what should I do?
Old Nov 2, 2006 | 09:13 PM
yeuchau's Avatar
Stage 2 C7 A6, QX60
what should I do?
what should I do if there is a rub in the front wheels.
the tires touches the suspension slightly, should I get the spacer.
if so what size of spacer should I do.
Michael
Old Nov 2, 2006 | 09:25 PM
rlee02135's Avatar
2004 C32 ///AMG
Michael
=does it actually rub?
if so, then get like a 5mm spacer and it shouldnt touch the shocks
what setup are you on?
Old Nov 2, 2006 | 09:57 PM
yeuchau's Avatar
Stage 2 C7 A6, QX60
front is 225/40/18, but it's the wheel has the CLK offset, which I don't know what it is
and rear is 255/35/18 which is perfectly fine.
is the 3mm spacer going to be too small??
is there any security relate issues when using spacer, or anything??
Old Nov 2, 2006 | 09:58 PM
yeuchau's Avatar
Stage 2 C7 A6, QX60
also can anyone tell me the offset for my 02C320
and also offset ont he W208 CLK
thanks
Old Nov 2, 2006 | 10:02 PM
Blazinpin0i's Avatar
Jeepney
go 5mm Spacer, 3mm is way too small
Old Nov 3, 2006 | 02:30 AM
yeuchau's Avatar
Stage 2 C7 A6, QX60
where can get spacers??
Old Nov 3, 2006 | 02:34 AM
white_w203's Avatar
is SOLD
better safe than sorry. go 5mm and if needed go higher.
Old Nov 3, 2006 | 03:41 AM
yeuchau's Avatar
Stage 2 C7 A6, QX60
will 10 mm be too much??
Old Nov 3, 2006 | 03:48 AM
BIGjohnny's Avatar
/////AMG
Using any spacers without hubcentric will most likely produce vibration to the steering wheel. Even using H&R spacers can cause vibration to the steering wheel.
However, i do believe that if you use anything smaller than 3mm spacers, vibration might not exist. Good luck.
Old Nov 3, 2006 | 03:59 AM
yeuchau's Avatar
Stage 2 C7 A6, QX60
do you know the 99CLK offset and 02C320 offset difference??
Old Nov 3, 2006 | 05:33 PM
yeuchau's Avatar
Stage 2 C7 A6, QX60
do you guys think that 10mm spacer will be too much
or should i just use 5mm spacer
Old Nov 3, 2006 | 07:07 PM
WaveyKat's Avatar
Something Slow
u must tell us the offset of the Wheels or will be kinda hard to help you i have a 3mm spacer and my offset is 38 so the spacer bring the offset down to 35 on my front right now and am fine no rubber no vibration or shaking at high speeds
Old Nov 3, 2006 | 07:51 PM
yeuchau's Avatar
Stage 2 C7 A6, QX60
that's why i am asking the offset on the 99 CLK430, because the wheel came off from CLK 430.
and i don't know the offset on that car
someone help me on what spacer to get
thanks
Old Nov 3, 2006 | 07:57 PM
rlee02135's Avatar
2004 C32 ///AMG
thanks
buy both sizes, and you'll find out
Old Nov 4, 2006 | 04:26 PM
yeuchau's Avatar
Stage 2 C7 A6, QX60
I might have to do that, cause no one has been able to help me on what size to get, or the offset differences on the CLK and C class.
I even ask about the offset in CLK forum, and they did not even reply to my post.
sucks.
Michael
Old Nov 4, 2006 | 11:38 PM
Tangerine's Avatar
Is @ Home
I've search and came up to your other post which was answered.
And did you bother searching? I did it in 5 secs and got the answer.
*Hint
Search ---> stock offset ---> narrow down search to CLK
Old Nov 5, 2006 | 12:21 AM
yeuchau's Avatar
Stage 2 C7 A6, QX60
*Hint
that's right i asked that in clk forum, and in fact they just answerd that not long ago.
Old Nov 5, 2006 | 12:23 AM
yeuchau's Avatar
Stage 2 C7 A6, QX60
by the way, the clk430 offset is 37mm, so I believe our car has 35mm offset right.
so that means I will be fine with 5mm spacer, correct me if i am wrong
and also is the hubcentric really necessary, because the one they well on HR website is not hubcentric.
and also, do i need extended bolts since it's only 5mm
thanks,
Michael
Old Nov 5, 2006 | 02:05 AM
gate1way2's Avatar
W220, W208, W203
clk offset is pretty much the same as the w203 offset. It usually runs anywhere from 35 to 38mm. I would take the front tire off and look inside the wheel just to make sure though.
Old Nov 6, 2006 | 04:18 PM
yeuchau's Avatar
Stage 2 C7 A6, QX60
i want to know that if the longer bolts is required for an 5mm spacer.
thanks
Old Nov 6, 2006 | 06:25 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
the w208 CLK runs a slightly larger offset which the wheel will tuck in more if used on the W203. 3-5mm is all it takes to rub on the suspension.
you can run a 3mm or a 5mm spacer. The 3mm spacer will not cause vibration, but if you are going with the 5mm spacer make sure it's hubcentric.
The stock front bolts should be long enough to have minimum 4-5 turns on the bolts.
Old Nov 7, 2006 | 03:21 AM
yeuchau's Avatar
Stage 2 C7 A6, QX60
but I can't find the 5mm hubcentric spacer.
ichiba say their 5mm spacer is hubcentric, but it doesn't look like it from the picture.
Old Nov 8, 2006 | 03:40 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
I think you'll be fine with a 3mm spacer.
Old Nov 8, 2006 | 07:30 AM
yeuchau's Avatar
Stage 2 C7 A6, QX60
I ordered a 5mm spacer, they said it's hubcentric, but it doesn't look like it on the picture.
oh well, just goann wait and install it, we'll see how it goes from there
