DIY installation of AVIC & other aftermarket HU's for W203 (Warning! lots of images!)
#455
i've always used the buttons on the oem deck to change volume and switch songs anyway.. those are the only functions that i lost from the steering wheel so it's no biggie for me. i love this new deck
#456
has anyone tried this:
http://cgi.ebay.com/ebaymotors/KENWO...spagenameZWD1V
i know the controller for pioneer works, but has anyone tried the kenwood one?
#457
2005 C230K Sport Coupe
So about how long, start to finish did it take you to install this unit? Did you come across anything funky while putting it in that you had to make fit? It looks great and I've been looking around for a new head unit for my car.
#458
I believe you can get a module to integrate the steering wheel controls. I'm going to try this with my install of the DNX7100. I've heard Soundgate and/or PAC may have add-on modules to maintain some control of basic functions from your steering wheel buttons.
I'll post pics and let you guys know.
Jon
Jon
#459
NeoScotty - like any other audio mod. I spent more time on hiding wires than putting in the actual unit itself. The hardest part was making everything sit well behind the deck since there isn't much room to play with and making sure there's enough space for the rear fan to cool the unit off.
The dash kit will give you gaps, so you will need to play around with the top and bottom pieces to minimize the gaps.
AMGfan - let me know how it goes ~
#460
#461
2013 E350 Bluetec, 2008 Audi S4 Avant, 2011 VW Golf TDI, 2015 Audi S3, 2020 GLB250
which dash kit did you use? That looks really nice! Looking into something like this, but the Metra dash kit requires a lot of cutting to fit a double DIN...
#462
05 c230
the setup looks super tight!
just one questions. i know you didn't have the bose system so it was relatively easy.
i have a harmon kardon and wanted to do similar. is that possible? i've hear no so many times, but hopefully some one that has would be able to advise.
thanks
thanks
#464
I don't have bose or HK so it was a step easier for me. As for any OEM upgraded sound systems. You will need to bypass the amp. It's really not too bad, you just have to run a bunch of new speaker wires for the aftermarket HU. I haven't done it to a benz but I did it to my father's Toyota Tundra.
1. locate the amp
2. check to see if all of the speaker wires are feeding into the amp.
3. unplug the speaker wires adapter that goes into the amp and tap a set of new wires from the adapter and send it to your aftermarket HU.
that was pretty much it for the Tundra...
#466
'06 C230 Silver (SOLD), '14 Black C250 Coupe, '16 Deep Ocean Blue Silverado
Question for sanf
Just finished my D3 install and the fm reception is zero. I got the euro adapter for the antenna and connected it to the antenna with the black connector, not the mustard color one. Did I do it properly?
Thanks,
Mike
Thanks,
Mike
#467
that thing is useless. regardless of you attaching the 12v+ wire or not. what i did was wrapping a speaker wire all around that long metal thing and ran the speaker wire up to the passenger door upper panel so that I can get good FM reception. try it out.. and oh, don't bother with the 12v+ wire on the euro antenna
#468
Thank you very much for your help.
Did you leave the speaker wire bare at the point of wrapping it around the metal part? If not, what did you connect it to behind the HU?
Thanks,
Mike
Thanks,
Mike
#469
connect the euro antenna to your avic. strip the rubber out of the speaker wire(2 inches or so) so you have enough to wrap it around the long metal thing. then use black tape to finish up the job. just leave the two oem plugs, u dont have to use them
#470
Thanks again.
I will try that, but probably not until this weekend since I just put everything back together last night. Did you connect your VSS wire and if so, where? I did not see a pink wire for that coming off of the factory harness.
Did you add the steering controls? It was a bit of a pain to find the part on the internet, but worth the searching and waiting. I finally found it from a guy in Portugal.
#472
Thanks again.
#474
#475
Something Slow
your upgrade look great!
alot of people is doing these upgrade but no one has done it in a car that has the BOSE or H/K system to let others who have this system know if we have to bypass or show a DIY on how to hook up or run wires....
