Best way to tell if c/o's will rub the tire?
Other than blindly guessing then testing it out and listening for rubbing noises when you drive, is there a best practice for determining whether the coils will rub the front tires? Some people say that you can jack the car up, then stick a piece of paper/cardboard/etc. between the wheel/tire and the suspension, but I'd think this isn't an accurate representation of how the wheel/tire sits in relation to the suspension when the springs are compressed after you set it back down. I've heard others say you can turn the wheel all the way to one side, then look behind the wheel to see how much space you have between the wheel/tire and suspension, but I'm not sure if this is accurate either since our wheels tilt to the outside when turned to provide a better turning radius. Some are able to hear or feel the rubbing during a quick test drive, while I know others who have taken their wheels off after a while to find out they had been rubbing and never noticed. I also know another guy who was driving along and smelled burning rubber, but by the time he could do anything about it, his tire already blew. Hopefully someone has insight they can share.
I'm taking it that you're not very familiar with coilovers? When the car is off the ground the springs are FULLY uncompressed widening the gap between the tires and coils. Reference the picture below. The car is off the ground with my stock 18" AMG wheels. Once on the ground the tire moves further upward and will contact the wider spring coils if compressed far enough.
I must disagree with you. From what i know, the suspension and wheel act together as one. If you turn really hard, everything else will turn with it. Same with upward and downward movement. I wouldn't worry about anything once the wheel/tire spins FREELY when the car is raised. I'm pretty sure i'm right.
This is Neal's car
THis is the result of setting my car on the ground with my stock wheels. In the previous pic you'll see that it doesn't touch while in the air. Now that we're on the ground the wheel moves upward causing contact. Same thing happens when you drive and hit a bump. It goes even further up. I didn't even drive the car in the pic below. Imagine what would happen if i did.
This is Neal's car
I haven't really had issues with my coilovers and aftermarket wheels until recently. I saw some rub marks on my passenger side spring coils. Nothing extreme though.
I've been having rubbing issues lately Front and Rear with my Tein Basic COs.For the fronts, I found many chipping marks on my inner lip.My wheel rubs against the perch/coil?Should I raise it/put 5 mm spacers ( I have spare spacers)?ET of my front wheels is 35.If I put 5 mm spacers, I will have ET 30(corect me if I'm wrong).Will my tires rub against my outer fender?
For the rears,everytime I hit big bumps,my rear wheels/tires rubbed against something.From the sound of it, it sounded like steel rubbed against steel,really SCARY sound.Anyone has any ideas?All I can think off,maybe, my inner lip rubs against my shock?is it possible?My original ET for my rear wheels is 38.I put 3 mm spacers,so now it's ET 35?!
TIA
