatar
2008 C300 Sport
are your tires getting chewed up when its rubbing? if it is then its rubbing against the bumper trim that blake was talking about or another piece of trim somewhere... you might also want to check the felt wheel well lining... when i had my fenders rolled/trimmed they had to cut the felt lining cuz it was rubbing like crazy in there...
Old Aug 30, 2006 | 01:20 AM
M230K's Avatar
2012 MERCEDES CLS63 AMG
what are you doing with 5 people in your car? ive never had more than 3 thas including myself lol
Old Aug 30, 2006 | 03:07 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
in your case...most likely the inner fender lining...mine's doing the same.
if it's not touching the outer fender now...it's not gonna touch when you have ppl in the car.
Old Aug 30, 2006 | 04:28 AM
SEXSPHERE's Avatar
i think it is just behind the rear bumper strip, because i can see it from the tire.. I had them dremmel already but yet it still rubs. And the shop that i had it done say that it is at the maximum he could cut.
Old Aug 30, 2006 | 04:29 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
if it's rubbing on the tabs from the impact strip just have them dremmel the entire tab out. The trim is not gonna come off and if it does...Betalink it.
