V-Belt possible problem C240 2001
At my last service the technician said there were some small parallel cracks on the back of my v-belt. Upon further inspection thre are some hairline cracks running in line with the belt (ie not across the belt) on the smooth side. On the ribbed side if you flex the belt a little I can clearly see the metal banding.
Does this mean the best is in need of replacement? If it snaps then is it going to damage the engine or will it just mean calling out the recovery and getting it done.
the technician was not overy worried and said to keep an eye on it and get it done at the next service.
If it does need doing then is it a simple DIY job for a non technical person (I am at the level where I can change pads) but I don't have a vast array of tools.
Any help much appreciated.
below is a picture showing the brading peeking through.
Not sure of the replacement cost. Are there any Guru's out there that have experience of this (not the cost I mean but more the condition of my belt and some tips on installation of a new one.).
Cheers,
Paul
The SAE has determined that serpentine is the correct word for multi-ribbed flexible belts driving accessories on internal combustion engines.
V belt is the preferred term for belts that transmit power between sheaves with tapered walls, as is the case for accessories on older vehicles and belt driven drive trains in modern cars with CVT's.
I retract my earlier statement: this type of belt should not be called "V-belt" (don't remember the last time I actually saw one). "V-ribbed belt" would be a proper name for it (as well as serpentine, of course).
Mine broke on the highway and my car kept going for a few miles until it almost overheated. The only messages that I got on my dash was that the alternator was not working and my battery juice was low. Then a couple of miles down the road I got the blaring red display saying to turn off the car because its over heating.
Then when I got off on the next exit I almost crashed because the steering was so stiff. So moral of the story is to get it fixed before wat happned to be happens to you.
I paid around $60 (also with the purchase of 4 brake sensors)
